Also see:
Part Numbers Index Main article for usage, photos, cross-reference Brake master cylinder
To September 1971
TBD
From October 1971
1 46010-H3300 ASSY-CYLINDER,BRAKE MASTER (TANDEM)FOR 1071- 1 46010-H3100 ASSY-CYLINDER,BRAKE MASTER (TANDEM) FOR 1071- 2 46073-B5010 ASSY-PISTON,SECONDARY FOR DRUM 2 46073-H3310 ASSY-PISTON,SECONDORY FOR DISC 3 46064-B5010 CUP-PISTON (2) 4 46066-B5010 SPACER-CUP 5 46068-B5010 CUP-PISTON 6 46062-B5010 SEAT-SPRING 7 46075-B5010 SPRING-RETURN 8 46063-H3310 ASSY-PISTON PRIMARY 9 46064-B5010 CUP-PISTON 10 46066-B5010 SPACER-CUP 11 46068-B5010 CUP-PISTON 12 46062-B5010 SEAT-SPRING 13 46065-B5010 SPRING-RETURN 14 46070-27260 RING-PISTON,STOPPER 15 46079-R1200 GASKET-PISTON STOPPER 16 46032-R1200 STOPPER-SECONDARY PISTON 17 46027-A6900 SPRING-RESIDUAL VALVE (2) 18 46050-H0111 ASSY-VALVE,RESIDUAL FOR DRUM (2) 18 46050-H0111 ASSY-VALVE,RESIDUAL FOR DISC 19 46057-10610 RETAINER-VALVE FOR DRUM (2) 19 46057-10610 RETAINER-VALVE FOR DISC 20 46050-73410 ASSY-VALVE,RESIDUAL FOR DISC 21 46057-73410 RETAINER-VALVE FOR DISC 22 46042-27260 PACKING-VALVE (2) 23 46038-21011 PLUG-CYLINDER (2) 24 46090-U0512 PESERVOIR-OIL FOR DRUM (2) 24 46090-U0512 RESERVOIR-OIL FOR DISC 25 46091-U0512 RESERVOIR-OIL FOR DISC 26 46016-10610 BAND-RESERVOIR (2) 27 46093-N0410 FILTER-OIL (2) 28 46020-U0512 ASSY-CAP,OIL RESERVOIR (2) 28 46020-K2411 ASSY-CAP,OIL RESERVOIR (2) 46020-U0512 29 41128-U0512 SCREW-BLEEDER (2) 30 41129-A2410 CAP-BLEEDER (2) 30 41129-40F00 CAP-BLEEDER (2) 41129-A2410 31 46100-27260 COVER-DUST 32 46080-H3110 ASSY-ROD,PUSH 33 46010-H3125 KIT-REPAIR,BRAKE MASTER CYL. 34 46010-H3325 KIT-REPAIR,BRAKE MASTER CYL.
