Large park-bench bumpers were optional in Japan. As always from 1974, North America got the large 'park bench' bumpers while other countries got still-boxy but lighter bumpers.
Front
Worldwide B310 have lights in the front bumper. North American bumpers have no lights.
1-piece bumpers * All Sedan, Coupe (except OPTION) * All Van (VB310) * Not used for North America
3-piece bumpers * All Wagon (WB310) * OPTION Sedan, Coupe Round-eye late 7812- * OPTION Sedan, Coupe Square-eye * All North America
Round-eye 1978-1979 Square-eye 1980-1982 Japan Van (VB310) all round-eye early Sedan, Coupe: round-eye 7711-7909 late Sedan, Coupe: square-eye 7910- Wagon (WB310) round-eye or square-eye came only with 3-piece bumper
One-piece Bumpers
Early bumpers are one-piece, but continued to be used even after other styles were introduced. In Japan, they were used on all B310 except Wagon (WB310).
62022-H8500 Plain Bumper
All metal 62022-H8500 (Lower Trim levels in Japan)
62022-H8500 - all years JDM Van (squareback)
62022-H8500 Sedan Round Eye, Sedan Square Eye (CT, City DX, DX only)
62022-H8500 Coupe DX (round eye), Coupe ES (square eye), Coupe Sport (1980)
62022-H8900 Luxe Bumper
Round Eye One-piece with rubber-covered ends (GL,GX Coupe & Sedan)
62022-H8560 Luxe Square Eye
From 1979 OCT has rubber strip along bumper front top edge
Note the orange coupe has the Strip removed, but the holes are visible
Misc
Rubber bumper ends with Overriders (not used in Japan)
Custom: Silver painted metal bumper (old-style STD look). B310 didn't use painted bumpers like B110 standard, but it makes for an interesting appearance.
Custom: Fiberglass (FRP) reproduction of metal bumpers. These particular ones are a hybrid design with large wraparound ends shaped like the 3-piece rubber extensions.
Custom: Big-bumper model retrofitted with small bumpers. Note the large openings behind the bumpers.
Three-piece Bumpers
Wagon (WB310 "Sunny California") * OPTION A14/A15 Sedan, A14/A15 Coupe * NOT AVAILABLE Van (VB310)
Also available in (JDM OPTION) version mounted with shock absorbers.
3-piece bumpers are much heaver with a complex cross-section. The shape of the bumper ends are different too.
62022-H8905 Round Eye
Round Eye (late) 62022-H8905. W/O rubber strip along top edge.
7901-7909 * WB310 Sunny California * not available VB310 * OPTION A14 Sedan, A14 Coupe
62022-H9936 Square Eye
Square Eye 62022-H9936. Has rubber strip along top front edge.
7910- * Sunny California (WB310) * not available VB310 * OPTION A14/A15 Sedan, A14/A15 Coupe
Blackout
Rubber covered bumpers -- not clear if these are 1-piece or 3-piece.
North America
Canada & USA - no lights in bumper
1979 (round headlamp) has rubber overriders
1980-1982 has rubber strip instead of protruding overriders
BUMPER-FRONT CENTER -1179 62022-H9100 62050-H9100 OVER RIDER ASSY-BUMPER 1279- 62022-H9900/62022-H9930 62060-H9900 RUBBER STRIP ASSY-FRONT BUMPER SIDE ASSY-FRONT 62032-H9100 RH, 62033-H9100 LH
Customized with 1979 bumper on later B310
Rear
Large Bumpers * Japan Wagon (reverse lamps in bumper) * Japan OPTION for Sedan, Coupe * North America all (no reverse lamps in bumper)
Small Bumpers * Coupe, Sedan early type with number plate cutout * Coupe, Sedan late type without cutout * Van
Sedan & Coupe
Early Small Bumpers
Early type locates the number plate below the bumper. Early cars also have round headlights.
Number plate cutout * Wide for Australia, Holland, UK, etc. * Narrow for Japan, Malaysia, etc.
Early GL style - Rubber bumper ends
Custom: FRP replica bumper, color matched to car
Late Small Bumpers
Late type locates the number plate above the bumper. Late cars also have square headlights.
Late GL type - rubber bumper ends
Large Bumper
Large bumpers have no cutout for number plate and side-lit plate
No number plate lamps or reverse lamps in bumper like North America
VB310
VB310 Van bumper has no cutout for number plate.
Wagon
WB310 Wagon has large park-bench style bumper
Japan Small Bumpers
Van - no number plate cutout Sedan, Coupe Round Eye - narrow plate number cutout Sedan, Coupe Square Eye - no number plate cutout
all metal ES,CT,DX rubber ends GL,GX,RSE
Van 85022-H9400 Van - all round eye
Round Eye All metal 85022-H8500 DX,CT
Round Eye Rubber-ended 85022-H8900 GL,GX & 85022-H8901 GL,GX
Square Eye 85022-H8565/85022-H8565 ES,CT,DX
Square Eye 85022-H8560/85022-H8561 GL,GX - rubber strip at top
NOTE side-lit number plate
Japan Large Bumpers
Wagon and OPTION (shock absorbed) for Sedan, Coupe has the reverse lamps in the bumper.
JDM Wagon round-eye 85022-H9800 7901-7909 no overriders
JDM Wagon square-eye 85022-H9905 7910- strip overrider
JDM OPTION for Sedan, Coupe (shock absorbed park-bench type)
* Round Eye (late) 85022-H9100 7812-7909
* Square Eye 85022-H9900 7910-
North America
North America used same bumper for all models (Sedan, Wagon, Coupe same). It is a large 5 mph crash-resistant shock-absorbing type. Just like the Japan OPTION bumper, except there are no reverse lamps in the North American bumper.
Round Headlamp cars use rubber overriders
Square Headlamp cars use rubber strip instead of overriders
Round Headlight -1179 62050-H9100 OVER RIDER-BUMPER 85022-H9100 BUMPER CENTER-REAR -0779 85022-H9901 BUMPER CENTER-REAR 0879-1179 <> 85022-H9100 Square Headlight 1279- 85060-H9900 RUBBER STRIP ASSY-FRONT 85022-H9900 BUMPER CENTER-REAR 85022-H9930 BUMPER CENTER-REAR <> 85022-H9900
