Axle Shaft
Revision as of 00:45, 31 October 2012; view current revision
Datsun 1200 axle shafts come in two sizes: H145 for all cars, and H165 units for all 1200 Trucks. Both are 23-spline axles, although the truck axles are a larger diameter and so they do not interchange.
Bearing Replacement
The bearing is held on a by a collar (a plain ring). This has to cut off with a cold chisel, then a new one pressed on.
Bearing held on by shaft collar
When replacing a rear axle bearing, check the wheel bearing-to-housing end face clearance and adjust with shims.
Wheel Bearing Packing
Axle Seal
Suppliers - USA
Axle
  • 38162-G0300 ASSY-SHAFT REAR AXLE B110, B210
  • 38162-H8500 SHAFT ASSY-REAR AXLE(L=612) B310
  • 38162-G1000 SHAFT ASSY-REAR AXLE B120 7510- with H165 diff
    • Also B210 H165B with L16 engine
Axle Seal
Datsun 1200 uses the same rear axle/wheel hub seal as Datsun 510. One is required for each side of the car. The same seal is used by H145 (1200 car) and H165 (1200 truck) rear axle assemblies.
Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
* formerly 43252-18000
* alternate manufacturer: 43252-H1010
Aftermarket
SKF OS550232
BECK/ARNLEY 0521583 (052-1583)
   size 41x58x4
* FITS many Nissan/Datsun including:
  * 1200 sedan/coupe/wagon/truck
  * Datsun B10 Datsun 1000
  * Datsun 510/610
  * Datsun S10 200SX 1977-1979
  * Datsun A10 1978-1981 (Stanza/510/Violet)
  * Nissan D21,D21U,D22 Nissan pickups 1986-2000 some
  * Nissan R50 "Pathfinder" rear outer "Grease Hub Seal"
  * Nissan WD21,WD22 "Pathfinder"
    43252-0W000
  * Nissan/Datsun 810/910 wagon (810/Maxima/Bluebird)
  * S110 1984 200SX w/CA20E engine SELECT USE
Axle Bearing
H145
  • Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
    Required when replacing the bearing. The collar is cut in two to release the bearing, and the new collar pressed on.
  • Nissan 43215-18000 BEARING-REAR AXLE
    • SKF GRW115R Schuck's
    • KOYO 83294C4
    • NSK B32-3CC5
    • NTN 6206BLUX/32C4 $28 USD
Interchange:
  • 1967-1970 Datsun B10 (180 is B10 part number)
  • 1970-1973 Datsun B110
Specs:
  • O.D.: 62.000 (mm)
  • Bore: 30.000 (mm)
    •  ?? 32 mm
  • Width: 16.000 (mm)
H150/H165
  • 43215-H5000 BEARING-REAR AXLE, OUTER B120 7510-, B210 H150
