B310 Electronic Distributor Swap
Revision as of 03:25, 27 November 2006; view current revision
Category: Engine Electrical System
Using the B310 electronic distributor in other A-series engines s a very simple swap, with only one minor modification needed to put it in an older 1971-1973 A-type engine. This distributor is factory stock on 1979-1982 Datsun 210 (North American version of the B310).
The 1980 Mitsubishi distributor on 1972 A12 engine. Note how it looks very similar to the 1971-1973 Hitachi or Mitsubishi distributor.
NOTE: This is not the same as the Hitachi electronic distributor as can be found in some New Zealand Sunnys and earlier North American B-210s. The one we are talking about here has a small 'black box' bolted on the side of the distributor.
Advantages
  • stealth. Looks very much like a factory 1200 point setup
  • Larger cap -- less chance to crossfire (important in humid climates)
  • High-energy spark -- uses full 12V coil (no ballast resistor)
  • No points to wear out, no dwell to adjust </ul>
    Mechanical
    1. If you are working with an old-style A-series engine (1966-1973), modify the distributor hold-down bracket to fit old-style block. The mounting bracket on newer distributors needs a slot cut with a hacksaw. For details, see Using Newer Distributor.
    2. Remove old distributor, Insert new distributor. And of course, set initial timing. For details, see the Ignition Timing article.
    Ah, this is the easy part, especially if you get a cut of the wiring harness when you purchase your distributor. But if you don't, it's still easy to hook up the wires.
    [1885.jpg [1]
    Connect wiring as shown here. As you can see, the two wires on the distributor go to the two coil wires.
      <li>Remove the standard low-energy coil and ballast resistor, then bolt the 12V coil in its place</li> <li>I believe the condensor is optional, it is to reduce radio interference. I bolted the condensor to the distributor mounting screw. Keep it away from the vibration and heat of the engine (mount it to the body panel). One end of the condensor can go to the ground spade-connector on the distributor body</li> <li>One side of the ballast resistor has a 12V IGN feed, so connect the Black/white wire to this original wire (Black/white)</li>
    NOTE: For coil, cap and rotor interchange, see part number section of B-210 Electronic Distributor Swap
      <li>Coil: 12V non-resistor: Nissan 22433-H7280, Bosch 00200, Beck/Arnley 1800039, AC Delco E525 or C502 (replaces F519 #12321584), Standard Motor Products UF-4/UF-4T</li> <li>Cap (same as points ignition): Standard Motor Products JH-63X/JH-63T/JH-63 <li>Rotor (same as points ignition): Standard Motor Products JR-79X/JR-79/JR-79T <li>Reluctor (rotating part): Standard Motor Products LX-528 </TR>
      </TABLE>
    • Pickup: Standard Motor Products LX-502
    • MakeModel</TD>Year
      NISSAN200 SERIES81-80
      21082-79
      31081-79
      51080
      </TR>
      </TABLE>
    • Ignitor: Standard Motor Products LX-516, F2045-18322 at drivewire.com ($126)
      NISSAN21082-79
      31081-79
      </TR>
      </TABLE> The Ignitor (elec. module) seem to be bulletproof. I'm told that the currently available replacement modules are junk, but the original Hitachi units are very good. They are still working after 20+ years!
      MakeModel</TD>Year
      NISSAN200 SERIES (uses UF-5 (Hanshin coil Calif.), UF-10 (Hanshin Federal) or UF-4 (Hitachi), Federal Hitachi used different reluctor.81-79
      21082-79
      280 SERIES , canada, US (except dist. 22100-P9000)81-79
      31081-79
      51080-79
      81081-79
      PICKUP80-79
       ModelYear Range Engine Chassis Transmission
       Nissan Maxima/810 4 Door Gas 1980 - 1981 L24E 910 5MT,3AT
       Nissan Maxima/810 5 Door Gas 1980 - 1981 L24E 910 5MT,3AT
       Nissan 620 Pickup 2.0 1978 - 1979 L20B 620
       Nissan 720 Pickup 2.0 1979 - 1980 L20B 720
       Nissan 200SX 2.0 1978 - 1979 L20BS10
       Nissan 210 1.21979 - 1982A12B310
       Nissan 210 1.41978 - 1982A14B310
       Nissan 210 1.51978 - 1982A15B310
       Nissan 280ZX 2.81978 - 1981L28ES130
       Nissan 310 1.41978 - 1980A14N10
       Nissan 310 1.5 OHV1980 - 1981A15N10
       Nissan 510 2.01978 - 1979L20BA10
       Nissan 810 2.41978 - 1980L24E810
       Nissan 200SX 2.01979 - 1980Z20ES110
       Nissan 510 2.01979 - 1980Z20SA10
      </ul>
