Cowl Part Numbers
Revision as of 05:34, 28 June 2012; view current revision
Categories: Body | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Cowl
Cowl Top Grille
Includes Sedan.1972 & Truck
18 66810-H1001 PLATE-baffle, cowl top (R.H.)
19 66811-H1001 PLATE-baffle, cowl top (L.H.)
1 66301-H1000 PANEL-COWL TOP -8012 <> 66301-H3100
  66301-H3100 PANEL-COWL TOP from 71-12 (truck) 71.1 (sedan)
  66301-G1500 PANEL-COWL TOP -8012
  66301-G1900 PANEL-COWL TOP 8101-
2 65433-H1000 SEAL-HOOD HINGE (2)
3 GRILLE-COWL TOP RH
  66802-H1002 S-std, T
  66802-H1001 S-DX,S-GL
  S-GX
   66802-H2303 #930 Green
   66802-H2304 #931 Gold
   66802-H2305 #932 Red
   66802-H2306 #821 White
   66802-H2307 #665 Yellow
   66802-H2308 #929 Blue
   66802-H2311 #003 Green
   66802-H2312 #004 Metallic green
   66802-H2313 #005 Metallic turkois
   66802-H2315 #117 Gray
   66802-H2316 #554 Green
4 GRILLE-COWL TOP LH
  66803-H1002 S-std, T
  66803-H1001 S-DX,S-GL
  S-GX
   66803-H2303 #930 Green
   66803-H2304 #931 Gold
   66803-H2305 #932 Red
   66803-H2306 #821 White
   66803-H2307 #665 Yellow
   66803-H2308 #929 Blue
   66803-H2311 #003 Green
   66803-H2312 #004 Metallic green
   66803-H2313 #005 Metallic turkois
   66803-H2315 #117 Gray
   66803-H2316 #554 Green
5 SCREW-TAPPING M4 FOR GRILLE FITTING (per side)
  08530-41212 (6) S-std, T
  08530-41290 (6) S-DX,S-GL
  08530-41290 (3) S-GX
  08530-41690 (2) S-GX
7 66822-H1000 SEALING RUBBER-COWL TOP,FRONT (66810)
Sedan
1 66301-H1600 PANEL-COWL TOP SEDAN
2 65433-H1000 SEAL-HOOD HINGE (2) SEDAN
3 66802-H2313 GRILLE-COWL TOP RH TURKOIS #005 SEDAN(DX) 1270-
3 66802-H2314 GRILLE-COWL TOP RH ORANGE #006 SEDAN(DX) 1270-
3 66802-H2312 GRILLE-COWL TOP RH GREEN #004 SEDAN(DX) 1270-
3 66802-H1001 GRILLE-COWL TOP RH SEDAN(DX)
4 66803-H2312 GRILLE-COWL TOP LH GREEN #004 SEDAN(DX) 1270-
4 66803-H2313 GRILLE-COWL TOP LH TURKOIS #005 SEDAN(DX) 1270-
4 66803-H2314 GRILLE-COWL TOP LH ORANGE #006 SEDAN(DX) 1270-
4 66803-H1001 GRILLE-COWL TOP LH SEDAN(DX)
5 08510-41212 SCREW-TAPPING TYPE 1 M4X12 1 (12) SEDAN
6 66822-H1000 RUBBER-SEALING HOOD REAR SEDAN
7 66810-H1001 PLATE-BAFFLE COWL TOP RH SEDAN
8 66811-H1001 PLATE-BAFFLE COWL TOP LH SEDAN
Coupe
1 66301-H1600 PANEL-COWL TOP COUPE
2 65433-H1000 SEAL-HOOD HINGE (2) COUPE
3 66802-H1806 GRILLE-COWL TOP RH WHITE #821 COUPE
3 66802-H1807 GRILLE-COWL TOP RH YELLOW #665 COUPE
3 66802-H2307 GRILLE-COWL TOP RH YELLOW #665 COUPE 1170- 4 66802-H1807
3 66802-H1809 GRILLE-COWL TOP RH BLUE #645 COUPE
3 66802-H2309 GRILLE-COWL TOP RH BLUE #645 COUPE 1170- 4 66802-H1809
3 66802-H1810 GRILLE COWL TOP RH GREEN #940 COUPE
3 66802-H2311 GRILLE-COWL TOP,RH,GREEN #003 COUPE
3 66802-H2305 GRILLE-COWL TOP RH RED #932 COUPE 1170- 4 66802-H1805
3 66802-H2314 GRILLE-COWL TOP,RH,ORANGE #006 COUPE
3 66802-H2310 GRILLE COWL TOP RH GREEN #940 COUPE 1170- 4 66802-H1810
3 66802-H2301 GRILLE-COWL TOP RH YELLOW #926 COUPE 1170- 4 66802-H1801
3 66802-H2306 GRILLE-COWL TOP RH WHITE #821 COUPE 1170- 4 66802-H1806
3 66802-H1805 GRILLE-COWL TOP RH RED #932 COUPE
3 66802-H1801 GRILLE-COWL TOP RH YELLOW #926 COUPE
3 66802-H1800 GRILLE-COWL TOP RH WHITE #924 COUPE
3 66802-H1802 GRILLE-COWL TOP RH GRAY #928 COUPE
3 66802-H2302 GRILLE-COWL TOP RH GRAY #928 COUPE 1170- 4 66802-H1802
3 66802-H1803 GRILLE-COWL TOP RH GREEN #930 COUPE
3 66802-H2303 GRILLE-COWL TOP RH GREEN #930 COUPE 1170- 4 66802-H1803
3 66802-H1804 GRILLE-COWL TOP RH GOLD #931 COUPE
3 66802-H2304 GRILLE-COWL TOP RH GOLD #931 COUPE 1170- 4 66802-H1804
3 66802-H2300 GRILLE-COWL TOP RH WHITE #924 COUPE 1170- 4 66802-H1800
4 66803-H1809 GRILLE-COWL TOP LH BLUE #645 COUPE
4 66803-H1806 GRILLE-COWL TOP LH WHITE #821 COUPE
4 66803-H2306 GRILLE-COWL TOP LH WHITE #821 COUPE 1170- 4 66803-H1806
4 66803-H1807 GRILLE-COWL TOP LH YELLOW #665 COUPE
4 66803-H2307 GRILLE-COWL TOP LH YELLOW #665 COUPE 1170- 4 66803-H1807
4 66803-H2309 GRILLE-COWL TOP LH BLUE #645 COUPE 1170- 4 66803-H1809
4 66803-H1810 GRILLE-COWL TOP LH GREEN #940 COUPE
4 66803-H2311 GRILLE-COWL TOP,LH,GREEN #003 COUPE
4 66803-H2314 GRILLE-COWL TOP,LH,ORANGE #006 COUPE
4 66803-H2305 GRILLE-COWL TOP LH RED #932 COUPE 1170- 4 66803-H1805
4 66803-H2300 GRILLE-COWL TOP LH WHITE #924 COUPE 1170- 4 66803-H1800
4 66803-H1801 GRILLE-COWL TOP LH YELLOW #926 COUPE
4 66803-H1805 GRILLE-COWL TOP LH RED #932 COUPE
4 66803-H2301 GRILLE-COWL TOP LH YELLOW #926 COUPE 1170- 4 66803-H1801
4 66803-H1800 GRILLE-COWL TOP LH WHITE #924 COUPE
4 66803-H1802 GRILLE-COWL TOP LH GRAY #928 COUPE
4 66803-H2302 GRILLE-COWL TOP LH GREEN #928 COUPE 1170- 4 66803-H1802
4 66803-H1803 GRILLE-COWL TOP LH GREEN #930 COUPE
4 66803-H2303 GRILLE-COWL TOP LH GREEN #930 COUPE 1170- 4 66803-H1803
4 66803-H1804 GRILLE-COWL TOP LH GOLD #931 COUPE
4 66803-H2304 GRILLE-COWL TOP LH GOLD #931 COUPE 1170- 4 66803-H1804
5 08530-41212 SCREW-TAPPING M4 FOR GRILLE FITTING (6) COUPE
6 08530-41612 SCREW-TAPPING M4 FOR GRILLE FITTING (6) COUPE
7 66822-H1000 RUBBER-SPONGE HOOD REAR COUPE
8 66810-H1001 PLATE-BAFFLE COWL TOP RH COUPE
9 66811-H1001 PLATE-BAFFLE COWL TOP LH COUPE
