Fuel Shut-Off System
Revision as of 12:53, 13 January 2012; view current revision
Category: Fuel System
The Fuel Shut-Off System was introduced in some 1980 B310 USA models. It leverages the anti-diesel valve to stop the fuel flow during periods of deceleration. This is similar to what EFI systems do. It is only active at higher speeds, namely above 40mph.
1980: All California models
1980: FED A15.MT
1981 CAL, FED, FED.MPG and CAN.MPG models.
  Canada models did not use fuel-shut off except for
  MPG (FU Engine) models.
For safety and good performance, the FSOS does not work unless the engine is decelerating.
  • Only works when decelerating (vacuum is high AND speed above 40mph)
  • Does not work in nuetral, so engine will not stop due to lack of fuel
  • Does not work when clutch is engaged (so you can blip the throttle)
Components are:
  • Anti-diesel valve (solenoid)
  • Vacuum valve
  • Speedometer speed switch, amplifier and relay
  • Automatic Transmission inhibitor switch
  • Manual Transmission nuetral switch
  • Clutch pedal switch
This would be an interesting system to retrofit to older models for increased fuel economy.
