Nissan Part Numbers
Revision as of 02:22, 12 April 2013; view current revision
Category: General Information
Nissan Part Numbers are comprised of two parts. The first part is the type of part. The part after the dash indicates the which car it was originally designed for.
PN format: OOOOO-OOOOO
Format:OOOOO-OOOOO
Number:SectionCharacter-Part TypeDistinction
Indicates:major function of partminor classification of section-Applied model (1)difference between similar parts
(1) Applied model: "the part is originally designed for this model. However, it may be used widely over our models. Therefore, it does not always signify the applied model".
Also see: Nissan N.E.S. Bolt & Small Hardware Part Numbers
Section
10	ENGINE
20	ELECTRICAL
30	POWER TRAIN
40	AXLE
50	BRAKE
60	STEERING
70	BODY (SEDAN)
80	BODY (COUPE)
90	MISCELLANEOUS
Section Detail
10 Engine
001 ENGINE ASSEMBLY
002 GASKET KIT
003 CYLINDER BLOCK, FRONT COVER & OIL PAN
004 CYLINDER HEAD, ROCKER COVER & THERMOSTAT
005 EMISSION CONTROL DEVICE
006 PISTON, CRANKSHAFT & CONNECTING ROD
007 CAMSHAFT, VALVE, SPROCKET & CHAIN
008 MANIFOLD
Sec.Group
10Engine complete section
11Engine section No. 1
12Engine section No. 2
13Camshaft & valve section
14Manifold section
15Lubrication section
16Fuel section No. 1
17Fuel section No. 2
18Engine control section
19Decomp & governor section
20Exhaust section
21Cooling system section
22Electric section No. 1
23Electric section No. 2
24Electric section No. 3
25Electric section No. 4
26Electric section No. 5
27Room heater & radio section
30Clutch group
32Transmission group
33Auxiliary gear box section
34Transmission control group
36Auxiliary brake section
37Propeller shaft group
38Final drive unit section
40Front axle section
41Front brake section
43Rear axle section
44Rear brake section
46Master cylinder, pedal &, piping group
47Power brake section
48Steering section
50Frame section
51Cross member section
54Front suspension section
55Rear suspension section
56Shock absorber section
57Spare tire section
60Body complete white body group
61Body front group
62Radiator shell & bumper section
63Fender section
64Hood ledge section
65Hood section
66Cowl section
67Dash section
68Instrument section
72Windshield section
73Roof section
74Floor section No. 1
76Body side section No. 1
78Rear fender section
79Back panel section
80Front door section No. 1
82Rear door section No. 1
84Trunk section
85Rear bumper section
86Front seat section No. 1
88Rear seat section No. 1
93Rear body section No. 1
95Body mounting section
96E. T. C. section No. 1
97E. T. C. section No. 2
99Car complete & tool section
Applied Model
Look at this part of the part number: 00000-xxx00 The xxx part tells which car it was designed for. Following is an abbreviated quick list, focusing on A-engined cars like the Datsun 1200 and those that share parts with the 1200.
For full list see: Applied Model Codes
  • SUNNY
  • 180, 181, 182, 183 (B10)
  • 209, 248, 257, 258, 277, 278 (B10)
  • H01-H03 ('69 B10)
  • H01-H99 numbers (B110/B210/B310)
  • W50 or W55 - A10 & B310
  • 95W late Sunny Truck
  • A-series FWD
  • M01-M99 is for Datsun F10/310 (Nissan Cherry)
  • BLUEBIRD
  • 210-299, A06-A60, A86-A95, N01-N24 Datsun 510
  • U01-U29 Datsun 610
  • PATROL model 60 (1960-1980)
  • 440, 441, 442
  • Datsun Pickup
  • B50-B99, G70, G71 Datsun 620
  • 10W, 30W, 04W Datsun 720
  • B50: Datsun 620 RHD
  • B93: Datsun 620 Truck RHD 7510-
  • B94: Datsun 620 Truck RHD 7605- Custom [extended cab]
  • B95: Datsun 620 Truck RHD
  • B96: Datsun 620 Pickup (coupe utility)
  • B64: Datsun 620 pickup LHD
  • G71: Datsun 620 Truck RHD 7809-
Distinction
The last two digits indicate a parts variation: maybe a different color, material or finish. Or possibly a production revision. They usually interchange but not always.
PurposeRangeMeaning
Similarity00-19
60-69
When parts are only slightly changed, or different color
Exc. Svc Use25-29
75-79
Repair kit/set used exclusively for service
Material00-19
60-69
Difference in materials
Processing00-19
60-69
For convenience of production line process, in case we can not use the original Part No.
LetteredA-ZExclusively reserved for service use
Example
Example: Nissan Part Number 40052-H1000
Sec. No.Character No.-Part Type No.Distinction No.
40052-H1000
Axle0-Front Axle-B110S('70.5)n/a
 052-Knuckle Arm RH-B110 Sedan, 1970-1/2
Reference: Datsun 1200 USA & Canada Parts Catalog Model B110 Series (C-0030U), 4th Overall Revision, December 1973
