B310 Dash
Revision as of 21:22, 25 June 2024; view current revision
Category: Datsun B310
Datsun B310 dashboard had round gauges, and later changed for 80s fashion.
Early: Individual pods for gauges of instrument panel
Late: Single large opening for instrument panel
Early Style for all Round Headlight models (1977-1979)
29579.jpgAlbum 29579
Late Style for Square Headlight models (1980-1982)
Early
All round headlight models used a wide driver's "cockpit" that encompassed the radio and center vents. This was 1977-1980.5 + all JDM VB310 van.
#2+4 dash: Two large central gauges flanked by four small
#2+2 dash: Two large central gauges flanked by two medium
LHD used a 2+2 dash for all models.
2+4 Gauge Cluster
Coupe GXE with tachometer
174_65ad3c910f165.jpgPost 498201
Left flank:
         Oil Pressure
         Fuel (Coupe GX)
Large Center Gauges
* Left: Speedometer
* Right is one of:
         Water/Fuel (sedan)
         Blank with idiot lamps
         Econometer (Coupe A14.GL)
         Tachometer (Coupe GX)
Right flank:
  Upper: Volt/Amp (coupe GX)
  Lower: Water Temperature
GXE - 2+4
SGX - 2+4
2+2 Gauge Cluster
#Van - 2+2
LHD used a 2+2 "flat" dash for all models
Medium Left is one of:
         Water/Fuel (sedan)
         Econometer (coupe A14.GL)
         Tachometer (coupe GX)
Large Center Gauges
Medium Right:
         Water/Fuel with idiot lights (oil/brake)
NOTE: LHD has the two side pods reversed
GL - 2+2
See: #Cluster Lid
Europe
Malta
16083.jpgAlbum 16083
Datsun 140Y wagon - Romania
7023.jpgAlbum 7023
Japan California
Sunny California (wagon)
0205239A30150423W00113.jpg 0205239A30150423W00114.jpg 0205239A30150423W00115.jpg
SGL
SGL grille with digital clock
174_5d81708783f53.jpgPost 492627 174_5d81708783f53.jpgPost 492627
Taiwan
Yulon#302
174_5c0b7264d0a82.jpgPost 490113
Van
Australia
20461.jpgAlbum 20461 20462.jpgAlbum 20462 20460.jpgAlbum 20460 20459.jpgAlbum 20459 20458.jpgAlbum 20458
USA Coupe
20121107_131954_DSC04458.jpg 20121107_132103_DSC04468.jpg 20121107_132031_DSC04463.jpg 20121107_132057_DSC04467.jpg 20121107_132045_DSC04465.jpg 20121107_132051_DSC04466.jpg 20121107_132305_DSC04472.jpg 20121107_132027_DSC04462.jpg
USA Sedan
large speedometer flanked by OPTION tachometer
To left of speedometer is smaller temp/water gauge
Small left side round pod is Clock Blank
Tachometer blank with idiot lamps (Oil/Amps)
Datsun-B210-46.jpg Datsun-B210-48.jpg Datsun-B210-49.jpg Datsun-B210-50.jpg Datsun-B210-54.jpg
10761.jpgAlbum 10761
Tachometer
Tachometer Yellow Zone
* Carburetor 6000-6250
* EGI        6400-6800
GX-E
TACHOMETER ASSY
24855-H8700 *K.(DX+GL) -7811
24855-H8701 *K.(DX+GL) 7812- CLEAR LAMP
24855-H9200 (S+K).GX
24855-H9201 (S+K).A14E
Clock
Clock is analog or digital.
LHD: Clock on right side of cluster
RHD: Clock on left side of cluster
GX:  Clock in center stack (above radio)
2+4 dash: CENTER STACK CLOCK, sealed shield
2+2 dash: left-side CLUSTER CLOCK, clear shield
GX,DX,GL analog
SGL, SGX digital
2+4 SGL SGX
SGL and SGX trims use a 2+4 gauge cluster with full engine gauges, so there is no room for clock. In these models the clock in located in the center stack, above the radio towards the center of the car.
Analog SGL
Digital SGX
CLOCK K,S.SGX
27380-H9210 DIGITAL QUARTZ LUMINOUS SPORT INST -7804
27380-H9211 DIGITAL QUARTZ LUMINOUS SPORT INST -7805-7909
SGX for dash center stack 27380-H9211
29576.jpgAlbum 29576
4-pin connector (analog version uses 3-pin connector)
29577.jpgAlbum 29577 29578.jpgAlbum 29578
Digital 2+2 GX DX GL
RHD: Left Clock (digital)
174_667b1b0a10daf.jpgPost 498532 174_667b1b1bb1c06.jpgPost 498532
Analog 2+2 GX DX GL
RHD: Left Clock (analog)
Econometer
サニーエコノモニター
サニーエコノメーター
Econometer (per Datsun catalog) was called Economonitor in Australia and ECONO MONITOR エコノモニター in Japan while the B210 version was called Econo Meter/エコノメーター.
In operation, a green light appears at low throttle openings, and a red light at heavy throttle. It is of course a type of vacuum gauge. Does it work to enhance fuel economy? Yes. By keeping acceleration light, the driver can achieve fuel savings up to 30%. And yet you still have maximum power available, should you decide to put your foot down and throw economy to the wind.
24895-H9000 ECONOMONITOR ASSY GL,SGL -7811 [large type]
24895-H9010 ECONOMONITOR ASSY GL,SGL 7812-7909 [small type]
H9010 ECONO MONITOR Japan in GL dash small gauge on right side along with EXH TEMP and BRAKE lamps
174_5c10d1413b248.jpgPost 490146 174_667b1b283292b.jpgPost 498532
H9000 Round dash early -7811 with lights for OIL and CHG. The tubes on the back are for the bulbs
29594.jpgAlbum 29594 29595.jpgAlbum 29595
Warning Lamp Assembly
Warning Lamp grid of four or six lamps is adjacent to the door.
LHD: grid on left side of dash
RHD: grid on right side of dash
rectangular grid cluster
variations
FUEL DOOR
BRAKE TEMP
BRAKE TEMP FUEL DOOR
FUEL DOOR TAIL STOP
BRAKE TEMP FUEL DOOR TAIL STOP
SGX: all six icons
26597 LAMP ASSY-EXHAUST TEMPERATURE
25040-H8700 BRAKE
      H8760 BRAKE FUEL DOOR TAIL STOP
      H9200 BRAKE FUEL DOOR
26599 LAMP ASSY-WARNING FUEL
25040-H8560 DOOR TAIL STOP
      H8561 DOOR
Late
1980-1982 switched to a smaller driver's "cockpit" that included just the instrument panel -- the radio and center vents were outside of this area. Japan vans stayed with the early style.
H85 single side gauges
    Speedometer + Idiot Lamps S,W except SGX
    Speedometer + Tachometer Coupe except SGX
H92 double side gauges S,K.SGX
2+4 cluster SGX
2+2 cluster Wagon/Sedan (except SGX)
210 (North America) 1982 2 large gauge + 2 small gauge with blanking plate
174_634fbc1c24f96.jpgPost 497226
GL steering wheel 1981 210
Yulon 303
Sedan/Wagon
SEDAN/WAGON GAUGES (except SGX)
  Round or Digital Clock (or 'NISSAN' clock mask)
Speedometer
Large Fuel/Temperature
 Idiot Lamp
NO tachometer option
Idiot Lamps (Large Fuel/Temperature)
* 'CHG' with BATTERY symbol
* OIL symbol
Idiot Lamp (Small pod) two variations
* H85 S,W.GL#,DX# BRAKE
or
* H92 S.GX CHG
2x2 cluster (2 large, 2 small)
With Digital Clock
With Analog Clock
29593.jpgAlbum 29593
174_634fbc3eee7c2.jpgPost 497226 174_634fbc4962747.jpgPost 497226 174_634fbc5a2bceb.jpgPost 497226
With choke and brake lamps
Coupe
COUPE GAUGES (except SGX)
 Round Clock (or 'NISSAN' clock mask)
Speedometer
Tachometer
 Small Fuel/Temperature
Idiot Lamp BATTERY (bottom of tachometer)
digital clock | analog clock
SGX
SGX/SGX-E GAUGES
 Digital Quartz Clock
 Fuel
Speedometer (160kph)
Tachometer
 Oil Pressure
 Water Temperature
Idiot Lamp BATTERY symbol (bottom of tachometer)
MASKED: Idiot Lamp Meter strip (bottom of cluster)
SGX-E 6800 RPM tachometer for EGI
Monitor Lamp Strip
Six variations, including two blank strips.
Masks are placed at bottom of cluster (where photo is labeled "Delete Plate")
Inspection Monitor Lamp strip 25040-H8563?
SGX with full Monitor Lamps (all six icons)
68450-H8501 MASK 7910- CT,S.DX,SPT,ES+W.DX, SGX
25040-xxxxx LAMP ASSY [six variations]
      H8500 EXH TEMP,BRAKE,FUEL
      H8562 FUEL,DOOR
      H8761 EXH TEMP,BRAKE,FUEL,DOOR,TAIL,STOP
      H9201 EXH TEMP,BRAKE,FUEL,DOOR
      H8563 FUEL,DOOR,TAIL,STOP
      H8611 CT/DX [blank]
      H8761 SGX [blank]
      USA   BRAKE
Tachometer
All Coupe and Sedan.SGX get a tachometer. There is no room for tachometer on Wagon, Van or regular Sedan dash.
H90 dual idiot lights at bottom
H92 single idiot light at bottom
TACHOMETER ASSY
24855-H9020 K-(K.SGX#,K.RSE),W.GX
24855-H9021 K.RSE,S.GXE
24855-H9215 (4S+K).SGX  [std redline]
24855-H9216 (4S+K).SGXE [EFI redline]
LENS 68435
25021-H9020 K-SGX# S.(GX#+SGL) OIL,BATTERY
25026-H8503 S,W.GL#,DX. BRAKE
25026-H9215 S.GX        CHG
Custom
11136.jpgAlbum 11136
Cluster Lid
Early - individal gauge lenses
Late  - one big opening for all gauges
H850 DX
H851 Late Model
H856 GL
H86  CITY + DX.WAGON
H92  GX
H94  Van STD late
CLUSTER LID
68420-H8500 DX BLACK
68420-H8501 DX BROWN
68420-H8510 7910- BLACK
68420-H8511 7910- BROWN
68420-H8560 GL BLACK
68420-H8561 GL BROWN
68420-H8600 CT BLACK W.DX
68420-H8601 CT BROWN W.DX
68420-H9200 GX# BLACK
68420-H9201 GX# BROWN
68420-H9400 BROWN
            7812- V.STD
            8011- V.A12.STD
            8110- V.A12.DXA
68420-H9460 8011- BLACK V.A12.STD,DXA
NOTE: DXA was a trim only available with 2-seat Van (VB312R)
H94
