63-Series Transmission
Revision as of 17:28, 11 December 2006; view current revision
This is the 63 series transmission page.
63A came in two versions:
  • 63A to fit L-series engine
  • 63A to fit A-series engine
So check the bellhousing bolt pattern.
The "A" indicates the transmission revision, not the engine type it fits.
  • 63A
Dogleg 5 speed overdrive 5th Slave cylinder is on the left side Uses AT prop shaft What clutch? What was the special vehicle these came out of?
  • 63L
See also: Category:Drivetrain Modifications
