<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference: Starting Motor
1 23300-H6900 MOTOR-STARTER (HITACHI S11 A12 AUTO 0673- 2 23300-H3900 1 23300-H0100 MOTOR-STARTER (HITACHI S11 A12 1 23300-H0101 MOTOR-STARTER (HITACHI S11 A12 0170-0671 12 23300-H0100 1 23300-H0101 MOTOR-STARTER (HITACHI S11 A12,MANUAL 0771-0573 3 1 23300-H5000 MOTOR-STARTER (HITACHI S11 A12 0673- 1 23300-H3900 MOTOR-STARTER (HITACHI S11 A12,AUTO 0771-0573 32 23300-H0100 2 23310-H3900 ASSY-ARMATURE A12,AUTO 0771- 0 23310-19900 2 23310-19900 ASSY-ARMATURE A12,MANUAL 0771- 2 23310-19900 ASSY-ARMATURE A12 0170-0671 1 3 23321-09900 WASHER-THRUST 2 A12 0170- 4 23312-10600 ASSY-PINION A12 0170- 4 23312-10605 ASSY-PINION A12 2 23312-10600 4 23312-E3000 ASSY-PINION A12 2 23312-10605 5 23465-E6800 SET-STOPPER PINION A12 0170- 6 23383-10600 ASSY-BEARING CENTER A12 0170- 7 23441-10600 METAL-CENTER BEARING A12 0170- 8 23306-15801 ASSY-COIL FIELD A12,AUTO 0771- 0 23306-M0100 8 23306-M0100 ASSY-COIL FIELD A12 0170-0671 1 8 23306-M0100 ASSY-COIL FIELD A12,MANUAL 0771- 9 23305-09500 SCREW-POLE,CORE 4 A12 0170- 10 23337-18005 ASSY-COVER REAR A12 0170- 10 23337-H0100 ASSY-COVER,REAR A12, 0170-0671 1 10 23337-H0100 ASSY-COVER,REAR A12,MANUAL 0771- 10 23337-10605 ASSY-COVER,REAR A12,AUTO 0771- 0 23337-H0100 11 23338-09900 METAL-COVER REAR A12 0170- 12 23380-19900 BRUSH (+) A12 0170-0671 1 12 23380-19900 BRUSH (+) A12,MANUAL 0771- 12 23380-10600 BRUSH (+) A12,AUTO 0771- 0 23380-19900 13 23379-19900 BRUSH (-) A12 0170-0671 1 13 23379-19900 BRUSH (-) A12,MANUAL 0771- 13 23379-09900 BRUSH (-) A12,AUTO 0771- 0 23379-19900 14 23333-09900 SPRING-BRUSH 2 A12,AUTO 0771- 0 23333-21001 14 23333-09900 SPRING-BRUSH 2 A12 0170- 14 23333-21001 SPRING-BRUSH 2 A12 0170-0671 12 23333-09900 14 23333-21001 SPRING-BRUSH 2 A12,MANUAL 0771- 15 23340-15805 BOLT-THROUGH 2 A12,AUTO 0771- 0 23340-18005 15 23340-18005 BOLT-THROUGH 2 A12 0170-0671 1 15 23340-18005 BOLT-THROUGH 2 A12,MANUAL 0771- 16 23318-H0100 ASSY-GEAR CASE A12 0170- 17 23319-10600 METAL-GEAR CASE A12 0170- 18 23322-M0100 SET-LEVER SHIFT A12 0170- 19 23309-H5000 ASSY-COVER BRUSH A12 0673- 0 23309-19905 19 23309-18005 ASSY-COVER BRUSH A12 0170-0671 1 19 23309-18005 ASSY-COVER BRUSH A12,MANUAL 0771-0573 3 19 23309-19905 ASSY-COVER BRUSH A12,AUTO 0771-0573 30 23309-18005 20 23343-18005 ASSY-SWITCH MAGNETIC A12 0170- 21 23470-M0100 SET-DUST COVER A12 0170- 22 23390-18005 BOLT M5 2 A12 0170- 23 23480-M0100 SET-SCREW A12 0170-
