Synchro is basically:
Coupling with hub Baulk rings and gear faces
Coupling with hub. Left: assembled. Right: not assembled
1st & 2nd gear. Center arrow points to the Coupling Collar
56-Series Transmission
4-speed and 5-speed synchronizers are very different See 56-Series_Transmission_Parts#Synchros
4-speed 32604-H1000 RING-BAULK (4) <> 32604-H1010 < 32604-H9000 32609-18000 INSERT-SHIFTING (6) 32603-18000 SPRING-SYNCHRONIZER (4) 32601-18000 HUB-SYNCHRONIZER (2) 32606-18000 SLEEVE-COUPLING (2)
5-SPEED 32601-H7200 HUB-SYNCHRONIZER (2) 32606-H7200 SLEEVE-coupling (2)
60-Series Transmission
FS5W60L 32604-H9000 RING-BAULK 4 32603-18000 RING-SYNCHRONIZER 4 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD 1 32609-18000 INSERT-SHIFTING 6
32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3 * unique to F5W60L 32608-H9000 INSERT-SHIFTING 9 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE 1
