Hitachi D4R Distributor
Revision as of 10:59, 10 January 2012; view current revision
Categories: Engine Electrical System | Ignition Modifications
The Hitachi D4R electronic distributors are used by the early E-series engines. These can these be modified to work in A-series engines. See E15 Electronic Distributor Swap for details.
These have an inboard transistor ignition unit, compared to earlier 1978-1982 A-series USA distributors with the outboard "matchbox" ignition.
Interior High-Energy Ignition Unit
Compare to older Exterior Matchbox (Hitachi D4K)
Variations
D4R80
22162-15M01 CAP ASSY-DISTRIBUTOR
N10 E15S USA, N12 E16S USA, B11 E15S+E16S
22157-H9560 ROTOR-HEAD
22163-15M00 STATOR [Sheet metal type]
22115-15M00 SIGNAL ROTO ASSY [Reluctor]
22136-21M00, 22136-D4700 PLATE ASSY-BREAKER
22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring]
22108-15M00 SHAFT ASSY [weight & spring shaft]
22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT
22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine
22132-21M00 CAM SET
D4R82
Appears to be very similar to D4R80.
0882-0588 B11 E15S+E16S USA, 0285-0986 N12 E16S USA
0882-0986 N12 USA
DISTRIBUTOR ASSY
* 22100-32M01,22100-32M01 HITACHI D4R82-24
* 22100-32M03,22100-32M04 HITACHI D4R82-24 W/VENT
* 22100-33M01,22100-33M02 HITACHI D4R82-12
* 22100-33M03,22100-33M04 HITACHI D4R82-12 W/VENT
* 22100-34M01,22100-34M02 HITACHI D4R82-13
* 22100-34M03,22100-34M04 HITACHI D4R82-13 W/VENT
22162-15M02 CAP ASSY-DISTRIBUTOR
22162-15M03 CAP ASSY-DISTRIBUTOR
22162-15M04 CAP ASSY-DISTRIBUTOR
22162-52A01 CAP ASSY-DISTRIBUTOR
22157-03A00 ROTOR-HEAD
(22173)22159-11M00,22159-11M03,22159-11M05,22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring]
22108-15M00, 22108-11M03 SHAFT ASSY [weight & spring shaft]
22132-33M00 CAM SET
22132-33M03 CAM SET
22132-34M00 CAM SET
D4R83
D4R83 is a great Hitachi distributor, used on 1980s Nissans and Hondas. The austin boys swap them into A-series engines too.
D4R83-39
20213.jpg D4R83-36 shaft with no collar
20215.jpg D4R83-30 shaft with collar
For Hitachi D4R Distributor
** Master Pro 2-4870A
** BWD C708
** Beck/Arnley 174-6861
** ACDelco E303E
CAP & ROTOR KIT
* Bosch 06089
Fits these USA models
** 1982 Datsun 310 (N10) E15
** 1983 Datsun Pulsar (N12) E16
** 1983-1986 Datsun Pulsar NX (KN13) E16
** 1982-1986 Datsun Sentra (B11) E15S,E16
** 1983-1984 Subaru Brat 1800,1800 Turbo
** Master Pro 2-3774
** BWD D575
** BWD D680 "Nascar"
Fits:
* 1976 Accord
* 1975-1975 Civic
* Many Datsun. See B-210_Electronic_Distributor_Swap#Rotor
22132-21M00 CAM SET
D4P
See Hitachi D4P Distributor
