60-Series Transmission Parts
Revision as of 02:05, 26 January 2016; view current revision
Category: Transmission
Parts for 60-Series Transmissions are listed below. This includes 4-speeds and 5-speeds from B210 and B310 vehicles.
Part Number Prefixes
* H90	B310	unique to F5W60L
* 180	B10	56-series
* H73	B210	60-series
th_ds325050m3508d-img600x448-1415020101v4pvcr8911.jpg th_60A-sandwhich_.jpg th_60A-sandwhich.jpg
Case Comparo
B210 F4W60A
* 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776
* 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377
* 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60
* 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA
* 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA
* 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A
* 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg]
* 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001)
* 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
F4W60L
rally cross of F4W60L Gear ratio
* 1st: 3.19
* 2nd: 2.38
* 3rd: 1.89
* 4th: 1.00
F4W60 gears - B210 USA CATALOG
32200-H7300 ASSY-GEAR MAIN DRIVE 20T
32210-H7300 GEAR-COUNTER 31-27-20-15T
32220-H7300 GEAR-REVERSE COUNTER 14T
32230-H7300 ASSY-GEAR 1ST SPEED 34T
32250-H7300 ASSY-GEAR 2ND SPEED 28T
32260-H7300 ASSY-GEAR 3RD SPEED 24T
32280-H7300 ASSY-GEAR REVERSE IDLER 22T
32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
FS5W60L
Gearset
full
* 32241-H9001 SHAFT-MAIN
* 32264-H7300 BEARING-NEEDLE MAIN SHAFT 2
* 32260-H9000 GEAR ASSY-3RD 27T
* 32604-H9000 RING-BAULK 4
* 32603-18000 RING-SYNCHRONIZER 4
* 32609-18000 INSERT-SHIFTING 6
* 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD
* 32606-18000 SLEEVE-COUPLING 2
* 32250-H9000 GEAR ASSY-2ND
* 32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) 2
* 32246-H7300 WASHER-THRUST
* 32273-H7300 BEARING-(BALL,) MAIN SHAFT
* 32246-H9000 WASHER-THRUST MAIN SHAFT
* 32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT
* 32230-H9000 GEAR ASSY-1ST
* 32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3
  unique to F5W60L
* 32608-H9000 INSERT-SHIFTING 9
* 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE
* 32245-H9000 GEAR-REVERSE, MAIN SHAFT
* 32234-H9000 RETAINER SHIFTING INSERT
  Catalog is incorrect
* 32354-H9000 NUT-HEX (M25 X 1.0)
* 32228-H9000 RING-SNAP OVERDRIVE BEARING [Or 00922-12200?]
* 00922-12200 RING-SNAP (T=1.2)? [Or 32228-H9000?]
* 32227-H9000 BEARING-(BALL,) MAIN SHAFT END
* 32228-H9000 RING-SNAP,MAIN SHAFT END BEARING [Or 00922-12200?]
* 00922-12200 RING-SNAP (T=1.2) [Or 32228-H9000?]
full
Select only one 32204
* 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40
* 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46
* 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52
* 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58
* 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64
* 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70
* 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76
* 32209-H7300 SPACER-BEARING MAIN DRIVE GEAR
* 32214-H7300 RING-MAIN BEARING 2
* 32203-H7300 BEARING-MAIN DRIVE
* 32200-H7300 GEAR ASSY-MAIN DRIVE
* 32272-H7300 BEARING-PILOT MAIN SHAFT 1 of 3
Select only one 32263
* 32268-H9000 RING-SNAP SELECT T=1.60
* 32268-H9001 RING-SNAP SELECT T=1.65
* 32268-H9002 RING-SNAP SELECT T=1.70
* 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH [Also F560A]
* 32340-H9000 GEAR ASSY-OVERDRIVE
* 32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT)
* 32219-H9000 BEARING-COUNTER SHAFT [Also F460A 7812-]
Select only one 32224
* 32224-H7200 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.30-2.35
* 32224-H7201 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.35-2.40
* 32224-H7202 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.40-2.45
* 32224-H7203 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.45-2.50
* 32224-H7204 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.50-2.55
* 32224-H7205 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.55-2.60
* 32224-H7206 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.25-2.30
* 32224-H7207 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.20-2.25
* 32210-H9000 GEAR-COUNTER ASSY
* 32219-H9010 BEARING-COUNTER SHAFT
* 32220-H9000 GEAR-REVERSE COUNTER
Select only one 32222
* 32222-H9003 RING-SNAP COUNTER SHAFT SELECT T=1.3
* 32222-H9004 RING-SNAP COUNTER SHAFT SELECT T=1.4
* 32284-H9000 WASHER-THRUST COUNTER SHAFT REAR [Mistake? See 32285N]
* 32282-H9000 GEAR-REVERSE IDLER
* 32272-H7300 BEARING-REVERSE IDLER GEAR 2 2 of 3
* 32285-H9000 SPACER-REVERSE IDLER GEAR
* 32292-14600 PIN-RETAINING [Also F560A]
* 32281-H9000 SHAFT-REVERSE IDLER
* 32284-N9000 WASHER-THRUST REVERSE IDLER 2
Bearings
RockAuto.com
BALL BEARING - input shaft
32203-H7300 BEARING-MAIN DRIVE $31.78 USA
 * 62 x 30 x 11 mm
 * Inside Diameter:30 mm,1.1811 in
 * Outside Diameter:62 mm,2.4409 in
 * Width:16 mm,0.6299 in
 * C3:radial clearance greater than Normal
   * Timken 206L
   * SUZUKI 08163-62063
   * SKF 6206ZNRJ
   * Nachi 6026N C3
BALL BEARING - counter shaft, rear
32219M 32219-H7300 BEARING-COUNTER SHAFT, REAR $95.28 USD
 replaced by 32219-H8900
 Specifications:
  * 52 x 20 x 15 mm
  * Width 15mm, 0.591 in.
  * Bore 20mm , 0.787
  * OD 52mm, 2.047
   * Nachi 6304N
   * Timken 304WB
   * Timken 304DD (sealed)
   * National 304 (open)
ENCLOSED BEARING - counter shaft, rear
32219  32219-H9700 BEARING-COUNTER SHAFT, FRONT
 * replaced by 32219-H9702 $22 USD
NEEDLE CAGE - output shaft, rear
32272  32272-H7300 BEARING-PILOT
 * replaced by 32272-G3201 $26.02 USD > 32272-14600, 32272-H7300
 * Koyo RS18/17P
   * 18x24x17 mm needle roller bearing
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT $38.43 USD
 Rear 60A
 National B1616
 * Cone Bore: 25.400mm, 1.00 inch
 * Outside Diameter: 31.750mm, 1.250 inch
 * Width: 25.400mm, 1.00 inch
32350 BEARING-overdrive gear
* 32345-H9000 60L 5-speed
* 32345-H9702 60A
32283  32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
60L 5-speed Bearings/Bushings
PowerTorque BK139 F4W60 $144 USD
FS5W60A
60A 5-speed Gearset
full
Input shaft, Counter shaft, Reverse/Idle shaft
full
Output shaft
full
1st, 1-2 hub, 2nd
Reverse/Idler Gears
th_60a-reverse.jpg th_60a-reverse-1.jpg th_60a-reverse-2.jpg th_60a-rev-1.jpg th_60a-rev-2.jpg
5th gear bolted to end of cluster shaft
Cluster shaft and free-gears (1st, 2nd, 3rd)
32604-H9700 Synchro BAULK RING & matching gear surface
th_case-1.jpg th_case-2.jpg th_case-3.jpg th_case-a.jpg th_case-b.jpg th_casec.jpg
Kit
O'Reilly Auto Rebuild Kits
PowerTorque BK173WS w/synchros $254 USD
PowerTorque BK173 w/o synchros $146 USD
Input Shaft Bearing
BALL BEARING-MAIN DRIVE (Input shaft)
32203-H7300 (type 6206)
Output Shaft Bearing
BALL BEARING - MAIN SHAFT (Output shaft, mid)
32273-H7300 [NSK 6305NR/SKF 43305C]
BALL BEARING - MAIN SHAFT (Output shaft, rear)
32275  32227-H9700
NEEDLE BEARING - PILOT (output shaft, front)
32272-H7300 [18x24x17 mm]
NEEDLE BEARING - MAIN SHAFT
32264M  32264-H7300 (2)
32264  32267-H7300 (2)
NEEDLE BEARING - OVERDRIVE GEAR (input shaft, 5th gear)
32350  32345-H9702
Cluster Bearings
60A 5-speed Bearings/Bushings
32219 BEARING-COUNTER SHAFT
32219-H9700 FS5W60A $95.28 USD
* enclosed needle bearing (pilot bearing)?
32219M BEARING-COUNTER SHAFT
32219-H7300
* F4W60L
* FS5W60A
32224 WASHER-THRUST COUNTER SHAFT FRONT
* SELECT USE T=2.30 - T=2.25
32283 BEARING-REVERSE IDLER GEAR
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
32287 WASHER-THRUST REVERSE IDLER
32265-18000
* F4W56
* FS5W60A
Thrust Washers
32287  32265-18000 WASHER-THRUST REVERSE IDLER [center]
32318  32287-H9700 WASHER-THRUST [REVERSE IDLER, rear]
32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front]
       SELECT USE
       32224-H7200 T=2.30-2.35
       32224-H7201 T=2.35-2.40
       32224-H7202 T=2.40-2.45
       32224-H7203 T=2.45-2.50
       32224-H7204 T=2.50-2.55
       32224-H7205 T=2.55-2.60
       32224-H7206 T=2.25-2.30
       32224-H7207 T=2.20-2.25
Seals
Front Cover O-ring
32112M  32112-H7300 RING-O FRONT COVER
Front Cover Seal
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
Nissan 32114-Y4000
* A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20
* RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18
* 60-series, 71-series 71B/71C
Specs
* shaft size: 30 mm
* bore size: 45 mm
* seal outer diameter: 45.2 mm
* seal width: 8 mm
* Polyacrylate or Nitrile
RockAuto
National 1981
Timken 1981
Fits:
* Nissan 32113-Y4000, 32114-20100, 32114-Y4000
* 8942152200
* 8943270620, 8943270621, 8943348450, 8943895931
* 9004310029, 9004311141, 9031130010, 9031130014
* 9031130115, 94215220, 94327062
* Ford EBTZ7052D
* Toyota W55 transmission
* Isuzu 8943270620 camshaft seal
Output Shaft
32136-18000 45mm
32136-G1001 60mm
32150-H7300
C2136-H8900 > 32136-H8900 $10.00 USD
C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION [4-speed & 5-speed 60-series] $23.87 USD
* 56A,60A,60L
* Nitrile Seal, Counter-Clockwise-Spiral Design
* Shaft Size: 1.181"
* Housing Bore: 1.772"
* Seal Width: 0.591"
* Seal Outside Dia: 1.78"
* Flange Outer Diameter=2.441" (?)
th_maido_113-img600x450-13530452029nee0t27970.jpg th_maido_113-img600x450-1353045201jpi1ni27970.jpg
32160- many EXTENSION ASSY-REAR
Factory Service Manual says:
If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
