KA Engine Swap
Revision as of 07:15, 14 January 2010; view current revision
Category: Engine Modifications
At 2.4 liters, the KA24E or KA24DE engine is the largest Nissan 4-cylinder engine. In many countries, it is readily available and inexpensive coming out of Nissan pickups. It will make a Datsun 1200 into a quick accelerator.
KA24E in Datsun 1200 = 14.0 second 1/4 mile
The main downside is that it is fairly heavy -- as heavy as an L-series engine (the KA24 is based on the L-series engines). One or two club members have swapped this into their 1200s with good success, reporting 14.0 second 1/4s with a stock motor (http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=6248&forum=2). Reportedly, a stock KA24DE can handle a fair amount of turbocharger boost, but not as much and doesn't rev as high as the SR20DET or CA18DET. So it's a good engine for street use, but the others may be better for high-dollar supercar buildups.
  • Fit a front sump oil pan and use the stock Datsun 1200 crossmember.
  • Fabricate custom engine mounts
  • Fabricate custom rear transmission mount
  • Use a stumpy transmission and 1978-1979 Datsun 510 rear axle with stock 510 driveshaft
There isn't much information on this swap into 1200s, so here are some links to 510 swap information: Datsuns.com 510 swap info
Fiveoneoh.com:
In stock form [the KA24] produces a large amount of power and impressive torque compared to the L-series motor. It would take a very carefully built L-series motor to equal the power and torque of the KA24. It has a very fair redline and will easily spin the tires in lower gears. If you are converting from the average L20b with mikuni's or built L16/L18 you will be happily surprised.
434.jpg 774.jpg 1737.jpg 1738.jpg 1780.jpg 1829.jpg 1830.jpg 1853.jpg 4265.jpg 4266.jpg 6523.jpg 8903.jpg 14359.jpg 16489.jpg
