Carbon Canister
Revision as of 09:03, 26 June 2016; view current revision
Categories: Emission Control And Tune-Up | Fuel System
The Carbon Canister (Vapor Canister) was fitted first to 1975 USA B210 to capture fumes from the fuel tank. Instead of letting the fumes just to go the atmosphere. In the Canister is an activated charcoal filter. Later when the engine runs, fresh air is drawn through the filter and burned in the engine. Like all 1200s, the fuel tank Filler Cap is not vented. It seals the gas tank well, so that any fumes must go through the vent hose. In the case of EVAPO models, the tank is vented in the engine compartment through a steel Evaporative Fuel Line. Bottom line: makes your Sunny smell good!
Some late-model 1200s (as well as the B210 and B310 Sunny) used a carbon canister, which was fixed by a bracket, bolted to the left strut tower. This is what most modern automobiles use to contain and filter the fumes created by the fuel (evaporative emissions). Instead of a Flow Guide Valve, the fuel tank is vented via the carbon canister. A simple check valve is used (located near the fuel tank) to prevent backflow into the fuel tank.
  • Late-model Australian utes were also fitted with a carbon canister, as seen in this 1985 model:
  • All USA B210s, from 1975 onward, were fitted with a carbon canister.
  • Australian A15-powered B310 Wagon (all other Aussie B310s implemented a Flow Guide Valve).
This system does not make use of a Flow Guide Valve. Instead, when the engine is running, the fumes are drawn through the air cleaner. When the engine is not running, they are stored inside the canister, where they are then absorbed by the carbon. When the engine is started, the purge line draws air through the canister and into the engine, thus drawing the fumes into the engine.
Maintenance
The carbon filter should be replaced at the interval listed in your owner's manual (generally every 2 year or 40,000 km).
System Operation
The canister is bolted to the left strut tower (right side of this photo)
Fuel tank vents to the canister, like this through the Evaporative Fuel Line (tank vent line):
The 1.5-way check valve lets fresh air freely into the tank, but only a little of the fumes from the tank can go back into the engine compartment.
The canister has three lines like this:
  1. Purge line (to intake manifold)
  2. Control line (to Vacuum Advance port on the carburetor, Tee into the existing hose)
  3. Vent line to tank. Vent line includes the Fuel Check Valve (1.5-way valve)
16807.jpg 1980 B310 Canister
5-hose Canister
Most 1981 B310 models for North America used a DCH306 version 2.0 carburetor which has a vented fuel bowl.
This externally vented Fuel bowl is goes to a special 5-hose Canister. The canister has a Vent Switching Valve which is open when the engine is not running, so that vapors from the fuel bowl can go directly to the charcoal filter. When the engine starts, vacuum from the intake manifold closes the VSV and the fuel bowl vents as previous through the vent above the choke blade.
4th & 5th hoses
Fuel bowl vent line (large diameter)
Vacuum from intake manifold (small diameter)
Used by
* All USA models
* Canada MPG model
14950-50A21 EVAPORATION CANISTER ASSEMBLY [4-line]
JAPAN
* B120 8910- A12
* C23 "Vanette" GA16DE
14950-W5901 VAPOR CANISTER ASSEMBLY <> 14950-S3001 <> 14950-N5300/14950-N5301 $137 USD
* 1975-1978 B210 USA
* 1980 N10 "310" USA
JAPAN
* 8110-8404 B11.E15E
* 8205 N12.E15E
14950-H9160
* 1979-1980 B310 A14/A15 + A12.CAN
* 1979 N10
14950-H9500
* 1981-1982 B310
14950-M6660 <> 14950-H9911
* B310 A12.CAL
* N10 1980-1982 A14,A15,E15
* S12 "200SX" 1984- CA18ET
14950-H9900 [3-line]
* 1980 B310 "210" A12.FED
* 1983-1984 N12 "Pulsar" E15ET
JAPAN
* 8209-8404 B11.E15ET
* 8305- N12.E15T
Filter
14952-N5300 FILTER $8.50 USD
Luber-Liner AF63 $2 USD
JAPAN
* K10 "March", 910, B11,BK10,C120,C31,E23,M10,N12,PK10,S110,T11,U11
NORTH AMERICA
* B210
* B310 "210"
* 720/D21 Pickup
* B11/B12 Sentra
* KN13 Pulsar NX
* M10 Stanza Wagon
* N10/N12 310 Pulsar
* S110/S12/S13 200SX 240SX
* T11/T12 Stanza
Fram BA3865 $2 USD
* GM 07021743
  * 1989-1992 Century/Cutlass/6000/Celebrity 4-cylinder
14964-F1700 CAP [with single vacuum fitting]
* B210
* B310 "210"
* 720 "Pickup" except Z24
* N10 "310" A14/A15
* S110 "200SX"
* S130 "280Z" 1979
* T11 "Stanza"
14952-F1700 FILTER
SIX CYLINDER
* S30 "280Z"
* Z31/Z32 "300ZX"
* 910 "810/Maxima"
* S12 "200SX" VG30E
* U11 "Maxima"
AcDelco A478C
