Horn
Revision as of 07:29, 27 December 2007; view current revision
Datsun 1200 used dual horns. It also uses a three-connector relay, which is bolted to the right-side strut tower just below the ignition coil.
location
Horn wiring schematic: 14974.jpg
Relay Wire Colors
  • Green - to horns
  • Green/white - to 15A fuse in fuse box, Battery side
  • Black/green - to steering column connector (for horn button)
  • Case bolts to body (earth/ground)
Stamped on the relay case are:
  • H - connector for Horns
  • B - connector for Battery (through fuse box)
  • S - connector for Switch (in steering wheel)
