<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Water Pump
Truck
WATER PUMP & FAN 1 21010-18027 PUMP ASS'Y-water, with gasket 21010-H1025 PUMP ASS'Y-water, with gasket > 21010-18027 21010-H5025 PUMP ASS'Y-water, with gasket (7211-8109) <*> 21010-H1025 * 08110-85010 (2 pcs),08213-84810 (3 pcs) とセットはにて新->旧に互瑍性おります。 21010-H7225 7804-8109 OP.COOLER <0,0> 21010-H7227 21010-H7227 8110- OP.COOLER 21010-M6626 8110- <0,2> 21010-H5025 2 21014-18000 GASKET-water pump cover to body side 21014-H1000 GASKET-WATER PUMP 7510- fixing water pump (from '72-11) 3 08911-10810 NUT 3 08911-1082A NUT 7510- 4 08110-84810 BOLT 2 08110-45010 BOLT 2 > 08110-84810 08120-83062 BOLT 7510- 5 08915-13810 WASHER-lock 5 09340-0010P WASHER-LOCK 8110- 6 21051-18000 PULLEY-fan and water pump -8910 21051-H7200 OP.COOLER 7804- 21051-H8500 9810- 7 11720N 11720-18002 BELT-fan 11720-77701 BELT-FAN & ALTERNATOR 7510-8503 L=980 <2,0> 11720-77702 11720-77702 8504- L=990 11720-H7200 OP.COOLER 7804-8109 L=970 Band <2,2> 11720-H7201 11720-H7201 OP.COOLER 8110- L=990 Band 11720-H7210 OP.COOLER 8504- L=975 Samsung 8 21060-H1001 BLADE-fan 21060-H1001 7510- 21060-N0110 FAN-COOLING OP.COOLER 7804-8109 <0,0> 21060-G1210 21060-G1210 FAN-COOLING OP.COOLER 8110- fixing fan blade to water pump 9 08120-62010 BOLT 4 10 21069-21000 WASHER-lock 2 21064-G1660 SPACER-FAN OP.COOLER 7804-7907 <0,0> 21064-G1615 21064-G1615 SPACER-FAN OP.COOLER 7908-
1 21010-18003 ASSY-PUMP WATER 1 21010-18026 ASSY-PUMP WATER WITH GASKET <> 21010-18003 1 21010-18027 ASSY-PUMP WATER WITH GASKET 0870-0871 <> 21010-18026 1 21010-H1025 ASSY-PUMP WATER WITH GASKET 0971-1072 <> 21010-18027 1 21010-H5025 ASSY-PUMP WATER WITH GASKET 1172- <> 21010-H1025 1 BA010-M6626 ASSY-PUMP WATER WITH GASKET 1172- <> 21010-H5025 2 21022-18003 VANE-WATER PUMP 3 21026-73000 ASSY-SEAL WATER PUMP 4 21027-73000 ASSY-SEAT 5 21035-13202 BEARING-WATER PUMP 6 21054-18000 HUB-WATER PUMP 7 21014-18000 GASKET-WATER PUMP COVER 8 08911-10810 NUT-HEX M8 FIXING WATER PUMP (3) 9 08110-84810 BOLT-HEX M8 FIXING WATER PUMP (2) 9 08110-85010 BOLT-HEX M8 FIXING WATER PUMP (2) 1172- <> 08110-84810 10 08915-13810 WASHER-LOCK FIXING WATER PUMP (5) 11 21051-18000 PULLEY-FAN & WATER PUMP 12 21060-H1001 FAN-COOLING 12 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA OP CRANK 12 21060-N0100 FAN-COOLING,FOR TROPICAL USE OP <> 21060-A4605 13 08120-62010 BOLT-HEX FIXING FAN (4) 14 21069-21000 WASHER-COCK FIXING FAN (2) 15 11720-18002 BELT-FAN L=838 A12 11720-G0300 BELT-FAN L=838 <> 11720-18002 1973 LB110 USA Parts Catalog
