Clock
Revision as of 21:07, 19 July 2011; view current revision
Factory installed clocks were optional in all 1200 models. Clocks were optional for rectangular or round style dashes. GX models had a clock fitted the Console, while other models fitted the clock to the instrument panel to the left of the speedometer.
Clocks were made by Niles, Kanto Seiki, Citizen or Jeco.
Rectangular, genuine Niles clock for STD or DX model. This one is for later B120 pickup.
newer style - Wide Font
Green Line
Jeco original style - Narrow Font
Theoretical LHD face
Options
2210.jpg Options
8882.jpg Early vs. Late comparo
21253.jpg Citizen clock
PB110 Sunny Excellent
The clock is powered by a constant-Hot wire. If you wire to IGN, it only runs when the key is on :-)
  1. 12V Power: L or RB
  2. Ground/Earth: B
  3. Lamp: RB or RG
Clock: Blue or Red/Black wire
Power feed 12V (Blue) hanging down from the harness.
Clock: Red/Blue or Red/Green
Lamp feed on instrument panel
Clock: Black wire
Ground/Earth point on instrument panel
(panel frame on rectangular panel)
JAPAN kaku メーター 角
27390-H1000 ASS'Y-CLOCK (op.) 3 speed, VDT, B120 -7511
27390-G1000 CLOCK ASSY 7512-7803
25005-H1000 MASK-clock 3 speed, VDT
25006-H1000 NUT-fix clock & tachometer (3)
JAPAN maru メーター 丸
25005-H1800 MASK-tachometer ['Sunny' for clock delete]
27380-H2000 ASS'Y-CLOCK GL,GX
27390-G1660 CLOCK ASSY 7804-
 08540-51612 SCREW
 08964-10510 NUT
JAPAN 1972
27380-H3300 CLOCK ASS'Y GL, (op.) Std, DX
25017-H3100 CLAMP-front cover (3)
25012-H3300 COVER ASS'Y-front (for clock) GL, (op.) Std, DX
25012-H3100 COVER ASS'Y-front ['Datsun' for clock delete]
fixing clock & tachometer
 08964-10510 NUT
 08510-51612 SCREW
 08915-43510 WASHER-plain
27380-H3400 CLOCK ASS'Y (for console box) GX
 08513-41212 SCREW (3) GX
 08915-43410 WASHER-plain GX
27380-H2000 ASSY-CLOCK USA
68470-H1100 MASK-RADIO DATSUN MARK
27978-H1000 PLUG-RUBBER
27979-H1000 PLUG-RUBBER
27389-H2300 SPACER FIXING CLOCK TO CONCOLE BOX
PB110 dash
25005-H1800 MASK-TACHOMETER ['Sunny' delete blank]
27380-H2600 CLOCK ASS'Y GL, GX, (op.) DX
 85-11342-12 SCREW (3)
 89-15434-1 WASHER-plain (3)
PB110 console
74990-H2600 MASK ASS'Y-clock ['Sunny'] GL,GA
27380-H2600 CLOCK ASS'Y GX
 85-10612-42 SCREW (8) 4-speed
 89-15436-42 WASHER-plain (7) 4-speed
 89-15536-42 WASHER-plain (1) 4-speed
74982-H2600 MASK-console box body SGA [single hole]
74982-H2601 MASK-console box body GX, (op.) Sedan [three hole]
