Synchronizers let you shift gears without grinding.
Synchro is two cones pressed together until the two shafts run the same speed:
Each gear has a syncho face (external cone) machined with it
The hub is spring loaded so when you move the shifter partway, it presses the baulk ring (internal cone part) against the gear cone.Template:Img400-When they have slowed down to the same speed, the shifter will move all the way in. It happens very quickly, unless the synchros are worn and not working well.
Synchro is basically:
- Coupling with hub
- Baulk ring cone
- Gear face cone
Coupling with hub. Left: assembled from the parts shown
Each synchro set services two gears (arrows). Center arrow points to the Coupling Sleeve (The Coupling Sleeve is what the shifter moves)
The hub is keyed to the mainshaft, so the hub sleeve rotates constantly in the Shift Fork while the car is moving.
The spring lets the hub move side-to-side inside the Coupling Sleeve, but not move too far. On this one there is a total of about 1/4" (5mm) total movement possible. The baulk ring, which fits in the hub, is pushed against the gear cone. Once the two shafts are synchronized, the spring pops the dog teeth together.
Warner Vs Porsche Type Synchros
F5C56A 5-speed has very different synchros from the 4-speed. It has competition type synchros (the "C" in F5C56A) which are very different: instead of a brass baulk ring, it has two split rings. Both types have a conical section to them. They are the same type as early Roadster 'servo' type but smaller size.
4-speed: W56 'W' Warner (Borg Warner) BRONZE baulk-ring type syncromesh 5-speed: C56 'C' Type STEEL Porsche split-ring synchromesh.
4-speed: W56 'W' BRONZE baulk-ring type syncromesh
5-speed: C56 'C' Type STEEL synchro
Gearbox
56-Series Transmission
See Transmission Gear Part Numbers
3-speed 32604-18000 B110,B210 RING-baulk 32604-H1000 B10 <> 32604-18000 32604-H7300 B210 > 32604-H1000 <> 32604-H1010
4-speed F4W56L, F4W56A 32604-18000 B10 RING-baulk 32604-H1000 B10 <> 32604-18000 32604-H9000 B120 RING-BAULK (4) 32604-H9000 B310 RING-BAULK F4W56A, F4W60L(F4+F5) 32604-H7300 RING-BAULK B211 F456A, F4W60L (from 7407) > 32604-H1000 32604-H7300 RING-BAULK B210 F456A (from 7407) > 32604-H1010 (from 7311) <> 32604-H1000 32609-18000 INSERT-SHIFTING (6) [plate] 32603-18000 SPRING-SHIFTING INSERT (4) (or SPRING-synchronizer, RING-SYNCHRONIZER) 32601-18000 HUB-SYNCHRONIZER (2) 32606-18000 SLEEVE-COUPLING (2) 32262 32265-18000 WASHER-THRUST, synchronizer hub [input gear side]
5-SPEED F5C56A 32601-H7200 HUB-SYNCHRONIZER (2) 32606-H7200 SLEEVE-coupling (2) 32611-H7200 RING-synchro 32612-H7200 BLOCK-thrust 32613-H7200 BLOCK-anchor 32614-H7200 BAND-brake 22 (2) $3 USD 32616-H7200 CIRCLIP
Also see 56-Series_Transmission_Parts#Synchros.
32603-18000 SPRING-SYNCHRONIZER * B11/B12/B13/B14 4-speed, 5-speed, E16, SR20DE, GA16DE * B110/B210 4-speed * B210/B310 4-speed, 5-speed * N10/N12/N13 F4, F5 * T115-speed parts
4-SPEED EARLY 32601-18000 HUB-SYNCHRONIZER 1 4 SPEED $78 USD 32604-H1000 BAULK RING 32606-18000 SLEEVE-COUPLING $52 USD
4-SPEED LATE 32601-H7301 HUB-SYNCHRONIZER, 1ST & 2ND, 3RD & 4TH $83 USD * same as 60-series Transmission 4-speed & 5-speed (1st & 2nd only) 32604-H9000 BAULK RING $44 USD * also replaces ealier 32604-H1000 * same as 60-series Transmission 4-speed 32606-18000 SLEEVE-COUPLING * same as 60-series Transmission 4-speed & 5-speed
5-SPEED 32601-H7200 HUB-SYNCHRONIZER, 2nd & 3rd, 4th & 5th 5-speed 32606-H7200 SLEEVE-coupling
- 5-speed was never available in pre-56A form (was designed from the go with improvements over the original 56L 4-speed)
- Used steel "competition" (Porsche type) synchros in F5C56A form
- Datsun Competition in one instance mentioned warner type synchros (F5W56A). However, other Datsun sources such as the B110 and B210 parts catalogs only list F5C56(A) and Porsche type synchros
The 5-speed transmission (FS5C56A) was originally installed on certain non-USA models of the 1200 ... The synchro mechanism is the servo-type (steel).
Pitroad will convert your F5C56A to Warner synchros for 559,000 yen
60-Series Transmission
Also see 60-Series Transmission Parts![]()
32604-H9000 RING-BAULK [12-tooth] * F4W56A 4-speed light duty (4) * F4W60L 4-speed heavy duty (4) * FS5W60L 5-speed early (5)
32604-H9700 RING-BAULK * FS5W60A 5-speed late (5)
FS5W60L 5-Speed (1979 B310) 32606-18000 SLEEVE-COUPLING 4th-5th, 2nd-3rd NOTE: 1st gear coupling sleeve is built into Reverse Gear 32604-H9000 RING-BAULK 5 32258-H9001 HUB-SYNCHRONIZER 1ST & REVERSE $133.92 USD 32602-32200 SPRING-SYNCHRONIZER 1ST 3 32608-H9000 INSERT-SHIFTING 3 32234-H9000 RETAINER-SHIFTING INSERT 32601-H9001 HUB-SYNCHRONIZER 2ND & 3RD 32603-18000 SPRING-SYNCHRONIZER 2 32609-18000 INSERT-SHIFTING 3 32601-H9000 HUB-SYNCHRONIZER 4TH & 5TH 32603-18000 SPRING-SYNCHRONIZER 2 32609-18000 INSERT-SHIFTING 3
FS5W60A 5-Speed (1980- B310) 32606-18000 SLEEVE-COUPLING 3 32604-H9700 RING-BAULK 5 32601-H7300 HUB-SYNCRO,1ST & 2ND 32609-H9700 INSERT-SHIFTING 3 32603-18000 SPRING-SYNCRO 2 32601-H7301 HUB-SYNCRO,3RD & 4TH 32609-M0102 INSERT-SHIFTING -0780 3 32609-H9700 INSERT-SHIFTING 0880- <0> 32609-M0102 3 32603-18000 SPRING-SYNCRO 2 32601-H9000 HUB-SYNCRO 5TH & REVERSE 32609-H9700 INSERT-SHIFTING 3 32603-18000 SPRING-SYNCRO 2
32602-32200 SPRING-SYNCHRONIZER * B310 1979 5-speed * 71B 5-speed, 4-speed * 63A 5-speed
32609-M0102 INSERT-SHIFTING * B310 1980 5-speed * N10 1979-1981 F4, F5
63-Series Transmission
A14-equipped B210 5-speed
32604-P0100 RING-BAULK (5) FS5W63A 5-speed 32606-N7100 SLEEVE-COUPLING <> 32606-73200 2 32605-N9000 HUB-SYNCHRONIZER,4TH & 5TH 32601-N9000 HUB-SYNCHRONIZER 2ND & 3RD 32609-73201 INSERT-SHIFTING 6 32603-73200 SPRING-SPREAD 4 32245-N9000 GEAR-REVERSE,MAIN (38T) 32258-N9001 HUB-SYNCHRONIZER,1ST & REVERSE 32608-N9000 INSERT-SHIFTING 3 32602-32200 SPRING-SYNCHRONIZER 3
32604-P0100 RING-BAULK * 63 5-speed * 71B 4-speed, 5-speed
32609-73201 INSERT-SHIFTING * 63 5-speed * Z31 VG30.MT.F5 3rd-4th
32603-73200 SPRING-SPREAD * 63 5-speed * B11/B12/B13/B14 * D21 4WD.KA24E.MT.FT * GC22.Z24I * N12/N13 * S12.VG30E.MT * T11 * Z31.VG30.MT.F5
Part Number
3264-18000
32604-18000 B110 56-series 3-speed 32604-18000 B10 3-spd, 4-spd <> 32604-H1000
Per B10 parts catalog, 180 is interchangeable with H10, however the B110 catalog makes no indication of this.
H1000 H1001 Thickness 7.8 8.2 mm Outside Diameter 69.6 69.3 O. D. less teeth 60.2 59.2
Per Ningbo, the dimensions differ slightly from H10
32604-H1000
56-series 4-speed * 32604-H1000 Baulk Ring * 32604-H1010 alternate supplier * 32604-H7300 > H10
H73 may be used to replace H10, but not vice-versa.
Per Nissan Parts, the original H10 synchros were "replaced" by the #H90 part, however the dimension are different.
Specs for OAT06-551003
Photo: aftermarket H10 specs
Some vendors list a 32604-H1001, however it differs from H1000 and it is unknow if this is an actual Nissan listing
H1000 H1001 Thickness 7.8 8.2 mm Outside Diameter 69.6 69.3 O. D. less teeth 60.2 59.2 cone part min dia 51 50.3 cone part max dia 53 52.3
Inspection
Place the baulk ring over the gear and push down to seat it, then measure the clearance between the teeth. Too little clearance is probably caused by a worn ring.
Normal: 1.05-1.40 mm Limit: 0.50 mm
Album: Fit ring to gear
Album: Measure 56A synchro clearance
32604-H7300
32604-H7300 RING-baulk (from '74-7) (4) 4-speed B210 F4W56A > (32604-H1000 <> 32604-H1010) * 6-tooth: 3 sets of 2 teeth
H73 synchro
Album: Assembled
OPS International OAT06-551002
OAT06-551002 specs
32604-H9000
32604-H9000 replaced H10 * 12 teeth (3 groups of 4 teeth, a group every 120 degrees) * 60L 4-speed & 5-speed (not 60A)
H90 baulk ring
Album: H90
32604-H9700
32604-H9700 Synchro BAULK RING & matching gear surface
Album: Genuine Nissan H97 (60A)
Photo: 32604-H9700 Synchro BAULK RING
Photo: DCIF-2253A (32604-H9700)
Post: H97 has three sets of three internal grooves
32604-P0100
32604-P0100 RING-BAULK * 63 5-speed, including B210.A14 versions * 71B 4-speed, 5-speed * 30 teeth (3 groups of 10 teeth)
JMIT/Jiun Mu DCIF-2254-32604-P0100/A6410![]()
OPS International OAT06-551008 (32604-P0100)![]()
Comparison
Thickness: 9 mm 60L 8.5 mm 63A/71B 7.8 mm 56 ? 60A Outside Diameter 76.5 mm 63A/71B 69.6 mm 56 68 mm 60L ? 60A
Outside Diameter Less Teeth 66.4 mm 63A/71B 60.2 mm 56 60 mm 60L ? 60A
Inside Diameter 58.6 mm 63A/71B 52.5 mm 60L 52 mm 56 ? 60A
Teeth Pattern 3 x 10 63A/71B 3 x 4 60L 3 x 2 Late 56A 30 Early 56A, 56L 30 60A
