Toyota overdrive 5-speeds are light, strong and readily available. Most have ratios are closer the common Datsun 5-Speeds. But you need to adapt it to the A-series engine as it uses a different bellhousing bolt pattern.
Also see: T50 5-speed
The Toyota gearboxes, being of the split case design, make it easier to maintain should you be the type to switch gearsets or perform your own overhauls. Toyota and aftermarket suppliers offer a large range of different gear ratios to suit your needs. It has a shorter throw.
Sources
T40 (A3) T50 (4AGE) W50 (Celica) W58 (Supra)
Ratios
1 2 3 4 5 R T40 (A3) 3.587 2.022 1.384 1.000 ----- 3.484 T50 (4AGE) 3.587 2.022 1.384 1.000 0.861 3.484 W50 (Celica) 3.566 2.056 1.384 1.000 0.850 4.091 W58 (Supra) 3.285 1.894 1.275 1.000 0.783 3.768
http://www.dellowauto.com.au - Download the catalogue and it gives you some info on the type of box and what ratios are in it.
Dellow Swap Kit
Dellow Engineering (Australia) sells an installation kit to fit a T50 five-speed into Datsun 1200.
See main article: T50 5-speed
Dellow also makes adapters for Rover/Buick V8 to Toyota Supra W57/W58 gearboxes for your more radical Datsun 1200 swaps.
W50 Adapter Plate
Bolt an adapter plate to a Celica W50 gearbox, then bolt A-series automatic bellhousing to it.
