Coolant
Revision as of 23:11, 1 November 2008; view current revision
Category: Cooling System
The Radiator Coolant keeps the engine from overheating, and prevent it from freezing. So it is also known as anti-freeze (antifreeze). Straight water can be used, but is subject to rust and to freezing, and non-distilled water can cause particle build up in the cooling system.
Fill the radiator with a distilled water in a 50/50 mix of coolant/antifreeze. If you live in freezing areas, check the coolant container for instructions (which may require a 30/70 mix in very cold areas).
  • Water capacity: 4.9 liter (5-3/16 US quart, 4-5/16 imperial qt)
Many of these brands listed below have changed names. Any modern antifreeze/coolant that is compatible with aluminum parts should be acceptable. The Datsun 1200 uses an aluminum head and water pump.
Antifreeze/Coolant for radiator
USA 1972 Owners manual (see page 23 for details): 23.jpg
Antifreeze/Coolant Specifications
Recommended:
  • Producing: Antifreeze coolant L.L.C. (Nissan "Long Life Coolant")
  • Shell Shellzone
Acceptable:
  • Chevron Atlas Perma Guard antifreeze
  • ESSO Long Life Coolant
  • ESSO Atlas Long Life Coolant RAD
  • Mobile Permazone
  • Sunoco Permanent Type
  • Texaco Antifreeze Coolant
  • Texaco Startex Antifreeze Coolant
