<-- Back to Radio
The radio mounts in the center of the dashboard, and is covered by the Dash Fascia.
Stock Location
Alternate Mounting Locations
In center Console
DIN Chassis
Most modern stereos are DIN-mounted, requiring you to use an alternate mounting location, or cut the metal dash to fit it.
amplifiers, equalizers, CD players, etc
You have to cut out the metal around the radio to fit a modern DIN-chassis receiver.
Glove Box
If you prefer not to cut the sheet metal on the Instrument Panel, you can mount it in the Glove Box:
Console
Mounted in the console, some modification required:
Fitting
DIN-mount radios are the same size as the original, but do not have shafts in the front. Instead they attach at the sides of the radio.
First, cut out the facia. Cut out the metal around the radio to fit a modern DIN-chassis receiver:
Rectangle cut larger, radio shaft holes now missing
Fabricate a DIN adapter bracket (or modify a commercial one).
Create a bezel, by modifying the stock radio delete plamote:
Carefully cut the center out of the delete plate:
