B210 console
Revision as of 23:28, 29 September 2025; view current revision
Category: Interior
<-- back to Console
B210 came with two different factory consoles (small and large) which are similar to the equivalent B110 consoles, but lower-profile and more streamlined/rounded.
NOTE: Does not fit the 1200 well
B210 came with two different factory consoles:
  • H50 #Short console (JDM: DX and van)
  • H51 #Long console (JDM: GL and GX)
These are similar to the equivalent B110 consoles, but lower-profile and more streamlined/rounded.
Short Type | Long Type
A12/A14/L14
H50 DX,V  short type
H51 GL,GX long type
L14/L16
H59 GB210 black or brown
* with pocket and coin tray
* with clock
* with twin gauges
Short
The short or small-type does not extend back between the seats.
174_65c0848f611eb.pngPost 498254
3146.jpgAlbum 3146 2858.jpgAlbum 2858
10994_51358e13c4f9f.jpgPost 431482 174_65c0847144c88.jpgPost 498254
74598-H5000 is this for the console? Or is it a jack mounting bracket?
Long
Standard "large type" for JDM GX & GL, Option for DX & Van
GL sedan with OPTION steering wheel
174_65c113815ec78.jpgPost 498256
GL Coupe
174_65c1138f52545.jpgPost 498256
174_65c11360045cb.jpgPost 498256
Modified for use with shifter of long gearbox
This one appear to have been cut to shorten it?
Option 3
174_65c2d3773d820.jpgPost 498276
Two Gauge
Dual-gauge was stock in the long console for Excellent GL
Also available as an option for all B210
174_65cc5db438b15.jpgOPTION Catalog
PB210 option DX, GX
21 74982-H5927 MASK KIT-console box with screw (Brown)
22 24870-H5500 GAUGE-oil pressure
23 24845-H5500 METER-ampere
24 25070-89901 UNIT-oil pressure gauge
Overhead Console
174_65713a3748449.jpgInstallation
North America
For sedan, console only available as OPTION for the last year '78, so very rare.
For USA Coupe, the long box was standard, though the short box was an option. In Canada, coupe console was an OPTION.
Amco
Official Datsun Accessory by Amco was this nice padded armrest. It provided a pocket tray, the hinged armrest, and a compartment under the armrest. It perfectly fit the early console. If you had the nice Coupe long console, installation called for cutting it.
174_68db0ff1d8bd3.jpgPost 499072 174_68db10138b9fd.jpgPost 499072 174_68db101e7e69d.jpgPost 499072 174_68db1029d17b1.jpgPost 499072 174_68db1034ba478.jpgPost 499072
                     INSTALLATION INSTRUCTIONS
                    DATSUN B 210 (1974) CONSOLE
1. Remove the four (4) sheet metal screws on late model Consoles and
   only the two (2) rear screws on early model consoles.  Untie shift
   boot ties on late model console only.
2. Early model consoles do not need to be removed.  To remove the late
   model console:  pull emergency brake all the way up, put gear shift
   in third gear and put seats all the way back.  Lift back end of
   console up, swing back end over seat cushion and remove.
3. On late model consoles only, cut end of console off as show in
   illustration.
4. Re-position cut off console in vehicle and install only the front
   two sheet metal screws.
5. For early and late model consoles, install the custom extended
   console as shown in illustration.  Install the two remaining
   (previously removed) sheet metal screws through front holes on
   extended console and through rear holes of factory console.
6. With a 1/8" (.125) drill, drill two holes in floor hump using rear
  holes of extended console as a guide. Install sheet metal screws
  provided.
  NOTE: Be sure not to drill through emergency brake cable on right
  hand side of floor hump. Do not drill through hydraulic
  lines located on underside of floor tunnel.
A275                                                      AA #367
174_68db11ac87386.jpgPost 499072
Comparison To B110 Consoles
The B210 consoles are similar to the equivalent B110 consoles, but the newer units are lower-profile and more streamlined/rounded.
  • lower profile: does not rise up and cover the heater vent
  • less angular, a bit more sleek
174_65c1134e516b5.jpgPost 498256
