Cam Followers, commonly called Lifters, are between the camshaft and the pushrods.
Inspect for Damage
Good lifter on right, bad lifter on left.
Large Diameter Lifter
At right is the standard valve lifter, but the umbrella diameter is not enough in the cam where the lift quantity is large. The left's umbrella diameter is larger:
Tomei Lightweigth lifter (軽量リフター) 33.600円 per set (about $350 USD).
Tomei Hollow Valve Lifter
B-Pro Lifter
An ecomonical lifter from B-Pro, is lighter (50g) than the stock A-series lifter (60g+).
- 13231-H1001 Stock Cam Follower $15.64 USD
- 13231-M0821 Lightweight Cam Follower
- 13231-78201 Oversize Cam Follower
- Required when installing certain extra-high performance camshafts
