Japan Emissions
Revision as of 00:17, 6 August 2017; view current revision
Category: Emission Control And Tune-Up
度排出ガス規制適合
Note 保安基準適合 means Safety Standards.
自動車排出ガス規制 automobile exhaust gas emissions regulations, the automobile of the internal combustion engine.
* 単体規制 Single Regulation (type regulation)
  applied to new models by the manufacturer
* 車種規制 Vehicle Regulation
  constant regulation
1966 CO under 3%
1967 16-item inspection
1969 CO under 2.5%
1970 CO inspection 5.5% idling
1972 CO inspection 4.5% idling
1973 testing
1974 NOx
1975 first sticker used
1976 sticker (Left: Used, Right: New with peeling cover)
排出ガス対策済 ステッカー, 排出ガス対策済, 般社団法人日本自動車工業会 (JAMA)
1973
S48 (1973) 昭和48年
First applies to B210 1973- (not B110 1970-1972)
* Sealed Fuel Tank with Flow Guide Valve for ventilation
* Flow Control Valve 14920-H5000 (mounts on #1 intake runner)
* Anti-diesel Valve (or Run-on Solenoid for A12T)
* Idle compensator in Air Cleaner
* Distributor D411-89
排出ガス対策済
Exhaust gas countermeasures completed
点火時期制御方式の排出ガス減少装置
anti-emissions devices of the ignition timing control system
H
"H" is the 1975 (50年度) emission standards. Also in 1975 in the United States similar regulations came into effect.
* H-B210 meets H-level emission standards
* H-B120 from 1975 uses NAPS-A engine A12
23894.jpgAlbum 23894
EGR
All B211 (from December 1975) and VB210 (from October 1975) used EGR Exhaust Gas Reduction. This included Vans which were not fitted with catalytic converters.
Catalyst
Nissan system's of exhaust gas cleaning by catalyzed oxidation (NAPS) adopted. A 2-way catalytic converter converted carbon monoxide (CO) and unburned hydrocarbons (HC) to produce "harmless" carbon dioxide (CO2) and water (H2O). It was only later than CO2 was acknowledged to be a pollutant itself. NOTE: In 1980 the 3-way converter introduced a 3rd reaction to reduce the third major pollutant NOx.
To enable efficient conversion, extra oxygen is introduced into the exhaust system by use of Nissan A.I.S. (Air Injection System), using a passive air induction (tuned pulse-flow) system. It used a cylinder head with an air passage drilled from front to back.
23097.jpgAlbum 23097
No feedback was used to control the fuel system. A carefully tuned carburetor was sufficient.
20905 CATALYST
20905-H7401
* JAPAN B211 A12.S,K 7512-
* JAPAN HB211 A14.S,K 7512-
* JAPAN GB211 L16 7602- (51 year standard)
* not used on Van
Unleaded Fuel
無鉛 Unleaded petrol only
B120
14807-89910 STICKER-FUEL 7510-
* placed on assistant's window
Buy at Bprojects
無鉛  無鉛ガソリンを
    ご使用下さい
B120
14806-89901 LABEL-UNLEADED FUEL ONLY 8910-
* placed inside fuel door
触媒 無鉛に限る Catalyst - Limited to Unleaded
B
1976 regulation including NOx
E
"E" 1978 emission standard (Showa 53 Year)
53年度排出ガス規制適合車
L
L - 1981 regulations
23169.jpgAlbum 23169
R
R - 昭和63 1988 regulations
25511.jpgAlbum 25511
14808-95W00 LABEL-EMISSION CONTROL,A 8910-
* placed under bonnet
Buy at Bprojects
26019.jpgAlbum 26019
