A-series Cylinder Heads were used in many models, and there are many variations. For more details, see A-series Cylinder Heads. Following are part numbers for head assemblies. Also see A12GX Part Numbers.
Contents[hide] |
Head Gasket
GASKET-CYLINDER HEAD (11044)
73 MM Bore
A10 Bore 73mm 11044-18000,18001,18002 B10 11044-18004 B10 replaces early part
A12 Bore 73 mm 11044-H1000 B110, B210 to '75-4 11044-H1025 B210 from '75-5 11044-H3901 B210 -7612, B310 Van 11044-H7403 B210 7701- 11044-M3000 B210 Van -7612 11044-M3001 B210 Van 7701- 11044-H8501 B310 Sedan, Coupe 11044-H2300, H2301 [thinner?] A12GX, A12T 11044-H2325 A12GX from '72-6
A13 (1974) Bore 73mm
75 MM Bore
A12A Bore 75mm
76 MM Bore
A14 Bore 76mm 11044-H7500,H7860 B210 11044-H7201 B310 11044-M2460 A14T
A13S,A15 (76mm bore) 11044-H8660
Intake Gasket
GASKET-MANIFOLD TO CYLINDER HEAD
- 11044-H7200 A14 Dry Oval Port
- 11044-H7400 A14 Dry Round Port
Valve Guides
- 13212-H0112 GUIDE-VALVE INTAKE $8.08
- 13213-H0113 GUIDE-VALVE EXHAUST $8.25
B10 JDM
From the B10 JDM parts catalog June, 1970 * Intake valves: 35mm 13201-H1000 (formerly 13201-18000) * Exhaust valves: 29mm 13202-18000 * Rally Springs (dual valve springs) were an option * Round Ports * Dry manifold
A10
180, H01, and H10 heads for B10 Sedan & Van 11041-18001, 11041-18002 ASS'Y-HEAD cylinder 11041-H0100 ASS'Y-HEAD cylinder 11041-18002 11041-H1001 ASS'Y-HEAD cylinder from '70-april. This last B10 head is the same as the B110 head. The fittings are probably different from the early head.
A10 Coupe
257 and H03 Heads for Coupe * Used with flat-top pistons for higher compression 11041-25700,11041-25701 ASS'Y-HEAD cylinder 11041-H0300 ASS'Y-HEAD cylinder 11041-25701 Most likely the Coupe head has a different size chamber (larger?), so that the flat-tops don't push it to 10.5:1.
B110 JDM
The following part numbers are from the B110 Japanese Domestic Model parts catalog (Nov. 1971).
A12
H10 Head * Intake valves: 29mm 13201-H1000 * Exhaust valves: 35mm 13202-18000 11041-H1001 HEAD ASSY-CYLINDER A12 except GX 11041-H1003 11041-H1003 HEAD ASSY-CYLINDER A12 except GX 11041-H1005 11041-H1005 HEAD ASSY-CYLINDER A12 except GX All of these are replacement-equivalents
A12GX (dual valve springs)
H23 Head for A12GX Engine * Appears identical to Early A12T Head Valves are same size as non-GX, but are special in some way * Intake valves: 13201-H2300 35mm * Exhaust valves: 13202-H2300 29 mm Combustion Chamber: 29cc (compression ratio 10:1 with flat-top pistons) 11041-H2300 HEAD ASSY-CYLINDER A12 GX 11041-H2301 11041-H2301 HEAD ASSY-CYLINDER A12 GX
B110 USA
Early USA model B110s heads were the same as JDM heads. From May 1971, had "Open" combustion chambers to reduce NOx emissions.
H10 Closed Chamber (same as JDM heads) 11041-H1001 to 5/71 obs
H39 Open Chamber (unique to USA, Model of Origin code H39 is for LB110TRU (U for United States) 11041-H3900 6/71-12/72 obs 11041-H3901 1/73-2/73 obs 11041-H3902 3/73 & up 11041-H3903 3/73 & up (supercedes H3902)
Source: Hollander Catalog, Nissan Parts Catalog
B120 Sunny Truck
Intake valves: 35mm * 13201-H1000 to 8503 * 13201-H2300 from 8504 Exhaust valves: 29mm * 13202-18000 to 8503 * 13202-H7400 from 8504
From the B120 Japanese Domestic Model parts catalog (1974, covers Start of JDM product in 1971 to April 1974)
H10 Head 11041-H1001 HEAD ASS'Y-cylinder 11041-H1002 HEAD ASS'Y-cylinder (from '72-1) [interchanges with H1001] 11041-H1003 HEAD ASS'Y-cylinder (from '73-1) 11041-H1005 HEAD ASS'Y-cylinder (from '73-3) [interchanges with H1003] * 11044-H1000 GASKET-cylinder head [no O-ring] * 11044-H1000 GASKET-cylinder head (from '72-5) [can use on earlier head] ** 11045-H1000 RING-"O" (from '72-5)
From the B120 Japanese Domestic Model parts catalog (Oct 1997, covers 7510-end of JDM product in 1994/1995)
Head Gasket * 11044-H3901 7510-9107 * 11044-H3902 9107-
M30 Dry Intake - Original Pattern Intake Gasket 14035-18000 * original manifold bolt-pattern 11041-M3000 HEAD ASSY-CYLINDER 7510-7803 * new manifold bolt-pattern 11041-M3001 HEAD ASSY-CYLINDER 7804-7907
G25 Dry Intake, New Bolt Pattern * Intake Gasket 14035-H7400 11041-G2560 HEAD ASSY-CYLINDER 7908-8109 * Intake Gasket 14035-H7410 11041-G2561 HEAD ASSY-CYLINDER 8110-8910
G61 Wet Intake, New Bolt Pattern * Intake Gasket 14035-H8501 -9111 * Intake Gasket 14035-H8511 9111- 11041-G6100 HEAD ASSY-CYLINDER 8910- * uses bridged intake manifold (front and rear runners are tied together)
B210 JDM Early
From the Nov 1976 JDM catalog
A12T
H57 Head 11041-H5702 HEAD ASSY-cylinder A12T * Intake valves: 13201-H2300 35mm * Exhaust valves: 13202-H2300 29mm * Extra Large Oval Port * Wet intake * Dual valve springs
A12S
* Intake valves: 35mm 13201-H1000 * Exhaust valves: 29mm 13202-18000 * Original Intake Bolt Pattern (Gasket 14035-18000) * Dry Intake
H50 Head 11041-H5002 HEAD ASSY-cylinder A12S
H30 Head 11041-H3000 HEAD ASSY-cylinder A12S (from '75-10) ^11041-H5002
B210 JDM Late
From the B210 Japanese Domestic Model parts catalog (Jul 1978) unless otherwise stated.
Head Gasket * A12: 11044-H3901 * A14: 11044-H7200 A14, A14T
A12 (Van)
M30 Head * Intake valves: 35mm 13201-H1000 * Exhaust valves: 29mm 13202-18000 * Round Port * Dry intake * Original intake bolt pattern 11041-M3000 HEAD ASSY-CYLINDER A12S V -7612 11041-M3001 HEAD ASSY-CYLINDER A12S V 7701-
A12S
H74 Head * Intake valves: 35mm 13201-H2300 * Exhaust valves: 29mm 13202-H7400 * Round Port * Dry Intake * New intake bolt pattern 11041-H7401 HEAD ASSY-CYLINDER A12S S,K -7612 11041-H7403 HEAD ASSY-CYLINDER A12S S,K 7701-
A14 (Van)
* Intake valves: 37mm 13201-H6200 * Exhaust valves: 30mm 13202-H6200
H75 Head 11041-H7500 HEAD ASSY-CYLINDER A14S V * Round Ports ** Intake-to-Head gasket 11044-H7200 * Dry Intake
11041-H7860 HEAD ASSY-CYLINDER A14S V
A14T (twin carb)
M24 Head * Intake valves: 37mm 13201-H6200 * Exhaust valves: 30mm 13202-H6200 * Dual valve springs * Oval Ports (smaller than GX, same size as standard A14) ** Intake-to-Head gasket 11044-H7200 11041-M2460 HEAD ASSY-CYLINDER A14T
B210 USA
HLB210 -- H for A13/A14 engine.
A13 (1974)
H62 Head * Medium Oval Port * Large Valves (A14 size) 11041-H6200 ASSY-HEAD CYLINDER A13 11041-H6201 ASSY-HEAD CYLINDER A13 11041-H6202 ASSY-HEAD CYLINDER A13 * 14035-H6200 GASKET-MANIFOLD TO CYLINDER HEAD
A14 Round Port
FU Head Round Port, Large Valves (came with 5-speed United States (FU) models) * 11044-H7400 GASKET-MANIFOLD TO CYLINDER HEAD 11041-H7281 ASSY-HEAD CYLINDER A14 (FED)(GFU) 1276-0578 11041-H7281 ASSY-HEAD CYLINDER A14 CAN 0877-0578 11041-H7282 ASSY-HEAD CYLINDER A14 (FED)(GFU), CAN 0678- 11041-H7283 ASSY-HEAD CYLINDER A14 (FED)(GFU), CAN 11041-H78261 B-210 1977 A14 5-speed Hollander
A14 Oval Port
Oval Port heads came on non-5-speed models.
H72 Head * 11044-H7200 GASKET-MANIFOLD TO CYLINDER HEAD 11041-H7200 ASSY-HEAD CYLINDER A14 -1175 11041-H7201 ASSY-HEAD CYLINDER A14 0776-0876 11041-H7261 ASSY-HEAD CYLINDER A14 0876-0777
H77 Head 11041-H7760 ASSY-HEAD CYLINDER A14 0877-0578 11041-H7761 ASSY-HEAD CYLINDER A14 0678- 11041-H7762 ASSY-HEAD CYLINDER A14 11041-H7760 B-210 1977 A14 exc. 5-speed Source: Hollander
M49 Head 11041-M4900 B-210 1975-1976 A14, F10 1976 Source: Hollander
B310 JDM
From the B310 Japanese Domestic Model parts catalog (Nov. 1983)
A12S Van
* Intake valves: 35mm 13201-H1000 (1971 B110) * Exhaust valves: 29mm 13202-18000 (1971 B110) * Round Port * Dry (no intake water ports) * 11044-H3901 GASKET-CYLINDER HEAD
M30 Head old intake bolt pattern * 14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD A12S.V -7909 * 14035-18010 GASKET-MANIFOLD TO CYLINDER HEAD A12S.V -7909 11041-M3001 HEAD ASSY-CYLINDER A12S.V N-7907 11041-G2560
G25 heads new intake bolt pattern * 14035-H7400 GASKET-MANIFOLD TO CYLINDER HEAD V 7910- [A14S.V, A12S.V] * 14035-H7410 GASKET-MANIFOLD TO CYLINDER HEAD V 7910- [A14S.V, A12S.V] 11041-G2560 HEAD ASSY-CYLINDER V.A12S 7910-8010 11041-G2561 11041-G2561 HEAD ASSY-CYLINDER V.A12S 8011-
A12S Van head is same as B120 Truck head.
A12S, A13S Sedan, Coupe
A13S replaced A12S 8011 * Intake valves: 35mm 13201-H2300 (1971 B110 GX engine) * Exhaust valves: 13202-H7400 * Round Port * Intake Water Ports * New intake bolt pattern
H85 heads * 11035-H8501 GASKET-MANIFOLD TO CYLINDER HEAD A12S.S,K Both of these are replacement-equivalents 11041-H8500 HEAD ASSY-CYLINDER A12S.S,K N-7909 11041-H8501 11041-H8501 HEAD ASSY-CYLINDER S,K.A12S 7910-8010
* 11044-H8660 GASKET-MANIFOLD TO CYLINDER HEAD A13S, A15 8011- 11041-H8503 HEAD ASSY-CYLINDER A13S 8011-
A14 Van
* Intake valve: 37mm 13201-H6200 * Exhaust valve: 30mm 13202-H6200 replaced by 13202-H8900 7910- * Dry (no Intake Water Ports) * New intake bolt pattern * Gasket 11044-H7201 (all A14)
H78 Oval Port heads * Oval Port * 14035-H7200 GASKET-MANIFOLD TO CYLINDER HEAD A14S.V -7909 * 14035-H7210 GASKET-MANIFOLD TO CYLINDER HEAD A14S.V -7909 11041-H7861 HEAD ASSY-CYLINDER A14S.V N-7806 11041-H7863 11041-H7863 HEAD ASSY-CYLINDER A14S.V 7807-7909 11041-G3202
H78 Round Port heads * Round Port * 14035-H7400 GASKET-MANIFOLD TO CYLINDER HEAD V 7910- [A14S.V, A12S.V] * 14035-H7410 GASKET-MANIFOLD TO CYLINDER HEAD V 7910- [A14S.V, A12S.V] 11041-G3202 HEAD ASSY-CYLINDER V.A14S 7910-8010 11041-G3203 HEAD ASSY-CYLINDER V.A14S 8011-
A15 & A14 Sedan, Coupe
H89 heads * Intake valves: 37mm 13201-H6200 * Exhaust valves: 30mm 13202-H6200 replaced by 13202-H8900 7910- * Regular Oval Port * Wet (Intake Water Ports) * New manifold bolt pattern 11041-H8900 HEAD ASSY-CYLINDER S,K.A14S 7811-7903 11041-H8901 11041-H8901 HEAD ASSY-CYLINDER S,K.A14S 7811-7903 11041-H8904 11041-H8904 HEAD ASSY-CYLINDER S,K.A14S 7904-8010, A15S 8011-
A14E & A15E
H92 heads * Intake valves: 37mm 13201-H6200 * Exhaust valves: 30mm 13202-H6200 replaced by 13202-H8900 7910- * Dual valve springs * Medium Oval Ports with notch for injector * Wet (has intake Water Ports) 11041-H9200 HEAD ASSY-CYLINDER A14E N-7810 11041-H9201 11041-H9201 HEAD ASSY-CYLINDER A14E 7811-7903 11041-H9202 11041-H9202 HEAD ASSY-CYLINDER A14E 7904-7907 11041-H9204 11041-H9204 HEAD ASSY-CYLINDER A14E 7908-8010 11041-H9204 HEAD ASSY-CYLINDER A15E 8011- All of these are replacement-equivalents
B310 USA
Source: Nissan Parts Catalog Jan 2006
North American Market was divided starting in mid-1970s:
- FED (U): Federal (49 states, not including California)
- CAL (K): California (which has stricter emission regulations)
- CAN (N): Canada
Heads and Head Gaskets were updated 0880, not interchangeable with previous gasket and head. The blocks are the same, so presumably the head was physically changed or ... perhaps the specification was simply upgraded.
VALVE -0780
- INTAKE 37mm: 13201-H6200 A12A USA
- EXHAUST 30mm: 13202-H6200 A12A USA
VALVE 0880-
- INTAKE: 13201-H9500 A12A USA 0880-
A10 JDM
From the JDM parts catalog for A10 Model Series (Auster/Violet) February 1980.
Base models had A14S engines, while the other trim levels were fitted with L-series or Z-series engines as in USA A10 "Datsun 510" and Australia A10 "Stanza".
* Intake valve: 37mm 13201-H6200 * Exhaust valve: 30mm 13202-H6200, replaced by 13202-H8900 7907- * 11044-H7200 GASKET-CYLINDER HEAD A14S -7803 * 11044-H7201 GASKET-CYLINDER HEAD A14S 7807-
H78 Oval Port heads * 14035-H7200 GASKET-MANIFOLD TO CYLINDER HEAD A14S.V -7906 * 14035-H7210 GASKET-MANIFOLD TO CYLINDER HEAD A14S.V -7906 11041-H7861 HEAD ASSY-CYLINDER A14S.V -7806 11041-H7863 HEAD ASSY-CYLINDER A14S.V 7807-7906
G32 head * 14035-H7400 GASKET-MANIFOLD TO CYLINDER HEAD A14S.V 7906- 11041-G3202 HEAD ASSY-CYLINDER A14S.V 7907-
H75 head * 14035-H7200 GASKET-MANIFOLD TO CYLINDER HEAD A14S.S,K -7803 11041-H7502 HEAD ASSY-CYLINDER A14S.S,K -7803
H89 head * 14035-H8901 GASKET-MANIFOLD TO CYLINDER HEAD A14S.S,K 7804- 11041-H8900 HEAD ASSY-CYLINDER A14S.S,K 7804-7906 11041-H8902 HEAD ASSY-CYLINDER A14S.S,K 7907-8003 11041-H8904 HEAD ASSY-CYLINDER A14S.S,K 8004-
Nissan Cherry Heads
The Cherry model family was Nissan's first front-wheel-drive line and includes the E10, F10 and N10 models, a.k.a. Datsun/Nissan Pulsar and includes Datsun 310.
E10 JDM
A10
M01 head * Intake valves: 35mm 13201-H1000 * Exhaust valves: 29mm 13202-18000 * 14035-18000 GASKET (manifold to cylinder head) 11041-M0100 HEAD ASSY-cylinder A10 11041-M0101 HEAD ASSY-cylinder A10 (from '72-1) 11041-M0102 HEAD ASS'Y-cylinder A10 (from '73-3)
A12S
H15 Head * Intake valves: 35mm 13201-H1000 * Exhaust valves: 29mm 13202-18000 * 14035-18000 GASKET (manifold to cylinder head) 11041-H1501 HEAD ASSY-cylinder A12S 11041-H1502 HEAD ASS'Y-cylinder A12S (from '73-1) 11041-H1503 HEAD ASSY-CYLINDER A12S (from '73-3)
A12T
Early_A12T_Head * (dual valve springs) * Intake valves: 35mm 13201-H2300 * Exhaust valves: 29mm 13202-H2300 * 14035-H2300 GASKET (manifold to cylinder head) 11041-M0800 HEAD ASSY-CYLINDER A12T 11041-M0801 HEAD ASS'Y-cylinder A12T (from '73-3)
F10 JDM
A12 Sedan & Coupe
* Intake valves: 35mm 13201-H2300 * Exhaust valves: 29mm 13202-H7400 11041-H7401 HEAD ASSY-CYLINDER A12S S,K
A12 Van
* Intake valves: 35mm 13201-H1000 * Exhaust valves: 29mm 13202-18000 11041-M3000 HEAD ASSY-CYLINDER A12S V
A14S
* Intake valves: 37mm 13201-H6200 * Exhaust valves: 30mm 13202-H6200 11041-7502 HEAD ASSY-CYLINDER A14S
A14T
* Intake valves: 37mm 13201-H6200 * Exhaust valves: 30mm 13202-H6200 11041-M2460 HEAD ASSY-CYLINDER A14T
N10 JDM
A12S Van
* Intake valves: 35mm 13201-H1000 * Exhaust valves: 29mm 13202-18000 11041-M3001 HEAD ASSY-CYLINDER 11041-G2560 11041-G2560 HEAD ASSY-CYLINDER
A12AS
* Intake valves: 13201-H2300 * Exhaust valves: 13202-H7400 11041-H8500 HEAD ASSY-CYLINDER A12AS 11041-H8501 11041-H8501 HEAD ASSY-CYLINDER A12AS 11041-H8503 11041-H8503 HEAD ASSY-CYLINDER A12AS
A14S Van
* Intake valves: 37mm 13201-H6200 * Exhaust valves: 13202- 11041-G3202 HEAD ASSY-CYLINDER 11041-G3203 11041-G3203 HEAD ASSY-CYLINDER 11041-H7863 HEAD ASSY-CYLINDER
A14S
* Intake valves: 37mm 13201-H6200 * Exhaust valves: 13202- 11041-H8900 HEAD ASSY-CYLINDER 11041-H8902 11041-H8902 HEAD ASSY-CYLINDER 11041-H8904 11041-H8904 HEAD ASSY-CYLINDER
A14E
* dual valve springs * Intake valves: 37mm 13201-H6200 * Exhaust valves: 13202- 11041-H9200 HEAD ASSY-CYLINDER 11041-H9202 11041-H9202 HEAD ASSY-CYLINDER 11041-H9204 11041-H9204 HEAD ASSY-CYLINDER
Nissan Competition
From the 1984 Nissan Competition Catalog:
CYLINDER HEADS & COMPONENTS (A-SERIES)
- 11041-H2302 GX CYLINDER HEAD (TO 6/73) For use with any A-series engine built up to 6/73. It has a 29cc combustion chamber and, due to its large intake port size, must be used with either the GX or Mikuni/Solex intake manifold. Valve size is 35mm/1.38" (intake) and 29mm/1.14" (exhaust)
- 11041-H5703 GX CYLINDER HEAD (FROM 7/73) Specifications are the same as 11041-H2302. For A-series engines built from 7/73
- 99996-H1167 COMPETITION CYLINDER HEAD (TO 6/73) This cylinder head is recommended for racing purposes only. Must be used with either the GX or Mikuni/Solex intake manifold. Completely ported, polished and fitted with competition intake (37mm/1.46") and exhaust (30mm/1.18") valves. For A-series engines built up to 6/73
- 99996-H1165 COMPETITION CYLINDER HEAD (FROM 7/73) Specifications are the same as 99996-H1167. For A-series engines built from 7/73
- 11056-H2301 GX HEAD BOLT Torque spec = 58 ft/lbs (9 needed)
- 11057-H2301 GX HEAD BOLT (TO 6/73) Torque spec = 58 ft/lbs (1 needed)
- 11057-H5700 GX HEAD BOLT (FROM 7/73) Torque spec = 58 ft/lbs (1 needed)
- 11044-M0821 COMPETITION HEAD GASKET Gasket has a bore diameter of 79mm/3.11", an uncrushed thickness of 0.8mm/ 0.032" and displaces 3.9cc's
Hollander Interchange
North American-Market Cylinder Heads (reference Hollander interchange 1980)
No. 183 Datsun 1200 (B110) 71-73 A12
11041-H1001 to 5/71 obs 11041-H3900 6/71-12/72 obs 11041-H3901 1/73-2/73 obs 11041-H3902 3/73 & up
No. 1367 Datsun B-210 (B210) 1974 A13
11041-H6200
No. 1370 Datsun B-210 (B210) 1977 A14
11041-H78261 or 11041-H7760
No. 1375 Datsun B-210 (B210) 75-76 A14 & Datsun F10 1976
11041-M4900
No. 1376 Datsun F10 1977-78
11041-H7660
No. 2641 Datsun 210 (B310) 1979 Ex. California A14 & A15
11041-H7702
No. 2642 Datsun 210 (B310) 1979 California A14 & A15
11041-H9162
No. 2742 Datsun 310 (N10) 1979
11041-H7762
