Datsun B310 dashboard had round gauges, and later changed for 80s style.
Early Style for all Round Headlight models (1977-1979)
Early: Individual pods for gauges of instrument panel Late: Single large opening for instrument panel
Late Style for Square Headlight models (1980-1982)
 full
Early
1977-1979 + all Japan VB310 van (all round headlight models) used a wide driver's "cockpit" that encompassed the radio and center vents.
NOTE: LHD has the two side pods reversed
Right LHD: Clock
Left RHD: Clock
Small Left: single: clock mask
            double: Fuel/Temp (Coupe GX)
Large Center Gauges
* Left: Speedometer
* Right: Water/Fuel (sedan)
         Blank with idiot lamps
         Econometer (coupe A14.GL)
         Tachometer (coupe GX)
Small Right:
* Single: Water/Fuel with idiot lights (oil/brake)
* Double: stacked Volt/Amp (coupe GX)
Left Clock (digital)
 full
Left Clock (analog)
 full
GL
 full
GXE
 full
SGX
 full
See: #Cluster Lid
 full
Japan California
Sunny California (wagon)
 full
 full
 full
Van
Australia
USA Coupe
 full
 full
 full
 full
 full
 full
 full
USA Sedan
large speedometer flanked by OPTION tachometer
 full
 full
 full
 full
To left of speedometer is smaller temp/water gauge
 full
Small left side round pod is Clock Blank
 full
Tachometer blank with idiot lamps (Oil/Amps)
 full
 full
 full
 full
 full
Tachometer
Tachometer Yellow Zone * Carburetor 6000-6250 * EGI 6400-6800GX-E
TACHOMETER ASSY 24855-H8700 *K.(DX+GL) -7811 24855-H8701 *K.(DX+GL) 7812- CLEAR LAMP 24855-H9200 (S+K).GX 24855-H9201 (S+K).A14E
Clock
2+4 dash: CENTER STACK CLOCK, sealed shield 2+2 dash: left-side CLUSTER CLOCK, clear shield GX,DX,GL analog SGL, SGX digital
CLOCK K,S.SGX 27380-H9210 DIGITAL QUARTZ LUMINOUS SPORT INST -7804 27380-H9211 DIGITAL QUARTZ LUMINOUS SPORT INST -7805-7909
Late
1980-1982 switched to a smaller driver's "cockpit" that included just the instrument panel -- the radio and center vents were outside of this area. Japan vans stayed with the early style.
H85 single side gauges H92 double side gauges S,K.SGX
2+2 cluster Wagon/Sedan (except SGX)
Sedan/Wagon
SEDAN/WAGON GAUGES (except SGX) Round or Digital Clock (or 'NISSAN' clock mask) Speedometer Large Fuel/Temperature Idiot Lamp
Idiot Lamps (Large Fuel/Temperature) * 'CHG' with BATTERY symbol * OIL symbol
Idiot Lamp (Small pod) two variations * H85 S,W.GL#,DX# BRAKE or * H92 S.GX CHG
2x2 cluster (2 large, 2 small)
Coupe
Also used by Sedan SGX
COUPE GAUGES (except SGX/SGX-E) Round Clock (or 'NISSAN' clock mask) Speedometer Tachometer Small Fuel/Temperature
Idiot Lamp BATTERY (bottom of tachometer)
SGX
SGX/SGX-E GAUGES Digital Quartz Clock Fuel Speedometer (160kph) Tachometer Oil Pressure Water Temperature
Idiot Lamp BATTERY symbol (bottom of tachometer) MASKED: Idiot Lamp Meter strip (bottom of cluster)
SGX-E 6800 RPM tachometer for EGI
 full
 full
 full
Monitor Lamp Strip
Inspection Monitor Lamp strip 25040-H8563? (five variations)
 full
SGX with full Monitor Lamps (all six icons)
 full
Masks go here (where photo is labeled "Delete Plate")
 full
68450-H8501 MASK 7910- CT,S.DX,SPT,ES+W.DX, SGX
25040-xxxxx LAMP ASSY [six variations]
      H8500 EXH TEMP,BRAKE,FUEL
      H8562 FUEL,DOOR
      H8761 EXH TEMP,BRAKE,FUEL,DOOR,TAIL,STOP
      H9201 EXH TEMP,BRAKE,FUEL,DOOR
      H8563 FUEL,DOOR,TAIL,STOP
      H8611 CT/DX [blank]
      H8761 SGX [blank]
Tachometer
H90 dual idiot lights at bottom H92 single idiot light at bottom
TACHOMETER ASSY 24855-H9020 K-(K.SGX#,K.RSE),W.GX 24855-H9021 K.RSE,S.GXE 24855-H9215 (4S+K).SGX [std redline] 24855-H9216 (4S+K).SGXE [EFI redline]
LENS 68435 25021-H9020 K-SGX# S.(GX#+SGL) OIL,BATTERY 25026-H8503 S,W.GL#,DX. BRAKE 25026-H9215 S.GX CHG
Cluster Lid
Early - individal gauge lenses Late - one big opening for all gauges
H850 DX H851 Late Model H856 GL H86 CITY + DX.WAGON H92 GX H94 Van STD late
CLUSTER LID
68420-H8500 DX BLACK
68420-H8501 DX BROWN
68420-H8510 7910- BLACK
68420-H8511 7910- BROWN
68420-H8560 GL BLACK
68420-H8561 GL BROWN
68420-H8600 CT BLACK W.DX
68420-H8601 CT BROWN W.DX
68420-H9200 GX# BLACK
68420-H9201 GX# BROWN
68420-H9400 BROWN
            7812- V.STD
            8011- V.A12.STD
            8110- V.A12.DXA
68420-H9460 8011- BLACK V.A12.STD,DXA
NOTE: DXA was a trim only available with 2-seat Van (VB312R)
