Automatic Transmission Control Part Numbers
Revision as of 04:14, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Automatic Shifter
1 34902-H1900 ASSY-HAND LEVER & BRACKET AUTOMATIC
2 34903-H1900 ASSY-BRACKET HAND LEVER AUTOMATIC
3 34907-25820 BUSH-HAND LEVER BRACKET (2) AUTOMATIC
4 34909-H1100 PACKING-HAND LEVER BRACKET AUTOMATIC
5 34915-H1100 ASSY-SUPPORT HAND LEVER AUTOMATIC
6 34946-H0300 SPRING-RETURN SELECT AUTOMATIC
7 34912-H1100 LEVER-HAND AUTOMATIC
8 34919-25820 KNOB-HAND LEVER AUTOMATIC
8 34919-H1000 KNOB-HAND LEVER AUTOMATIC 1171- 2 34919-25820
9 34923-25820 SCREW-HAND LEVER AUTOMATIC
10 34947-25820 PIN-SELECT AUTOMATIC
11 18136-61503 RING-SNAP"E" (2) AUTOMATIC
12 34913-H1900 ASSY-SHAFT HAND LEVER AUTOMATIC
13 34434-89900 SCREW-LOCK AUTOMATIC
14 00851-21610 WIRE-LOCK AUTOMATIC
15 08360-82014 SCREW-MACHINE M8X1.25 (4) AUTOMATIC
16 34932-H2520 COMP-SHAFT ROD AUTOMATIC
17 34552-89900 INSULATOR-ROD (2) AUTOMATIC
18 34419-04100 WASHER-SPRING (2) AUTOMATIC
19 34485-14805 PIN-SPRING (2) AUTOMATIC
20 34951-H2520 ASSY-CROSS SHAFT AUTOMATIC
21 34952-H1100 COMP-BRACKET CROSS SHAFT AUTOMATIC
22 34462-18000 BUSH-SPHERICAL CROSS SHAFT (2) AUTOMATIC
23 34965-25820 COVER-OUTER RH CROSS SHAFT AUTOMATIC
24 34966-25820 COVER-INNER RH CROSS SHAFT AUTOMATIC
25 34463-14806 SPRING-RETURN CROSS SHAFT AUTOMATIC
26 34467-84700 BOOT-OUTER CROSS SHAFT AUTOMATIC
27 74941-89900 COVER-OUTER LH CROSS SHAFT AUTOMATIC
28 34936-H1100 COMP-SHAFT ROD LOWER AUTOMATIC
29 34938-25820 PIN-SHAFT ROD AUTOMATIC
30 34948-25820 RING-SNAP 'E' TYPE AUTOMATIC
31 34410-21000 TRUNION-GEAR SHAFT ROD AUTOMATIC
32 34552-89900 INSULATOR-ROD AUTOMATIC
33 01311-00021 WASHER-PLAIN (2) AUTOMATIC
34 34419-04100 WASHER-SPRING AUTOMATIC
35 34485-14805 PIN-SPRING AUTOMATIC
36 08911-14010 NUT-HEX M10X1.25 (2) AUTOMATIC
