Wiring Diagram
Revision as of 06:53, 16 July 2010; view current revision
WARNING: Wire colors can vary by year, model and country. Please double-check the wiring in your Datsun 1200 before connecting parts according to this article. You don't want to burn something up! Use a voltmeter or test light to confirm the circuit behavior.
B110
High-Res USA 1971 Intro Diagram
1971 USA
USA 1973 Manual Transmission
B120
1978 Australia 1200 ute
3 parts each 656 x 1280
Total size 1968 x 1280
Differences between 1978 Australia and 1978 other RHD
Horn "Low" is optional in Australia
* standard for other RHD countries.
Transmission switches
* Australia: Spade connectors for Back-up lamp switch
* Other RHD: Round multi-connector to:
** Spade connectors for Top Gear switch
** Spade connectors for Back-up lamp switch
Other RHD has:
* T/O Cut Solenoid
* Vacuum Cut Solenoid
* Speedometer has speed switch and attached SW amplifier
* Body harness is split differently
** one section disconnects from main harness
* Heater is optional
* Dimmer dash illumination switch
** Has usual six-connector rectangular connector
** Has additional 1-spade wire for Twist Control
** Two-position: Normal and Dim (not continously variable)
B122
Late-model Sunny Truck from October 1989
B210 Early RHD (Australia?):
