<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
1 48400-H1101 ASSY-WHEEL STEERING EXC OKINAWA 1 48400-H6101 ASSY-WHEEL STEERING 48400-H1101 2 48429-H1010 ASSY-RING SLIP OP SEDAN COUPE 3 48422-H1110 ASSY-PAD WHEEL EXC OKINAWA 4 48432-H1010 BUTTON-HORN(L) 5 48432-H1011 BUTTON-HORN(P) 6 48424-H1010 SPRING-HORN (2) 7 48464-H1010 RING-INSULATOR (2) 8 48498-H1100 EMBLEM 'D' MARK EXC OKINAWA 9 48435-H1010 GUIDE-HORN BUTTON (2) 10 08911-34210 NUT-HEX 12 11 08916-24210 WASHER-TOOTH 12 12 Template:RefMe SET-SHELL STEERING WITHOUT PARK LIGHT S 4 SPEED 48471-H1650 12 48470-H4650 SET-SHELL STEERING WITHOUT PARK LIGHT S EXC OKINAWA 0172- 2 48471-H1950 12 48471-H1650 SET-SHELL STEERING 4 SPEED AUTO. 13 08530-42012 SCREW-TAPPING M4 (3) 14 08330-41410 SCREW-MACHINE M4 15 48700-H1900 ASSY-LOCK STEERING 15 48700-H1901 ASSY-LOCK,STEERING(5 POINT) 0471- 0 48700-H1900 16 48750-H1900 ASSY-SWITCH IGNITION 16 48750-E7705 ASSY-SWITCH IGNITION (5 POINT) 0471- 0 48750-H1900 17 48760-H1900 SWITCH-WARNING DOOR BUZZER 17 48700-H1900 SWITCH-WARNING DOOR BUZZER 2 48760-H1900 18 24814-H1900 ASSY-BUZZER DOOR CHECK 18 24814-H1901 ASSY-BUZZER DOOR CHECK 4 24814-H1900 18 24814-H1902 ASSY-BUZZER,DOOR CHECK 0370- 2 24814-H1901 19 48780-H1900 BRACKET-BUZZER 20 08510-51012 SCREW TO FIX BUZZER TO BRACKET (2)
