Also see:
Part Numbers Index Main article for usage, photos, cross-reference Truck Fuel Tank
Early
To February 1973
full-size pic
FUEL TANK (up to '73-2) 1 17201-G1000 TANK ASS'Y-fuel 2 17373-14801 PLATE-lock 3 17342-18000 O RING 4 25060-G1000 GAUGE-fuel tank 5 17312-14800 PACKING-drain 17312-H1000 <> 17312-14800 6 08931-44210 PLUG 17310-H1000 <> 08931-44210 7 17251-G1000 CAP ASS'Y-filler 17251-G1001 <> 17251-G1000 8 17264-18000 PACKING 9 17220-G1000 TUBE-filler, upper 10 17221-H1000 PACKING 11 17222-H1000 NECK-filler 12 08310-40812 SCREW 3 13 17229-G1000 HOSE-filler 17229-G1001 > 17229-G1000 17229-G1052 HOSE ASS'Y-filler, with clamp <> 17229-G1001 14 17228-H1400 GROMMET 15 08723-15600 CLAMP-hose 2 08723-15800 > 08723-15600 16 17325-G1000 HOSE-ventilation (ℓ=560mm) 17 24250-G1000 GROMMET 18 17326-G1000 COLLAR-ventilation hose 19 08723-12600 CLAMP-hose 2 20 17501-G1001 TUBE-fuel(up to '71-9) 17501-G1003 TUBE-fuel(from '71-10) 21 17515-H1006 HOSE-fuel, with clamp (ℓ=75mm) (Op.) 17515-H1008 HOSE-fuel, with clamp (ℓ=75 mm) (Op.) > 17515-H1006 22 17515-G1001 HOSE-fuel, with clamp (ℓ=220mm) (Op.) 08742-20020 HOSE-fuel (6.0x13.5x2,2200) 23 08723-11400 CLAMP 2 24 08110-81610 BOLT 4 25 08915-43810 WASHER-plain 4 26 08915-13810 WASHER-lock 4 27 17810-G1000 PLATE ASS'Y-fuel hose protector (R.H.) (op.)
EVAPO
From March 1973
FUEL TANK (from '73-3) 1 17201-G1400 TANK ASS'Y-fuel 2 17373-14801 PLATE-lock 3 17342-18000 O RING 4 25060-G1000 GAUGE-fuel tank 5 17312-H1000 PACKING-drain 6 08931-H1000 PLUG 7 17251-H1901 CAP ASS'Y-filler 8 17264-18000 PACKING 17251-H1902 CAP ASS'Y-filler, with packing <> 17251-H1901 + 17264-18000 9 17220-G1401 TUBE-filler, upper 10 17221-H1000 PACKING 11 08310-40812 SCREW 3 12 17229-G1052 HSOE ASS'Y-filler, with clamp 13 08723-15300 CLAMP-hose 2 14 17228-H1400 GROMMET 15 17325-G1400 HOSE-vent (ℓ=540mm) 16 24250-G1000 GROMMET 17 17326-G1000 COLLAR-vent hose 18 08723-12600 CLAMP-hose 4 19 17350-G1402 TANK ASS'Y-reservoir 20 17355-G1401 BRACKET ASS'Y-reservoir tank 21 17361-G1400 TUBE-evapo 22 17524-M1500 HOSE-fuel, with clamp (ℓ=90 mm) (Op.) 23 17515-G1400 HOSE-fuel, with clamp (ℓ=880 mm) (Op.) L-all 17515-G1003 HOSE-fuel, with clamp (ℓ=800 mm) (Op.) S-all 24 06112-1200P GROMMET 5 25 17364-G1400 CONNECTOR-3way (up to '73-5) (Op.) 17364-G1401 CONNECTOR-3way (from '73-6) (Op.) > 17364-G1400 17364-G1402 CONNECTOR-3way (from '73-8) (Op.) > 17364-G1401 26 17515-H1821 HOSE-fuel, with clamp (ℓ=120 mm) (Op.) 27 17515-G1406 HOSE-fuel, with clamp (ℓ=65 mm) (Op.) 28 17515-G1002 HOSE-fuel, with clamp (ℓ=580 mm) (Op.) S-all 29 17515-G1004 HOSE-fuel, with clamp (ℓ=500 mm) (Op.) L-all 30 17367-G1400 CONNECTOR-2way (up to '73-5) 17367-G1401 CONNECTOR-2way (from '73-6) > 17367-G1400 17367-G1402 CONNECTOR-2way (from '73-8) > 17367-G1402 31 17325-G1002 HOSE-fuel (ℓ=270 mm) S-all 17325-G1003 HOSE-fuel (ℓ=270 mm) (from '73-8) S-all > 17325-G1002 32 17325-G1401 HOSE-fuel (ℓ=360 mm) L-all 17325-G1402 HOSE-fuel (ℓ=360 mm)(from '73-8) L-all > 17325-G1401 33 17515-G1401 HOSE-fuel, with clamp (ℓ=760 mm) (Op.) L-all 34 17213-G1400 ORIFICE-fuel 35 17368-G1400 COLLAR-hose 1 S-all, 2 L-all fixing reservior tank 08360-61414 SCREW 1 08915-53610 WASHER-plain 2 08360-61814 SCREW 2
FUEL PIPING 36 17515-H1008 HOSE-fuel, with clamp (ℓ=75 mm) (Op.) 37 17501-G1400 TUBE-fuel 38 17515-G1001 HOSE-fuel, with clamp (ℓ=220 mm) (Op.) 39 08110-81625 BOLT-wiht lock & plain washer 4 40 17810-G1000 PLATE ASS'Y-fuel hose protector (R.H.) 41 08510-61612 SCREW 5 42 08915-43610 WASHER-plain 5 (注) *印部品についてな下記の部品にてサービス。。。 08742-22020 HOSE-fuel (6.0 x 13.5 x 2.200) 43 08723-11400 CLAMP 14
Late
From October 1975
full-size pic
(N-7907) B 08510-61623 08518-51612 SCREW (7908-)
17201 TANK ASSY-FUEL 17201-G1401 7510-7803 <2,2> 17201-G1402 17201-G1402 7804-7907 <2,2> 17201-G1403 17201-G1403 7908-8111 <2,0> 17201-G1405 17201-G1405 8111-8910 17202-95W00 8910- 08110-81625 BOLT 17201A PLUG-DRAIN 17310-H1000 7510-7803 <0,0> 01125-00025 01125-00025 7804-7907 <0,2> 01125-00062 01125-00062 7908- 17201B PACKING-DRAIN PLUG 17312-H1000 -7804 17312-S0160 7804- 17220F GROMMET-FILLER TUBE 17228-H1400 GROMMET 17222 NECK ASSY-FILLER 17220-G1402 08310-40812 SCREW 17223 HOSE-FILLER 17229-G1002 08723-15800 CLAMP 17251 CAP ASSY-FILLER 17251-H1902 -8503 17251-U7402 8504- 17271 COVER 17810-G1000 -7907 17811-G1000 7908- 08510-61623 SCREW 08510-61623 SCREW -7907 17321 HOSE-BREATHER 17325-G1003 -8910 SB 17325-G1402 -8910 LB 17324-G1000 8910- SB 17324-G1400 8910- LB 08723-12600 CLAMP 17322 HOSE-BREATHER A(L=120) A8742-20020 -8910 L=120 17515-H1821 8910- 17323 CONNECTOR-HOSE,FILLER 17367-G1402 17325 HOSE-VENTILATION 17325-G1400 08723-12600 CLAMP 17325N HOSE-VENTILATION 17328-G1000 7608- SB L=800 17328-G1400 7608- LB 08723-11400 CLAMP -7607 08723-11100 CLAMP 7608- 17326A PROTECTOR 17326-G1000 17326B PROTECTOR 17368-G1400 17326C PROTECTOR 17327-G1000 -8910 SB 17327-G1400 -8910 LB 08723-12600 CLAMP 08723-11400 CLAMP 17515-G1401 8910- 17333 HOSE-EMISSION CONTROL A(L=65) A8742-20020 -8910 L=65 17515-G1406 8910- 08723-11400 CLAMP 17333M TUBE-BREATHER 17213-G1400 17334 HOSE-BREATHER A8742-20020 -8910 A(L=580) 17515-G1002 8910- SB 17515-G1404 8910- LB 08723-11400 CLAMP 17342 SEAL-0 RING, FUEL GAUGE 17342-18000 -8910 17342-18000 8910- 17343 PLATE-LOCK,FUEL GAUGE 17343-14801 -8503 17343-14800 8504- 17350 TANK ASSY-RESERVE 17350-G1403 08360-61428 SCREW 08723-11400 CLAMP 17350A SCREW 01436-00111 2 7904-8503 08915-53610 WASHER -7903 08915-5362A WASHER 8504- 08360-61814 SCREW -7903 08360-6182B SCREW -8504- 17351 CONNECTOR-3 WAY 17364-G1402 17361 GROMMET 24250-89949 17362 GROMMET 06112-1200P B -8910 4 01651-00261 A 06112-1200P B 8910- 4 17501X HOSE-FUEL A8742-20020 -8910 L=760 08740-76021 17526-95W00 8910- 17501Z HOSE-FUEL * 08740-20021 8910- L=200 S/#A8742-20020 08723-1142A CLAMP (17508) C17-02 17510X HOSE-RETURN * 08740-25021 8910- L-250 S/#A8742-20020 08723-11400 CLAMP 25060 GAUGE ASSY-TANK UNIT 25060-G1000 -8111 25060-G1010 8112-
