L-series Engine Components
Revision as of 01:41, 2 September 2025; view current revision
Categories: Engine Modifications | Engine Swaps | Nissan Engines
<-- back to L-series Engine Swap
Datsun L-series four-cylinder engine major components
Intake Manifold
Nissan Violet
Datsun Bluebird
Single Carb
  • 14002-A8901 MANIFOLD ASS'Y-intake L14S.V 710 [1980.05 catalog]
  • 14002-A8903 MANIFOLD ASS'Y-intake L14S.V F/COLD 710 [1980.05 catalog]
    • 14035-U0101 GASKET-manifold L14S.V 710
  • 14002-A8925 MANIFOLD ASS'Y-intake L14,L16S 710 [1974.2 catalog]
  • 14002-A3419 MANIFOLD ASS'Y-intake LPG 710 [1974.2 catalog]
    • 14035-U0101 GASKET-manifold L14, L16S 710
  • 14004-A3500 MANIFOLD-exhaust L14, L16S 710 [dual outlet]
    • 20711-A0800 GASKET-exhaust tube 710
  • 14004-U9500 MANIFOLD-exhaust L14S.V 710
Twin Carb
Datsun Bluebird 510:
Datsun Bluebird 610:
Nissan 710: 1973-1975 only (L16T SSS)
Datsun Bluebird 910: Europe
510 SSS, CSS
  • 14002-22026 MANIFOLD ASS'Y-intake L16T, L18T 510
    • 14035-U2800 GASKET-manifold L16T, L18T
      • replaced 14035-23000 GASKET-manifold L16T, L18T
  • 14004-A3500 MANIFOLD-exhaust L16T, L18T
    • 20711-A0800 GASKET-exhaust tube 510 ALL
610 SSS
  • 14002-22026 MANIFOLD ASS'Y-intake L16T, L18T 610
  • 14002-K1425 MANIFOLD ASS'Y-intake (from '73-4) L16T, L18T 610
    • 14035-U2800 GASKET-manifold L16T, L18T (from '72-11)
  • 14004-A3500 MANIFOLD-exhaust L16T, L18T 610 [dual outlet]
  • 14004-U9500 MANIFOLD-exhaust L16T, L18T (from '75-7) 610 [dual outlet]
    • 20711-A0800 GASKET-exhaust tube 610 ALL
710 SSS
  • 14002-K1425 MANIFOLD ASS'Y-intake L16T 710 [1974.2 catalog]
  • 14004-A3500 MANIFOLD-exhaust L16T 710 [dual outlet]
910 Bluebird SSS (Europe, 0180-1283)
14002-K1412 MANIFOLD-INTAKE L18T
* 14035-U2800 GASKET-MANIFOLD <> 14035-U2810
14004-U9501 MANIFOLD-EXHAUST
* Same as L16S, L18S and 720.L18
Weber
Datrally1200 twin-DCOE manifold
20767_56fa3dd9bbd31.jpgPost 477820 20767_56fa3dee54502.jpgPost click for topic 20767_56fa3e02bbbf1.jpgPost click for topic
EGI
  • 14002-N6950 MANIFOLD ASS'Y-intake L16E 710 EGI -7601 [1980.05 catalog]
  • 14002-U7652 MANIFOLD ASS'Y-intake L16E 710 EGI 7601- [1980.05 catalog]
    • 14035-N6900 GASKET-manifold L16E 710 [1980.05 catalog]
  • 14002-N1400 MANIFOLD ASS'Y-intake L16E P710FE, P710WFE (SSS) EGI [1974.2 catalog]
  • 14002-N1400 MANIFOLD ASS'Y-intake KP610TE (SSS) EGI [1974.2 catalog]
  • 14002-N1400 MANIFOLD ASS'Y-intake L16E, L18E 610 EGI [1975 catalog]
    • 14035-N1401 GASKET-manifold L16E 710 [1974.2 catalog]
  • 14004-N6901 MANIFOLD-exhaust L16E 710 -7601 [dual outlet] [1980.05 catalog]
  • 14004-U7600 MANIFOLD-exhaust L16E 710 7602- [dual outlet] [1980.05 catalog]
  • 14004-N5800 MANIFOLD-exhaust L18P 710 7602- [dual outlet] [1980.05 catalog]
  • 14004-N7000 MANIFOLD-exhaust L18P 710 -7512 [dual outlet] [1980.05 catalog]
  • 14004-N7001 MANIFOLD-exhaust L18P 710 7601-7703 [dual outlet] [1980.05 catalog]
Exhaust Manifold
  • N58 exhaust ports are round (L18P Japan, 1978-1980 North America)
  • All others are square
  • A square manifold will work on a round port head (barely) better than the other way around.
  • Some late manifolds are 4 into 1 with a single large round connection to the down pipe
  • Most others are 4 into 2, with two outlets into a twin-pipe down pipe
Standard L16/L18 cast iron extractor is 4-into-2 and have an exhaust shop make up a 2-into-1 exhaust pipe, tuned to whatever RPM length you want to rev your engine.
  • fits 1200
  • lasts forever
  • no exhaust leaks
  • quiet
174_570dcf4068d57.jpgPost 478208
Downpipes need to be custom-made to fit Sunny
dual-outlet gasket 20691-A0880
PB110 L14
14035-U0101 GASKET > 14035-U0101 > 14035-21000
510 Japan
14053-21000 L13/L14S/L16S [small inlet port]
14053-U0101 L14S/L16S [small inlet port] > 14053-U0101
14053-28000 L16T/L18T [large inlet port] > 14004-23000
14004-21000 L13 early
14004-A3500 L13/L14S/L16S + L16T/L18T
610 JAPAN
* all square port
14035-U0101 L16S/L18S > 14035-U0100
14035-U2800 L16T/L18T > 14035-U2300
14035-N1401 L16E/L18E [single top bolt, notched] > 14035-N1400
14004-A3500 <> 14004-U9500 [Dual-outlet, divorced]
810 JAPAN
14004-W0300 L18P -7611
14004-N5800 L18P 7612-7901
14004-U7600 L18E   [dual outlet, divorced]
14004-U9500 L16S.V [dual outlet, divorced]
14004-U9656 L16S.S,K+L18S [single outlet, heat riser]
14035 MANIFOLD GASKET TO CYLINDER HEAD
14035-U0101 L16S.V -7709
14035-U0105 L16S.V 7710- > 14035-U0105
14035-U6700 L16S.S,K+L18S 7709-
14035-W5300 L16S.S,K+L18S 7710-
14035-U6700 L18P -7611
14035-N5800 L18P 7612-7702
14035-W5800 L18P 7703-
14035-N6900 L18E
A10 JAPAN
* all square port
14035-N6900 L16E [notched]
14035-U6700 L16S -7709
14035-W5300 L16S 7710-7803
14004-W5500 L16E [dual-outlet, divorced]
14004-U9655 L16S [single-outlet, heat riser]
720 USA
14004-N5800 round port, air injection, single outlet
14035-W5800 round port > 14035-W5801
N58 round port
* L18P
* late L20B USA
L20B USA with air injection
1975-1977 U67 head square ports Heat Riser type
1978-1980 W58 head round ports divorced type
N58 L20B USA late
L20B USA early (square port with air injection)
A26 manifold
230 manifold
A21 with EGR port
Manifold Gasket
#W58 Round exhaust ports
Square Exhaust port
* small round intake port
  Nissan U01
  Nissan U28
* large round intake port
  Nissan U67
  Nissan W53
#U01/210/K07 Square exhaust ports (small round intake port)
#W53/U67 Square exhaust ports (large round intake port)
#U28 Square exhaust ports SPECIAL (large round intake port)
EFI Notched intake port
* Nissan 14035-N6900
* Nissan 14035-N1401
* Cherry S8354K (14035-N1401)
N14 early EFI with notched intake ports for L16E and L18E engines
14035-U0115
14035-U0115/14035-U0105/14035-U0101/14035-U0100
Replaces 14035-21000
         14035-K0700
Victor Reinz MS15241
 * Nissan 14035-U0100/14035-U0101/14035-U0105/14035-U0115
 * Nissan 14035-U2800/14035-U2810
14035-U2800
Version of U01 with large intake ports
14035-U2810 GASKET-MANIFOLD <> 14035-U2800
* 910 Bluebird SSS (Europe, 0180-1283)
* Nismo
14035-W5300
A4035-W5301/14035-W5301/14035-W5300 MANIFOLD GASKET
replaces: 14035-U6700
Fel-Pro MS226931
14035-W5800
W58 Round Exhaust Port
* JDM L18P
* USA L20B 1978-1980
14035-W5801/14035-W5800 MANIFOLD GASKET
* Fel-Pro MS22801
Round exhaust ports
Cylinder Head
Head Gasket
GASKET-CYLINDER HEAD
* small bore
* big bore
Camshaft
Japan Market
  • 13001-21000 CAMSHAFT L13, L16 510 1967-1970, L14 510 1971, L14 710
  • 13001-21000 CAMSHAFT L16 510 1969, L14S B110
  • 13001-21010 CAMSHAFT L14S B210 [early], L16S 710
  • 13001-H2700 CAMSHAFT L16S 510 1972, L14T B110, L16S B210, L16S 710 1976-, L16S 610, L18S 610, L16S 810.V.MT 7808-, L18S 810 -7807, L16S 810 -7807, L16 A10
  • 13001-H2710 CAMSHAFT L14T B210, L18S 610
  • 13001-N7200 CAMSHAFT L14S 710 1976-
  • 13001-23000 CAMSHAFT L16 510 1971, L16(LPG) 1972, L16(LPG) 710, L18P 710, L18P 810
  • 13001-22000 CAMSHAFT SSS, CSS [L16T] 510 1969-, L16T 710, L16E 710, L16T 610, L18T 610, L16E 610 [late], L18E 610 [late], L18E 810
  • 13001-U4210 CAMSHAFT L16E 610 [early], L18E 610 [early]
  • 13001-E3001 CAMSHAFT L20AS 810 -7702
  • 13001-E3082 CAMSHAFT L20AS 810 7703-
  • 13001-P3000 L20AE 810 -7702
  • 13001-P3081 L20AE 810 7703-
  • 13001-U8680 L16S.V.AT 810 7710-
North America Catalog
  • 13001-21000 CAMSHAFT L13 510
  • 13001-23000 CAMSHAFT -0571 521, 620 -0872, L16 510
  • 13001-H2700 CAMSHAFT 521 [late], L16 510
  • supercedes 13001-H2710 CAMSHAFT 0671- 521, L16 510
  • 13001-U2010 CAMSHAFT L16 620 0972-, L18 710, L18 610
  • 13001-U2000 CAMSHAFT L16 620 0972-, L18 710, L18 610
  • 13001-22000 CAMSHAFT L18 620, L20B 620, L20B A10, L20B 710, L20B 610, L20B S10, L20B 720
NISSAN COMPETITION (from 1984 catalog)
  • 13001-22000 SSS CAMSHAFT (.413/248°)
  • 99996-D1023 RALLY CAMSHAFT (.475/270°) 109° lobe centers, requires .160" lash pads
  • 99996-D1022 SLALOM CAMSHAFT (.490/290°) 109° lobe centers, requires .160" lash pads, competition springs
  • 99996-D1025 #196 RACE CAMSHAFT (.530/306°) 102° lobe centers, requires alternate las pads, competition springs, spray bar
  • 99996-D1024 #273 RACE CAMSHAFT (.630/306°) high-lift version of 99996-D1025
  • 99996-D1029 CAMSHAFT BILLET/UNDRILLED
Thermostat Housing
L20B thermostat housing changed three times due to incorrect readings on the temperature gauge.
The improved version is a 3-bolt outlet & gasket, from May 1978.
USA 720	L20B
11061-Y7000 HOUSING-THERMOSTAT
11062-Y7000 GASKET-WATER OUTLET
11060-Y7010 OUTLET-WATER
The 3-bolt housing is the best one. The dealers used to put it on L20Bs that were marginally overheating and it fixed the problem. Of course you have to change both the housing and the outlet both.
The last time Nissan revised the L20B thermostat housing they increased the outlet to a larger diameter, and used larger hoses. This was to (yet again) prevent overheating issues. It seems to have worked.
11062-Y7000 GASKET-WATER OUTLET <> 11062-D4200
WASHER-JOINT,OUTLET
720	L20B
910	L24E/LD2
B11	CD17
S12	CA18DET
S130	L28E
T11	CA20S
S10	L20B 0578-
620	L20B 0578-
11062-D4200 GASKET-WATER OUTLET
910	L24E
B11	CD17
KN13	CA16DE/CA18DE
511	CA20S
720	L20B
910	LD28
S10	L20B 0578-
620	L20B 0578-
720	L20B
S10	L20B 0578-
620	L20B 0578-
L-series water inlet is high on the right side of the timing cover
30551.jpgAlbum 30551
The big hose goes down to the cool part of the radiator (the bottom).
The small hose going up leads to the thermostat housing on the other side of the engine
13049-21001 INLET-water PB110
13049-U0100 WATER-INLET 510.USA
27061-21000 CONNECTOR 2 WAY
The 2-way connector: leads up the intake manifold on the other side of the engine. Some engines, this tees off with a "bypass hose" that goes to the thermostat housing. Some L engines do not have the bypass hose.
For the 510, the rear outlet is capped. For the PB110 it is connected to the heater outlet hose.
Clutch
L Engine transmissions use a hydraulic clutch. For LHD 1200s, just connect the existing hose to the new transmission.
Changing the clutch over to hydraulic from the Datsun 1200 cable system. You can use a Clutch Master Cylinder from Stanza A10. Put a hole through the firewall with a hole saw and bolt it up. Its very close to the brake master cylinder. Straighten the clutch pedal at the top so that it pivots correctly.
Also see for more ideas: Hydraulic clutch
180mm: L14
200mm: L16/L18/L20B cars
225mm: L18/L20B trucks
240mm: L24/L26/L28
5-bolt: L13/L14/L16/L18
6-bolt: L20B/L24/L26/L28
1974 620 with L18: 5 bolt crank and 225mm
Flywheels
When purchasing the engine, get the matching flywheel with it. Some L-series engines use a crank with five bolts for the flywheel, but most have six bolts.
Best to get the matching clutch assy and be sure to get tne matching release bearing sleeve.
L14
5-bolt flywheel with 180 mm clutch surface
L16, L18 cars
5-bolt flywheel with 200mm clutch surface
L18 - 1974 Datsun 620 Pickup
5-bolt flywheel with 225mm clutch surface
L20B
6-bolt flywheel with 225mm clutch surface (trucks)
6-bolt flywheel with 200mm clutch surface (S10)
280Z (L28) Flywheel
11251.jpgAlbum 11251
Distributors
Points, Hitachi remote EI from 1976-1978, and Matchbox from 1979-up. Z-series and L-series distributors interchange but only the 4-plug type should be used.
Advance Curves
1974 620 with L18
initial timing 12°@800rpm (12@650 in "D")
D4A2-01 550rpm/0° to 2150rpm/10°, 5.91inHg/0° to 0.94inHg/3.5°
Total advance: 10° initial + 2x12° centrifugal = 34°
1976 S30 with L28E
plug gap .8mm (0.031 in.)
FED D6F4-01 7° @ 800rpm HOT, 13° COLD
FED D6F4-02 7° @ 700rpm HOT, 15° COLD with AUTOMATIC
CAL D6F4-03 10° @ 800rpm
CAL D6F4-03 10° @ 700rpm with AUTOMATIC
CAL 2+2 D6F4-02 10° @ 700rpm
2+2 D6F4-01 7° @ 700rpm HOT, 13° @ 800rpm COLD
2+2 D6F4-02 7° @ 700rpm HOT, 13° COLD with AUTOMATIC
1977 S10 with L20B
all the same Centrifugal curve except CAN AT
all Vacuum curves vary
Full advance: ° initial + ° centrifugal = °
Hitachi Remote EI, high-energy
plug gap 1.1mm (0.043 in.)
CAL MT D4F5-06 600rpm/0° to 1950rpm/11°, 2.76inHg/0° to 7.68inHg/10°
CAL AT D4F5-07 600rpm/0° to 1950rpm/11°, 3.54inHg/0° to 5.51inHg/13°
Hitachi points
plug gap 0.9mm (0.035 in.)
FED MT D4A5-14 600rpm/0° to 1950rpm/11°, 2.76inHg/0° to 7.68inHg/10°
FED AT D4A6-03 600rpm/0° to 1950rpm/11°, 3.54inHg/0° to 6.30inHg/4°
CAN MT D4A6-06 600rpm/0° to 1950rpm/11°, 5.91inHg/0° to 9.84inHg/5°
CAN AT D4A6-07 550rpm/0° to 2300rpm/11°, 5.91inHg/0° to 9.84inHg/3°
