GX Carburetor Part Numbers
Revision as of 05:14, 4 September 2017; view current revision
Categories: Fuel System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
A12GX Carburetor Part Numbers
1971
CARBURETOR (TWIN)
  16010-H2330 ASS'Y-CARBURETOR, twin, front GX
  16010-H2332 ASS'Y-CARBURETOR, twin, front (from '70-Jul.) GX < 16010-H2332
  16010-H2331 ASS'Y-CARBURETOR, twin, rear GX
  16010-H2333 ASS'Y-CARBURETOR, twin, rear (from '70-Jul.) GX < 16010-H2331
1 16122-H2310 ASS'Y-SHAFT, throttle GX
2 16324-H2310 ASS'Y-FILTER, piston GX
3 16144-H2310 ASS'Y-NUT, idle adjusting GX
4 16355-H2310 ASS'Y-NOZZLE GX
5 16127-H2310 ASS'Y-PLATE, throttle adjusting, front GX
5 16127-H2311 ASS'Y-PLATE, throttle adjusting, rear GX
6 16277-H2310 ASS'Y-LEVER, first idle, front GX
6 16277-H2312 ASS'Y-LEVER, first idle, front (from '70-Jul) GX < 16277-H2310
6 16277-H2311 ASS'Y-LEVER, first idle, rear GX
6 16277-H2313 ASS'Y-LEVER, first idle, rear (from '70-Jul) GX < 16277-H2311
8 16083-58000 SLEEVE 2 GX
9 16214-25610 NUT (8ø) 2 GX
9-1 16116-H2310 SLEEVE (from '71-May) 2 GX
10 16190-10401 SPRING-starter, return (B) GX
   16190-73410 SPRING-starter, return (A) GX
11 16147-14611 PLATE-cam (B) GX
   16147-73411 PLATE-cam (A) GX
12 16116-14610 SLEEVE (B) 2 GX
13 16157-14610 SPRING-connecting (B) GX
   16157-73410 SPRING-connecting (A) GX
   16238-H2310 ASS'Y-LEVER, choke, front GX
14 16238-H2311 ASS'Y-LEVER, choke, rear GX
   16147-H2310 PLATE-connecting, front GX
15 16147-H2311 PLATE-connecting, rear GX
   16227-H2310 ADAPTER-front GX
16 16227-H2311 ADAPTER-rear GX
17 16233-E3210 BOLT (8ø) 2 GX
18 16356-25610 PIPE-rubber, fuel 2 GX
19 16358-E4310 CLIP-fuel pipe 4 GX
20 16061-10400 FLOAT 2 GX
21 16101-H1000 ASS'Y-VALVE, needle 2 GX
22 16062-10400 LEVER-float 2 GX
23 16066-25610 SHAFT-float 2 GX
24 16331-10400 SCREW-nipple set 2 GX
25 16098-25710 FILTER 2 GX
26 16554-H2310 JET-needle 2 GX
27 16031-10560 PLUG-drain 2 GX
   16031-A8710 PLUG-drain 2 GX 2 16031-10560
   16418-H2310 CLAMP-choke, front GX
28 16419-H2310 CLAMP-choke, rear GX
29 16346-10615 SPRING-suction 2 GX
30 16341-25610 ASS'Y-NUT, oil cap 2 GX
31 16194-H2310 SPRING-throttle 2 GX
16455-H2310 SET-GASKET GX
A 16335-14610 PACKING (10ø) 4 GX
B GASKET-float chamber 2 GX
C WASHER (8ø) 2 GX
D PACKING (18ø) 2 GX
E WASHER (10ø) 2 GX
16475-H2310 SET-SCREW & WASHER "B" GX
F PACKING (12.5ø) 2 GX
G WASHER (7ø) 4 GX
H WASHER (5ø) 2 GX
  WASHER (4ø) 2 GX
I PING-cotter (1ø) 2 GX
J WASHER-thrust 2 GX
K BOLT (5ø) 2 GX
  BOLT (5ø) 2 GX
L WASHER-clock (7ø) 2 GX
M SET-screw, needle jet 2 GX
16465-H2310 SET-SCREW & LOCK WASHER "A" GX
N SCREW (5ø X 16) 16 GX
O SCREW (5ø X 12) 2 GX
  SCREW (4ø X 10) 2 GX
  SCREW (4ø X 8) 4 GX
P WASHER-lock (8ø) 4 GX
Q WASHER-lock (5ø) 18 GX
R WASHER-lock (4ø) 2 GX
