B210 van and B210 coupe both used a tail gate. The Coupe tail gate is more commonly called the hatch or liftgate.
Coupe Tail Gate
DX came with hatch struts, to keep the hatch open when lifted. GL & GX hatch struts came with switches to turn the light on.
90100-H5500 ASSY-PANEL,TAIL GATE COUPE 90810-H5501 WEATHERSTRIP-tail gate <> 90810-H5500
TAIL GATE TRIMMING (underside of hatch) 90900-H5500 FINISHER-tail gate (Black) 90900-H5501 FINISHER-tail gate (Brown) 01553-00211 CLIP-trim (Black) (11) 01553-00221 CLIP-trim (Brown) (11)
Hatch Struts
Tail Gate Stay 90210-H5550 BALANCER KIT-tail gate (R.H.) K-GX,K-GL,(op.)K-DX, USA ALL 90211-H5550 BALANCER KIT-tail gate (L.H.) K-GX,K-GL,(op.)K-DX, USA ALL 90210-H5500 BALANCER ASS'Y-tail gate (R.H.) K-DX $175 USD 90211-H5500 BALANCER ASS'Y-tail gate (L.H.) K-DX $175 USD
Aftermarket * SACHS Stabilus SG225004 $17 USD Rockauto, $21 USD O'ReillyCONNECTION Ball Socket End Extended Length 24" Compressed Length 15" Lower Mount Type: Ball Socket Upper Mount Type: Ball Socket Travel Length (In): 8.504 Inch * AMS AUTOMOTIVE 4729 Hatch Lift
Extended Length (inches) 23.88 Compressed Length (inches) 14.81 Stroke (inches) 9.07 Pounds of Force 46 Shaft Diameter (mm) 8 Body Diameter (mm) 22 Shaft Connection U-Blade Body Connection U-Blade
B310
1979-1982 Rockauto.com B310 WAGON * AMS AUTOMOTIVE 4853 Extended Length (inches) 25.24 Compressed Length (inches) 15.37 Stroke (inches) 9.87 Pounds of Force 78 Shaft Diameter (mm) 10 Body Diameter (mm) 22 Shaft Connection Ball Socket (Nylon) 10mm Body Connection Ball Socket (Nylon) 10mm Internal Spring With Internal Spring * SACHS SG225007 $28 USD O'Reilly CONNECTION Ball Socket End Extended Length 25" Compressed Length 16"
B310 SEDAN * SACHS SG325006 CONNECTION Eyelet End Extended Length 20" Compressed Length 13" * AMS AUTOMOTIVE 4429 Extended Length (inches) 20.25 Compressed Length (inches) 13.15 Stroke (inches) 7.10 Pounds of Force 61 Shaft Diameter (mm) 8 Body Diameter (mm) 19 Shaft Connection Off-Set Blade (.318 dia. hole) Body Connection Off-Set Blade (.318 dia. hole)
