Gearbox Length
Revision as of 02:55, 21 January 2017; view current revision
Category: Transmission
When swapping gearboxes, know that many larger transmissions are the same length as the Datsun 1200 gearbox.
All 56-series and 60-series RWD transmissions are the same length. 4-speeds and 5-speeds are the same length. So they all use the same driveshaft.
FS5W63A and B110/B210 Automatic are slightly different length than 4-speeds. The driveshaft is 15mm longer than a 4-speed driveshaft.
FS5W63A from non-B210 may be different length. Per (ROConnor): "I hav here a 63A#1 dogleg 5-speed, and a 56A 4-speed that both measure 660mm from the mounting face to the end of the output shaft (so may be diferent 63A's?)"
For more details, see Gearbox Length
Short tail
Short tail total length: ~26.3"
See main article: Stumpy
  • 1977-1979 200SX USA S10 (L-series engine, FS5W63 "smoothcase" dogleg)
  • 1968-1973 PL510 (L-series engine, F4W63 "bottom pan")
  • 720 FS5W71B "ribbed case" used on certain 720 4X4s (long wheelbase?)
    • Z-engined series
    • may have had an L series in 1980 only
Long Tail
Long Tail total length: ~31.5"
F4W63 4-speed
  • 1965- 520/521 from '65 with J and L Engines
  • 1978-1981 HLA10 L and Z Engines
  • 1973-1975 610 L Engine
  • 1974-1977 710 L Engine
  • 7206-7309 620 L Engine
FS5W63 5-speed (dogleg)
  • 1979-1981 HLA10 optional L and Z series
F4W71A 4-speed
  • early 1970-1971 240Z
F4W71B 4-speed
  • 1973-1978 S30 240/260/280Z
  • 7310-1980 620 L Engine
  • 1978 -? 810 L Engine
  • 1980-1986.5 720 L and Z Engines
FS5W71B 5-speed
  • 1977-1979 620 L Engine
  • 1977-1983 280Z and 280ZX L Engine
  • 1978-1984 810/Maxima L Engine
  • 1980-1983 S110 (200SX) Z Engine
  • 1984-1986.5 S110 (200SX) CA Engine
  • 63 series: 1.6-2.0 liter engines
  • 71 series: 2.2 and larger engines
Extra Long
71C
