Rear Seat Part Numbers
Revision as of 10:46, 27 October 2021; view current revision
Categories: Body | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Rear Seat
Coupe Tonneau Cover
REAR SEAT (SEDAN) (exc. GL, GX)
* C-173 page 100-2 1971.11
4 88320-H1000 ASS'Y-TRIM, rear seat cushion (黒 black) S-Std
5 88320-H1100 ASS'Y-TRIM, rear seat cushion (緑 green) S-Dx.
  88320-H1102 ASS'Y-TRIM, rear seat cushion (黒 black) S-Dx.
6 88320-H1101 ASS'Y-TRIM, rear seat cushion (灰 grey) S-Dx.
  88320-H1103 ASS'Y-TRIM, rear seat cushion (黄 yellow) S-Dx.
Sedan
1 88300-H1001 ASSY-CUSHION REAR SEAT (BLACK) SEDAN 1271-0672
1 88300-H1113 ASSY-CUSHION REAR SEAT (YELLOW) SEDAN 1270-0672
1 88300-H1111 ASSY-CUSHION REAR SEAT (GRAY) SEDAN 0670-1170
1 88300-H7001 ASSY-CUSHION REAR SEAT (BEIGE) SEDAN 0772-
1 88300-H1101 ASSY-CUSHION REAR SEAT (GRAY) SEDAN 0170-0570
1 88300-H1112 ASSY-CUSHION REAR SEAT (BLACK) SEDAN 0670-1171
1 88300-H1102 ASSY-CUSHION REAR SEAT (BLACK) SEDAN 0170-0570
1 88300-H7002 ASSY-CUSHION REAR SEAT (BLACK) SEDAN 0173-
1 88300-H7000 ASSY-CUSHION REAR SEAT (BLUE) SEDAN 0772-
2 88600-H1103 ASSY-BACK REAR SEAT (YELLOW) SEDAN 1270-0672
2 88600-H7001 ASSY-BACK REAR SEAT (BEIGE) SEDAN 0772-
2 88600-H1101 ASSY-BACK REAR SEAT (GRAY) SEDAN 0170-1170
2 88600-H7002 ASSY-BACK REAR SEAT (BLACK) SEDAN 0173-
2 88600-H7000 ASSY-BACK REAR SEAT (BLUE) SEDAN 0772-
2 88600-H1000 ASSY-BACK REAR SEAT (BLACK) SEDAN 1271-0672
2 88600-H1102 ASSY-BACK REAR SEAT (BLACK) SEDAN 0170-1171
3 88320-H1000 TRIM-CUSHION REAR SEAT (BLACK) SEDAN 1271-0672
3 88320-H7000 TRIM-CUSHION REAR SEAT (BLUE) SEDAN 0772-
3 88320-H7002 TRIM-CUSHION REAR SEAT (BLACK) SEDAN 0173-
3 88320-H1101 TRIM-CUSHION REAR SEAT (GRAY) SEDAN 0170-1170
3 88320-H1103 TRIM-CUSHION REAR SEAT (YELLOW) SEDAN 1270-0672
3 88320-H7001 TRIM-CUSHION REAR SEAT (BEIGE) SEDAN 0772-
3 88320-H1102 TRIM-CUSHION REAR SEAT (BLACK) SEDAN 0170-1171
4 88620-H1101 TRIM-BACK REAR SEAT (GRAY) SEDAN 0170-1170
4 88620-H7002 TRIM-BACK REAR SEAT (BLACK) SEDAN 0173-
4 88620-H1103 TRIM-BACK REAR SEAT (YELLOW) SEDAN
4 88620-H1000 TRIM-BACK REAR SEAT (BLACK) SEDAN 1271-0672
4 88620-H1102 TRIM-BACK REAR SEAT (BLACK) SEDAN 0170-1171
4 88620-H7000 TRIM-BACK REAR SEAT (BLUE) SEDAN 0772-
4 88620-H7001 TRIM-BACK REAR SEAT (BEIGE) SEDAN 0772-
5 08340-61610 SCREW-MACHINE FIXING SEAT BACK (2) SEDAN
6 08915-53610 WASHER-PLAIN FIXING SEAT BACK (2) SEDAN
Coupe
Rear Seat
1 88300-H1803 ASSY-CUSHION REAR SEAT (YELLOW) OP COUPE 1270- 2 87500-H1602
1 88300-H7100 ASSY-CUSHION REAR SEAT (BLUE) COUPE 0772- 2 87550-H1602
1 88300-H7101 ASSY-CUSHION REAR SEAT (BEIGE) COUPE 0772-
1 88300-H7102 ASSY-CUSHION REAR SEAT (BLACK) COUPE 0173-
1 88300-H1802 ASSY-CUSHION REAR SEAT (BLACK) COUPE
2 88600-H1802 ASSY-BACK REAR SEAT (BLACK) COUPE
2 88600-H1803 ASSY-BACK REAR SEAT (YELLOW) OP COUPE 1270-
2 88600-H7100 ASSY-BACK REAR SEAT (BLUE) COUPE 0772-
2 88600-H7101 ASSY-BACK REAR SEAT (BEIG) COUPE 0772-
2 88600-H7102 ASSY-BACK REAR SEAT (BLACK) COUPE 0173-
3 88631-H7100 PANEL-SEAT BACK COUPE 0772- 2 88631-H1800
3 88631-H7101 PANEL-SEAT BACK COUPE 0173- 2 87401-H1001
3 88631-H1800 PANEL-SEAT BACK COUPE
3 88631-H7102 PANEL-SEAT BACK COUPE 0173-
4 H8612-H1400 ASSY-HANDLE REAR SEAT BACK COUPE
5 H8619-H1400 WASHER-HANDLE COUPE
6 H8613-H1400 WASHER-NYLON COUPE
7 H8614-H1400 PIN-LOCK (2) COUPE
8 H8615-H1400 SPRING-LOCK (2) COUPE
9 H8617-H1400 RUBBER-BUMPER (2) COUPE
10 H8618-H1400 WIRE-RELEASE (2) COUPE
11 88320-H7102 TRIM-CUSHION REAR SEAT (BLACK) COUPE 0173-
11 88320-H1802 TRIM-CUSHION REAR SEAT (BLACK) COUPE
11 88320-H1803 TRIM-CUSHION REAR SEAT (YELLOW) OP COUPE 1270-
11 88320-H7100 TRIM-CUSHION REAR SEAT (BLUE) COUPE 0772-
11 88320-H7101 TRIM-CUSHION REAR SEAT (BEIGE) COUPE 0772-
12 88620-H1802 TRIM-BACK REAR SEAT (BLACK) COUPE
12 88620-H1803 TRIM-BACK REAR SEAT (YELLOW) OP COUPE 1270-
12 88620-H7100 TRIM-BACK REAR SEAT (BLUE) COUPE 0772- 2 87550-H1602
12 88620-H7101 TRIM-BACK REAR SEAT (BEIGE) COUPE 0772-
12 88620-H7102 TRIM-BACK REAR SEAT (BLACK) COUPE 0173-
13 88641-H1400 CATCHER-BACK REAR SEAT RH COUPE
13 88641-H1900 CATCHER-BACK REAR SEAT RH COUPE 4 88641-H1400
14 88642-H1400 CATCHER-BACK REAR SEAT LH COUPE
14 88642-H1900 CATCHER-BACK REAR SEAT LH COUPE 4 88642-H1400
15 88643-H1800 SHIM-CATCHER REAR SEAT BACK (0) COUPE
15 88643-H1900 SHIM-CATCHER REAR SEAT BACK (2) COUPE 4 88643-H1800
16 08310-61212 SCREW-MACHINE M5X0.8 (4) COUPE
17 08915-13810 WASHER-SPRING LOCK (4) COUPE
18 08310-81210 SCREW-MACHINE M5X0.8 (4) COUPE
19 88606-H1800 ASSY-HINGE REAR SEAT BACK (2) COUPE
20 08320-61012 SCREW-MACHINE M6X1.0 (4) COUPE
21 08510-41040 SCREW-TAPPING M4 1 (16) COUPE
22 08915-43540 WASHER-PLAIN M5 1 (16) COUPE
22 88653-H1800 WASHER-PLAIN M5 1 (16) COUPE 2 08915-43540
Tonneau Cover
23 84950-H1825 SET-COVER,TONNEAU OP.COUPE 0672- 2 84950-H1800
24 84950-H1800 ASSY-COVER,TONNEAU OP.COUPE 1169-
25 84951-H1800 HOOK-COVER (2) OP.COUPE 1169-
26 74933-30000 FASTNER (7) OP.COUPE 1169-
27 08510-61242 SCREW TO FIX HOOK (2) OP.COUPE 1169-
28 08520-41612 SCREW TO FIX FASTENER (7) OP.COUPE 1169-
