Datsun 1200 axle shafts come in two sizes: H145 for all cars and early utes, and H165 units for 1974-1997 models.
Bearing Replacement
The bearing is held on a by a collar (a plain ring). This has to cut off with a cold chisel, then a new one pressed on.
Bearing held on by shaft collar
When replacing a rear axle bearing, check the wheel bearing-to-housing end face clearance and adjust with shims.
Suppliers - USA
- Nissan
- RockAuto differential parts
- http://www.partsamerica.com
Axle
- 38162-G0300 ASSY-SHAFT REAR AXLE B110, B210
- 38162-H8500 SHAFT ASSY-REAR AXLE(L=612) B310
- 38162-G1000 SHAFT ASSY-REAR AXLE B120 7510- with H165 diff
- Also B210 H165B with L16 engine
Rear Axle Seal
- Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
Rear Axle Bearing
- Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
- Required when replacing the bearing. The collar is cut in two to release the bearing, and the new collar pressed on.
- Nissan 43215-18000 BEARING-REAR AXLE
- SKF BR30206 O'Reillys/Schucks/Grand/Kragen
- National Bearing 30206
- KOYO 83294C4
- NSK B32-3CC5
- NTN 6206BLUX/32C4 $28 USD
NOTE: 180 is B10 part number, so B10 and B110 should interchange
Specs:
- O.D.: 62.000 (mm)
- Bore: 30.000 (mm)
- Width: 16.000 (mm)
