Also see:
Part Numbers Index Main article for usage, photos, cross-reference Rear Brake
Early
Up to 1973 February
COMPLETE ASSEMBLIES Use with front disc brakes (GL, GX) 44000-H0500 ASS'Y-BRAKE, rear (R.H.) 44010-H0500 ASS'Y-BRAKE, rear (L.H.) Use with front drum brakes (STD, DX or Van) 44000-27700 ASS'Y-BRAKE, rear (R.H.) 44010-27700 ASS'Y-BRAKE, rear (L.H.)
INDIVIDUAL PARTS
1 backing plate
44020-27700 ASS'Y-DISC, rear brake (R.H.)
44030-27700 ASS'Y-DISC, rear brake (L.H.)
2 44060-18000 ASS'Y-SHOE, rear brake, fore (2)
44060-H0100 ASS'Y-SHOE, rear brake, fore (op.) (2)
3 44070-18000 ASS'Y-SHOE, rear brake, after (2)
44070-H0100 ASS'Y-SHOE, rear brake, after (op.) (2)
4 41066-18000 LINING-brake B40 (4)
41066-H0100 LINING-brake B705B (4) (op.)
5 44081-18000 PIN-anti shoe rattler (4)
6 44082-32200 SEAT-spring (4)
7 44083-32200 SPRING-anti shoe rattler (4)
8 44084-32201 RETAINER-shoe rattler (4)
9 44090-18000 SPRING-return brake shoe, cylinder (2)
10 44091-18000 SPRING-return brake shoe, adjuster (4)
cylinder assemblies
11 44100-18000 ASS'Y-CYLINDER, rear wheel (13/16") STD,DX or Van (2)
44100-H0500 ASS'Y-CYLINDER, rear wheel (11/16") GL,GX (2)
12 44112-71200 CUP-piston (NABCO) (exc. GL,GX) (2)
44124-71610 CUP-piston (TOKICO) (exc. GL,GX) (2)
44112-18800 CUP-piston (NABCO) GL,GX (2)
44112-16510 CUP-piston (TOKICO) GL,GX (2)
13 44108-18000 PISTON-cylinder (NABCO) (exc. GL,GX) (2)
44108-22010 PISTON-cylinder (TOKICO) (exc. GL,GX) (2)
44108-18800 PISTON-cylinder (NABCO) GL,GX (2)
44108-H0510 PISTON-cylinder (TOKICO) GL,GX (2)
14 44113-31700 RING-snap (NABCO) (2)
44113-31710 RING-snap (TOKICO) (2)
15 44118-18000 ASS'Y-LEVER (NABCO) (2)
44118-21910 ASS'Y-LEVER (TOKICO) (2)
16 44124-31700 COVER-dust "A" (NABCO) (2)
44124-31710 COVER-dust "A" (TOKICO) (2)
17 44128-21900 SCREW-bleeder (NABCO) (2)
44128-21010 SCREW-bleeder (TOKICO) (2)
18 44129-30001 CAP-bleeder (2)
19 44141-31700 SHIM-adjusting "A" (NABCO) (2)
44141-31710 SHIM-adjusting "A" (TOKICO) (2)
20 44142-31700 SHIM-adjusting "B" (NABCO) (2)
44142-31710 SHIM-adjusting "B" (TOKICO) (2)
21 44144-18000 COVER-dust "B" (NABCO) (2)
44144-21910 COVER-dust "B" (TOKICO) (2)
22 44149-31700 PLATE-"A" (NABCO) (2)
44149-31710 PLATE-"A" (TOKICO) (2)
23 44150-31700 PLATE-"B" (NABCO) (2)
adjuster assemblies 24 44200-18000 ASS'Y-ADJUSTOR, rear brake (2) ---------------------- 25 44204-18000 WEDGE-adjustor (2) 26 44205-18000 TAPPET-adjustor (2) 27 08915-13610 WASHER-lock, fixing adjustor (4) 27 08911-10610 NUT, fixing adjustor (4) ----------------------
REPAIR KITS Use with front disc brakes (GL,GX) NABCO 44100-H0525 KIT-REPAIR, rear wheel cylinder "A" (NABCO) 44100-H0526 KIT-REPAIR, rear wheel cylinder "B" (NABCO) TOKICO 44100-H0527 KIT-REPAIR, rear wheel cylinder "A" (TOKICO) 44100-H0528 KIT-REPAIR, rear wheel cylinder "B" (TOKICO) Use with front drum brakes (STD,DX or Van) NABCO 44100-18025 KIT-REPAIR, rear wheel cylinder "A" (NABCO) (2) 44100-18026 KIT-REPAIR, rear wheel cylinder "B" (NABCO) (2) TOKICO 44100-G0327 KIT-REPAIR, rear wheel cylinder "A" (TOKICO) (2) 44100-G0328 KIT-REPAIR, rear wheel cylinder "B" (TOKICO) (2)
Mid Model
From 1973 March
COMPLETE ASSEMBLIES 44000-H3100 BRAKE ASS'Y-rear (R.H.) STD,DX 44010-H3100 BRAKE ASS'Y-rear (L.H.) STD,DX 44000-H3300 BRAKE ASS'Y-rear (R.H.) GL,GX 44010-H3300 BRAKE ASS'Y-rear (L.H.) GL,GX
INDIVIDUAL PARTS - same as early (see above)
cylinder assemblies
11 44100-H3100 ASS'Y-CYLINDER, rear wheel (13/16") STD,DX or Van (2)
44100-H3300 ASS'Y-CYLINDER, rear wheel (11/16") GL,GX (2)
14 44113-U4000 RING-snap (NABCO) (2)
44113-U4010 RING-snap (TOKICO) (2)
16 44124-U4000 COVER-dust "A" (NABCO) (2)
44124-U4010 COVER-dust "A" (TOKICO) (2)
17 44128-U0201 SCREW-bleeder (NABCO) (2)
44128-U0512 SCREW-bleeder (TOKICO) (2)
18 44129-U0201 CAP-bleeder (NABCO) (2)
44129-30001 CAP-bleeder (TOKICO) (2)
19 44141-U4000 SHIM-adjusting "A" (NABCO) (2)
44141-U4010 SHIM-adjusting "A" (TOKICO) (2)
20 44142-U4000 SHIM-adjusting "B" (NABCO) (2)
21 44144-U4000 COVER-dust "B" (NABCO) (2)
44144-U4010 COVER-dust "B" (TOKICO) (2)
22 44149-H3300 PLATE-"A" (NABCO) (2)
44149-U4010 PLATE-"A" (TOKICO) (2)
ADJUSTOR ASSEMBLIES - same as early type (see above)
REPAIR KITS 11/16" use with front disc brakes (GL,GX) 44100-H3325 REPAIR KIT-rear wheel cylinder (NABCO) 44100-H3327 KIT-REPAIR, rear wheel cylinder (TOKICO) 13/16" use with front drum brakes (STD,DX or Van) 44100-H3125 KIT-REPAIR, rear wheel cylinder (NABCO) (2) 44100-H3126 KIT-REPAIR, rear wheel cylinder (TOKICO) (2)
Late 1200
From 1989 October - Self-adjusting type
Fastening to axle housing flange 08915-23810 WASHER (8) 08912-43810 NUT (8) 44000A BOLT 44005-U1400 (8)
44000M BRAKE ASSY-DRUM,REAR RH
44000-G1210
44010M BRAKE ASSY-DRUM,REAR LH
44010-G1210
44020 PLATE ASSY-BACK,REAR BRAKE RH
44020-G1210
44020G PLUG
41098-70A10
44030 PLATE ASSY-BACK,REAR BRAKE LH
44030-G1210
44060K SHOE SET-REAR BRAKE
44060-G1225
44081-M4901 PIN-ANTI SHOE RATTLE 4
44083-W5200 SPRING-ANTI SHOE RATTLE 4
44090-M4900 SPRING-RETURN,REAR BRAKE SHOE 2
44091-M4900 SPRING-RETURN,REAR BRAKE SHOE (2)
44100B
01436-00052 BOLT (4)
44100K CUP KIT-BRAKE WHEEL CYLINDER,REAR
D4100-D5590 NABCO 3/4 (1)
D4100-G2893 TOKICO 3/4 (1)
44100P CYLINDER ASSY-REAR WHEEL
44100-D5510 (2)
44108 PISTON-CYLINDER (4)
44108-D0101 NABCO
44108-G2810 TOKICO
44112 CUP-PISTON (4)
44112-PO201 NABCO
44112-P0211 TOKICO
44124 COVER-DUST (4)
44124-D5500 NABCO
44124-17C10 TOKICO
44125 SPRING (2)
44125-M7010 TOKICO
44125-U9200 NABCO
44127 BOOT
44095-M4910 (2)
44128-U5200 SCREW-BLEEDER NABCO
44129-A2410 CAP-BLEEDER SCREW TOKICO
44200N ADJUSTER ASSY-REAR BRAKE
44200-W5211 RH
44201-W5211 LH
44211-H8300 STOPPER-ADJUSTER LEVER
44212-H8300 FASTENER-ADJUSTER
Disc/Drum Setup
complete assembly 1 44000-H3300 ASSY-BRAKE REAR RH FOR FR DISC OP 0273- 2 44000-H0500 1 44000-H0500 ASSY-BRAKE REAR RH FOR FR DISC OP -0173 3 2 44010-H0500 ASSY-BRAKE REAR LH FOR FR DISC OP -0173 3 2 44010-H3300 ASSY-BRAKE REAR LH FOR FR DISC OP 0273- 2 44010-H0500
[individual parts] 3 44020-27700 ASSY-DISC REAR BRAKE RH OP 4 44030-27700 ASSY-DISC REAR BRAKE LH OP 5 44060-18000 ASSY-SHOE REAR BRAKE FORE (2) OP 6 44070-18000 ASSY-SHOE REAR BRAKE AFTER (2) OP 7 41066-18000 LINNING-BRAKE (4) OP * included with brake shoes 8 44081-18000 PIN-ANTI SHOE RATTLE (4) OP 9 44082-32200 SEAT-SPRING ANTI SHOE RATTLE (4) OP 10 44083-32200 SPRING ANTI SHOE RATTLE (4) OP 11 44084-32201 RETAINER-SHOE RATTLE (4) OP 12 44090-18000 SPRING-RETURN RR BRAKE SHOE CYLINDER (2) OP 13 44091-18000 SPRING-RETURN RR BRAKE SHOE ADJUST (4) OP
cylinder assemblies 14 44100-H3300 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP 0273- 2 44100-H0500 14 44100-H0500 ASSY-CYLINDER REAR WHEEL FOR FR DISC (2) OP -172 2 --------------------------------------- 15 44112-18800 CUP-PISTON(NABCO) (2) OP 15 44112-H3300 CUP-PISTON (NABCO) (2) OP 2 44112-18800 15 44112-16510 CUP-PISTON (TOKIKO) (2) OP 0273- 16 44108-18800 PISTON-CYLINDER(NABCO) (2) OP 16 44108-H0510 PISTON-CYLINDER (TOKIKO) (2) OP 0273-0173 3 17 44113-31700 RING-SNAP(NABCO) (2) OP -173 3 17 44113-U4000 RING-SNAP (NABCO) (2) OP 0273- 0 44113-31700 17 44113-U4010 RING-SNAP (TOKIKO) (2) OP 0273- 18 44118-18000 ASSY-LEVER(NABCO) (2) OP 18 44118-21910 ASSY-LEVER (TOKIKO) (2) OP 0273- 19 44124-U4000 COVER-DUST'A' (NABCO) (2) OP 0273- 19 44124-U4010 COVER-DUST'A' (TOKIKO) (2) OP 0273- 19 44124-31700 COVER-DUST'A'(NABCO) (2) OP -173 3 20 41128-21900 SCREW-BLEEDER(NABCO) (2) OP -173 3 20 41128-U0201 SCREW-BLEEDER (NABCO) (2) OP 0273- 0 41128-21900 20 41128-U0512 SCREW-BLEEDER (TOKIKO) (2) OP 0273- 21 41129-A2410 CAP-BLEEDER(NABCO) (2) OP -173 3 21 41129-U0201 CAP-BLEEDER (NABCO) (2) OP 0273- 0 41129-A2410 21 41129-30001 CAP-BLEEDER (TOKIKO) (2) OP 0273- 21 41129-40F00 CAP-BLEEDER (TOKIKO) (2) OP 0273- 41129-30001 22 44141-31700 PLATE-LOCK(NABCO) (2) OP -173 3 22 44141-U4000 PLATE-LOCK (NABCO) (2) OP 0273- 0 44141-31700 22 44141-U4010 SHIM-ADJUSTING'A' (TOKIKO) (2) OP 0273- 23 44142-31700 PLATE BACK UP(NABCO) (2) OP -173 3 23 44142-U4000 PLATE-BACK UP (NABCO) (2) OP 0273- 0 44142-31700 23 44142-31710 SHIM-ADJUSTING'B' (TOKIKO) (2) OP 0273- 24 44149-31700 SHIM ADJUSTING'A'(NABCO) (2) OP -173 3 24 44149-H3300 SHIM-ADJUSTING'A' (NABCO) (2) OP 0273- 0 44149-31700 24 44149-U4010 PLATE-LOCK (TOKIKO) (2) OP 0273- 25 44150-31700 SHIM ADJUSTING'B'(NABCO) (2) OP 26 44144-18000 COVER-DUST'B'(NABCO) (2) OP -173 3 26 44144-U4000 COVER-DUST'B' (NABCO) (2) OP 0273- 0 44144-18000 26 44144-U4010 COVER-DUST'B' (TOKIKO) (2) OP 0273- ---------------------------------------
[not shown in diagram] 27 44100-H0525 KIT-REPAIR WHEEL CYLINDER"A"(NABCO) (2) OP -173 3 27 44100-H3325 KIT-REPAIR WHEEL CYLINDER (NABCO) (2) OP 0273- 0 44100-H0525 27 44100-H3327 KIT-REPAIR WHEEL CYLINDER (TOKIKO) (2) OP 0273- 28 44100-H0526 KIT-REPAIR WHEEL CYLINDER"B"(NABCO) (2) OP -173 3
29 44200-18000 ASSY-ADJUSTER REAR BRAKE (2) OP ------------------------------------ 30 44204-18000 WEDGE-ADJUSTER (2) OP 31 44205-18000 TAPPET-ADJUSTER (4) OP 32 08915-13610 WASHER-LOCK M6 (4) OP 33 08911-10610 NUT-HEX M6X1.0-2 (4) OP ---------------------------------------
