Air Cleaner Part Numbers
Revision as of 00:01, 9 January 2012; view current revision
Categories: Engine Mechanical | Catalog
Also see:
Part Numbers Index
Main article for usage, photos, cross-reference
Air Cleaner
Early
To May 1971
1 16500-H1005 ASSY-AIR CLEANER A12 CRANK 2 16500-H1001
1 16500-H1901 ASSY-AIR CLEANER A12 EVAPO
1 16500-H1905 ASSY-AIR CLEANER A12 EVAPO 2 16500-H1901
1 16500-H1001 ASSY-AIR CLEANER A12 CRANK
2 16500-H1010 ASSY-AIR CLEANER,FOR COLD REGION A12 CRANK
2 16500-H1015 ASSY-AIR CLEANER,FOR COLD REGION A12 CRANK 2 16500-H1010
2 16500-H1910 ASSY-AIR CLEANER,FOR COLD REGION A12 EVAPO
2 16500-H1915 ASSY-AIR CLEANER,FOR COLD REGION A12 EVAPO 2 16500-H1910
 16547-52A00 PACKING A12 16547-H1000
3 16547-H1000 PACKING A12
 A6548-M5600 PACKING A12 16548-18000
4 16548-18000 PACKING A12
5 16568-H1000 ASSY-PACKING A12
6 16546-18000 ASSY-ELEMENT,PAPER(VISCOUS) A12
7 16523-H1000 INSULATOR A12
8 16547-H1000 PACKING A12
9 16596-78521 MARK A12
10 01237-00011 NUT-WING A12 2 16551-H1000
10 16551-08000 NUT-WING A12 2 01237-00011
 16551-W7000 16551-08000
10 16551-H1000 NUT-WING A12
11 16525-H1001 STUD-AIR CLEANER A12
11 16525-H5000 STUD-AIR CLEANER A12 0573- 2 16525-H1001
12 16573-H1001 SUPPORT-AIR CLEANER A12
13 08915-43610 WASHER-RLAIN (2) A12
14 08120-61210 BOLT (5) A12
15 08915-13610 WASHER-LOCK (5) A12
16 16574-H1001 SUPPORT-AIR CLEANER,FRONT A12
17 08915-53610 WASHER-PLAIN A12
18 A6530-70N40 DUCT-COVER TO AIR CLEANER A12 16530-H1001
18 16530-H1001 DUCT-COVER TO AIR CLEANER A12
 01555-00291 CLAMP-DUCT (2) A12 08723-14400
19 08723-14400 CLAMP-DUCT (2) A12
20 16590-H1000 ASSY-COVER,EXHAUST MANIFOLD A12
Late
From June 1971
1 16500-H3901 ASSY-CLEANER,AIR A12 0771- 5 16500-H3900
1 16500-H7000 ASSY-CLEANER,AIR A12 0772- 0 16500-H3901
1 16500-H3900 ASSY-CLEANER,AIR A12 0671-0771 1
2 01237-00011 NUT-WING A12 0671-
2 16551-08000 NUT-WING A12 2 01237-00011
3 16510-H3900 ASSY-MOTOR,VACUUM A12 0671-
 16580-01B01 ASSY-SENSOR,TEMPERATURE A12 16580-H3900
4 16580-H3900 ASSY-SENSOR,TEMPERATURE A12 0671-
5 16582-H3900 CLAMP-SENSOR & TUBE A12 0671-
6 22318-C0601 TUBE-VACUUM MOTOR TO TUBE L=200 A12 0671-
7 22318-C0601 TUBE-VACUUM CONTROL L=320 A12 0671-
8 16573-H1001 SUPPORT-AIR CLEANER A12 0671-
9 16574-H1001 SUPPORT-AIR CLEANER,FRONT A12 0671-
10 08120-61210 BOLT (5) A12 0671-
11 08915-13610 WASHER-LOCK (5) A12 0671-
12 08915-43610 WASHER-PLAIN (2) A12 0671-
13 08915-53610 WASHER-PLAIN A12 0671-
14 16530-B3901 DUCT-COVER TO AIR CLEANER A12 0671-
15 08723-14400 CLAMP-DUCT (2) A12 0671-
16 16590-H3900 ASSY-COVER,EXHAUST MANIFOLD A12 0671-
17 08190-81210 BOLT (3) A12 0671-
18 08915-43810 WASHER-PLAIN (3) A12 0671-
19 08915-13810 WASHER-LOCK (3) A12 0671-
20 14896-25600 BAND-HOSE A12 0671-
21 14875-H1900 CONNECTOR-VACUUM A12 0671-
