Also see:
Part Numbers Index Main article for usage, photos, cross-reference Rear Brake
Late Truck
From 1989 October
Fastening to axle housing flange 08915-23810 WASHER (8) 08912-43810 NUT (8) 44000A BOLT 44005-U1400 (8)
44000M BRAKE ASSY-DRUM,REAR RH 44000-G1210 44010M BRAKE ASSY-DRUM,REAR LH 44010-G1210 ------------------------------------ 44020 PLATE ASSY-BACK,REAR BRAKE RH 44020-G1210 44020G PLUG 41098-70A10 44030 PLATE ASSY-BACK,REAR BRAKE LH 44030-G1210 44060K SHOE SET-REAR BRAKE 44060-G1225 44081-M4901 PIN-ANTI SHOE RATTLE 4 44083-W5200 SPRING-ANTI SHOE RATTLE 4 44090-M4900 SPRING-RETURN,REAR BRAKE SHOE 2 44091-M4900 SPRING-RETURN,REAR BRAKE SHOE (2) 44100B 01436-00052 BOLT (4) 44100K CUP KIT-BRAKE WHEEL CYLINDER,REAR D4100-D5590 NABCO 3/4 (1) D4100-G2893 TOKICO 3/4 (1) ---------------------------------- 44100P CYLINDER ASSY-REAR WHEEL 44100-D5510 (2) 44108 PISTON-CYLINDER (4) 44108-D0101 NABCO 44108-G2810 TOKICO 44112 CUP-PISTON (4) 44112-PO201 NABCO 44112-P0211 TOKICO 44124 COVER-DUST (4) 44124-D5500 NABCO 44124-17C10 TOKICO 44125 SPRING (2) 44125-M7010 TOKICO 44125-U9200 NABCO 44127 BOOT 44095-M4910 (2) 44128-U5200 SCREW-BLEEDER NABCO 44129-A2410 CAP-BLEEDER SCREW TOKICO ---------------------------------- 44200N ADJUSTER ASSY-REAR BRAKE 44200-W5211 RH 44201-W5211 LH 44211-H8300 STOPPER-ADJUSTER LEVER 44212-H8300 FASTENER-ADJUSTER ------------------------------------
Disc/Drum Setup
1 44000-H3300 ASSY-BRAKE REAR RH FOR FR DISC OP 0273- 2 44000-H0500 1 44000-H0500 ASSY-BRAKE REAR RH FOR FR DISC OP -173 3 2 44010-H0500 ASSY-BRAKE REAR LH FOR FR DISC OP -173 3 2 44010-H3300 ASSY-BRAKE REAR LH FOR FR DISC OP 0273- 2 44010-H0500 3 44020-27700 ASSY-DISC REAR BRAKE RH OP 4 44030-27700 ASSY-DISC REAR BRAKE LH OP 5 44060-18000 ASSY-SHOE REAR BRAKE FORE (2) OP 6 44070-18000 ASSY-SHOE REAR BRAKE AFTER (2) OP 7 41066-18000 LINNING-BRAKE (4) OP 8 44081-18000 PIN-ANTI SHOE RATTLE (4) OP 9 44082-32200 SEAT-SPRING ANTI SHOE RATTLE (4) OP 10 44083-32200 SPRING ANTI SHOE RATTLE (4) OP 11 44084-32201 RETAINER-SHOE RATTLE (4) OP 12 44090-18000 SPRING-RETURN RR BRAKE SHOE CYLINDER (2) OP 13 44091-18000 SPRING-RETURN RR BRAKE SHOE ADJUST (4) OP 14 44100-H3300 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP 0273- 2 44100-H0500 14 44100-H0500 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP -172 2 15 44112-18800 CUP-PISTON(NABCO) (2) OP 15 44112-H3300 CUP-PISTON (NABCO) (2) OP 2 44112-18800 15 44112-16510 CUP-PISTON (TOKIKO) (2) OP 0273- 16 44108-18800 PISTON-CYLINDER(NABCO) (2) OP 16 44108-H0510 PISTON-CYLINDER (TOKIKO) (2) OP 0273-0173 3 17 44113-31700 RING-SNAP(NABCO) (2) OP -173 3 17 44113-U4000 RING-SNAP (NABCO) (2) OP 0273- 0 44113-31700 17 44113-U4010 RING-SNAP (TOKIKO) (2) OP 0273- 18 44118-18000 ASSY-LEVER(NABCO) (2) OP 18 44118-21910 ASSY-LEVER (TOKIKO) (2) OP 0273- 19 44124-U4000 COVER-DUST'A' (NABCO) (2) OP 0273- 19 44124-U4010 COVER-DUST'A' (TOKIKO) (2) OP 0273- 19 44124-31700 COVER-DUST'A'(NABCO) (2) OP -173 3 20 41128-21900 SCREW-BLEEDER(NABCO) (2) OP -173 3 20 41128-U0201 SCREW-BLEEDER (NABCO) (2) OP 0273- 0 41128-21900 20 41128-U0512 SCREW-BLEEDER (TOKIKO) (2) OP 0273- 21 41129-A2410 CAP-BLEEDER(NABCO) (2) OP -173 3 21 41129-U0201 CAP-BLEEDER (NABCO) (2) OP 0273- 0 41129-A2410 21 41129-30001 CAP-BLEEDER (TOKIKO) (2) OP 0273- 21 41129-40F00 CAP-BLEEDER (TOKIKO) (2) OP 0273- 41129-30001 22 44141-31700 PLATE-LOCK(NABCO) (2) OP -173 3 22 44141-U4000 PLATE-LOCK (NABCO) (2) OP 0273- 0 44141-31700 22 44141-U4010 SHIM-ADJUSTING'A' (TOKIKO) (2) OP 0273- 23 44142-31700 PLATE BACK UP(NABCO) (2) OP -173 3 23 44142-U4000 PLATE-BACK UP (NABCO) (2) OP 0273- 0 44142-31700 23 44142-31710 SHIM-ADJUSTING'B' (TOKIKO) (2) OP 0273- 24 44149-31700 SHIM ADJUSTING'A'(NABCO) (2) OP -173 3 24 44149-H3300 SHIM-ADJUSTING'A' (NABCO) (2) OP 0273- 0 44149-31700 24 44149-U4010 PLATE-LOCK (TOKIKO) (2) OP 0273- 25 44150-31700 SHIM ADJUSTING'B'(NABCO) (2) OP 26 44144-18000 COVER-DUST'B'(NABCO) (2) OP -173 3 26 44144-U4000 COVER-DUST'B' (NABCO) (2) OP 0273- 0 44144-18000 26 44144-U4010 COVER-DUST'B' (TOKIKO) (2) OP 0273- 27 44100-H0525 KIT-REPAIR WHEEL CYLINDER"A"(NABCO) (2) OP -173 3 27 44100-H3325 KIT-REPAIR WHEEL CYLINDER (NABCO) (2) OP 0273- 0 44100-H0525 27 44100-H3327 KIT-REPAIR WHEEL CYLINDER (TOKIKO) (2) OP 0273- 28 44100-H0526 KIT-REPAIR WHEEL CYLINDER"B"(NABCO) (2) OP -173 3 29 44200-18000 ASSY-ADJUSTER REAR BRAKE (2) OP 30 44204-18000 WEADGE-ADJUSTER (2) OP 31 44205-18000 TAPPET-ADJUSTER (4) OP 32 08915-13610 WASHER-LOCK M6 (4) OP 33 08911-10610 NUT-HEX M6X1.0-2 (4) OP
