Coil on Plug for your Datsun.
CA18DE Ignitor
Use MegaSquirt 2.0 to control the CA ignitor. MegsSquirt 3 can directly drive COP, but by using the ignitor it will work with MegaSquirt 2.
22020-85M10 TRANSISTOR IGNITION UNIT * USA 1987-1988 KN13 USA "Sentra XE" CA16DE/CA18DE * 1988 N13 Pulsar NX CA18DE
One plug has 5-wires -- 4 inputs low current triggers. The odd pin is for ground/earth. Connect two to Megasquirt:IGN1 and two to Megasquirt:IGN2.
The other plug has 4 high current outputs to the four coils.
Ignition Control Module (ICM) * Nissan 22020-85M10 * STANDARD MOTOR PRODUCTS LX645 * BECK/ARNLEY 1800180 * ACDELCO E1985A * AIRTEX/WELLS 6H1129
TunerStudio settings
Trigger on rising edge? Trigger on falling edge? Output: logic level Type: wasted spark
SR20DET Ignitor
The SR unit is smaller, newer but works the same way.
22020-50F00 'DIS4 04'
Input Trigger
Input trigger: coil negative terminal with normal point or electronic distributor.
With Nissan 360° CAS, use MegaSquirt 3 with 1.3.3 software. This includes CA18DE/DET CAS or the D4P distributor but modified to fit in A-series engine. MegaSquirt 2 will work if you swap the trigger wheel for a 22-1 wheel from DIYautoTune.
