Block Comparison
Revision as of 05:06, 12 October 2009; view current revision
A10
B10 Sunny "Datsun 1000" came with A10 engine, 998 cc, 3-main bearing block. All other engines except A10 have 5-main bearings.
JDM Catalog
  • 11010-18000 ALL Except Coupe
    • 13035-18000 ASSY-COVER TIMING CHAIN
  • 11010-18001 from E/# A10-184228
    • 13035-18001 ASSY-COVER TIMING CHAIN [updated to Double timing chain & pressure tensioner]
    • 13035-H1000 ASSY-COVER TIMING CHAIN from 0570 [Fits all B10 blocks]
  • 11010-25700 Coupe
Some B10 was fitted with NIKKI carburetor.
A12
B110
B110 A12 engine
  • 11010-H1000 JDM, USA -0470
  • 11010-H2300 GX, USA non-GX from 0570-
    • [chain tensioner and bolts changed 0570]
B310
F10
  • 11010-H2300 A12 BARE BLOCK 73mm/2.87" bore size
    • H10 or M08
  • 11010-H9960 A12A BARE BLOCK 75mm/2.95" bore size
  • 11010-H6200 [1974] A13 BARE BLOCK 73mm/2.87" bore size
  • A14 cast "A14" above fuel pump
    • H72 or G30
  • 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
    • G34
