Transmission Case Part Numbers
Revision as of 05:49, 27 February 2017; view current revision
Categories: Transmission | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference:
56-Series Transmission
F5C56A Case
 1972 B110 Parts Catalog C-231
TRANSMISSION CASE (5 SPEED)
1 06120-85510 BOLT-hex 6
2 08915-23810 WASHER-lock 6
3 08111-02062 BOLT-hex 3
4 32100-H7230 CASE COMP.-transmission
  32219-G1000 BEARING-need counter shaft
5 32102-18000 PLUG-welch T/M case 2
6 00931-10810 PLUG-filler
7 32110-H1000 COVER ASS'Y-front transmission
8 32113-H3100 SEAL-oil, front cover
9 32112-18000 RING-O, front cover
As required:
 10 32208-18001 SHIMG-adjusting from cover (t=0.2)
 11 32208-18002 SHIMG-adjusting from cover (t=0.1)
 12 32208-18003 SHIMG-adjusting from cover (t=0.3)
13 08120-82510 BOLT-fix front cover 3
14 08915-13810 WASHER-spring 3
15 32130-H7230 EXTENSION ASS'Y-rear
16 32136-G1001 SEAL-oil, rear extension
17*32150-H5000 RETAINER-oil
18 38322-H7201 BREATHER ASS'Y
19 32140-24900 BUSH-return spring
20 32351-H7200 BEARING-needle extension rear
21 08120-80510 BOLT-hex, fix rear extension 3
22 08120-80110 BOLT-hex, fix rear extension
23 08120-85510 BOLT-hex, fix rear extension 4
24 08915-23810 WASHER-spring 8
25 32137-H7200 PLATE ASS'Y-adapter
26 32133-18000 PIN-dowel, rear extension 2
27 08931-44210 PLUG-drain
28 32155-H7200 GASKET-plate coppes
29 32005-21000 SWITCH ASS'Y-revers lamp
30 32703-15400 PINION ASS'Y-speedometer (17T)
31 32707-18000 SLEEVE ASS'Y-speedometer pinion
32 32709-18000 RING-O, speedometer pinion
33 32710-18000 RING-O, speedometer pinion
34 32708-18000 WASHER-speedometer pinion
35 32712-18000 PIN-retaining speedometer pinion
36 08915-13610 WASHER-spring 2
37 08110-61410 BOLT-fix speedometer 2
[Missing from diagram]
   08120-85510 BOLT-hex 6
   08915-23810 WASHER-spring 6
48 30422-18000 COVER-dust, clutch
49 08360-61014 BOLT-hex, dust cover 3
F4W56L Case
4-Speed Light-Duty to March 1973
1 32100-H1630 CASE-TRANSMISSION 4 SPEED 1070- 2 32100-H1600
1 32101-H3900 CASE-TRANSMISSION 4 SPEED 0671-
1 32100-H3930 ASSY-CASE,TRANSMISSION 4 SPEED 0172- 2 32101-H3900
1 32100-H1600 CASE-TRANSMISSION 4 SPEED
2 32102-18000 PLUG-WELCH TRANSMISSION CASE 4 SPEED
3 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED
3 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 0172-
4 00931-10810 PLUG-FILLER 4 SPEED
5 32110-H1000 ASSY-COVER FRONT T/M CASE 4 SPEED
6 32113-13200 SEAL-OIL FRONT COVER 4 SPEED
6 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0971- 2 32113-13200
7 32112-18000 RING-'O' FRONT COVER 4 SPEED
8 32208-18002 SHIM-ADJUST FRONT COVER T=0.1MM (0) 4 SPEED
8 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3MM (0) 4 SPEED 1071-
8 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2MM (0) 4 SPEED
8 32208-18000 SHIM-ADJUSTING FRONT COVER T=0.5MM (0) 4 SPEED
9 08120-82510 BOLT (3) 4 SPEED
10 08915-13810 WASHER-LOCK (3) 4 SPEED
11 32130-H3900 ASSY-EXTENSION REAR 4 SPEED 0172-0972 22 32130-H1010
11 32130-H6230 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 0273- 0 32130-H3930
11 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 1072- 2 32130-H3901
11 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 0172- 2 32130-H3900
11 32130-H1030 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 1070- 2 32130-H1010
11 32130-H1010 ASSY-EXTENSION REAR 4 SPEED 2 32130-H0110
11 32130-H0110 ASSY-EXTENSION REAR 4 SPEED
11 32130-H3901 ASSY-EXTENSION REAR 4 SPEED 1072-0173 30 32130-H3900
12 32132-18000 BUSH-REAR EXTENSION 4 SPEED
13 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 1072- 0 32136-H3100
13 32136-18001 SEAL-OIL REAR EXTENSION 4 SPEED
13 32136-H3100 SEAL-OIL REAR EXTENSION 4 SPEED 1071-0972 22 32136-18001
14 38322-N0100 ASSY-BREATHER 4 SPEED 1070- 2 38322-A0900
14 38322-A0900 ASSY-BREATHER 4 SPEED
15 32140-24900 BUSH-RETURN SPRING 4 SPEED
16 00931-10810 PLUG-FILLER 4 SPEED
17 08120-85510 BOLT (8) 4 SPEED
18 08915-23810 WASHER-LOCK (8) 4 SPEED
19 08915-43810 WASHER-PLAIN 4 SPEED
20 32137-H1010 ASSY-PLATE ADAPTER 4 SPEED
21 32133-18000 PIN-DOWEL REAR EXTENSION 4 SPEED
22 32141-24900 BUSH-STRIKING ROD 4 SPEED
23 32005-21100 COMP-SWITCH REVERSE LAMP 4 SPEED
23 32005-21101 COMP-SWITCH REVERSE LAMP 4 SPEED -673 32 32005-21100
23 32005-H5000 COMP-SWITCH REVERSE LAMP 4 SPEED 0773- 2 32005-21101
24 32005-H5000 COMP-SWITCHI,4 TH 4 SPEED 0773- 2 32005-21101
24 32005-21100 COMP.-SWITCH,4 TH 4 SPEED 0671-
24 32005-21101 COMP-SWITCH,4 TH 4 SPEED -673 32 32005-21100
25 32006-H6000 COMP-SWITCH,NEUTRAL 4 SPEED 0773- 2 32006-H3900
25 32006-H3900 COMP.-SWITCH,NEUTRAL 4 SPEED 0172-0673 3
26 08120-85510 BOLT FIXING TRANSMISSION (6) 4 SPEED
27 08915-23810 WASHER-LOCK FIXING TRANSMISSION (6) 4 SPEED
28 24210-89957 CLIP 4 SPEED 2 24210-89922
29 32702-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED SEDAN COUPE
30 32707-18000 ASSY-SLEEVE SPEEDOMETER 4 SPEED
31 32709-18000 RING-'O' SPEEDOMETER PINION 4 SPEED
32 32710-18000 RING-'O' SPEEDOMETER PINION 4 SPEED
33 32708-18000 WASHER-SPEEDOMETER PINION 4 SPEED
34 32712-18000 PIN-RETAINING SPEEDOMETER 4 SPEED
35 08915-13610 WASHER-LOCK (2) 4 SPEED
36 08110-61410 BOLT (2) 4 SPEED
37 30422-18000 COVER-DUST CLUCH HOUSING 4 SPEED
38 08110-61010 BOLT (3) 4 SPEED
39 08915-13610 WASHER-LOCK (3) 4 SPEED
1973 LB110 USA Parts Catalog, page 50-1
F4W56A Case
4-Speed Heavy-Duty from April 1973
1 32100-H6210 CASE-TRANSMISSION 4 SPEED 0473- 2 32005-21101
2 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 0473-
3 00931-10810 PLUG-FILLER 4 SPEED 0473-
4 32110-H1000 ASSY-COVER FRONT TRANSMISSION 4 SPEED 0473-
5 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0473-
6 32112-18000 RING-'O' FRONT COVER 4 SPEED 0473-
7 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3 (0) 4 SPEED 0473-
7 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2 (0) 4 SPEED 0473-
7 32208-18002 SHIM-ADJUSTING FRONT COVER T=0.1 (0) 4 SPEED 0473-
8 08120-82510 BOLT-FIX FRONT COVER (3) 4 SPEED 0473-
9 08915-13810 WASHER-SPRING (3) 4 SPEED 0473-
10 32130-H6200 ASSY-EXTENSION REAR 4 SPEED 0473-
11 32132-18000 BUSH-REAR EXTENSION 4 SPEED 0473-
12 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 0473-
13 38322-A0900 ASSY-BREATHER 4 SPEED 0473-
13 38322-N0100 ASSY-BREATHER 4 SPEED 0473- 2 38322-A0900
14 32140-24900 BUSH-RETURN SPRING 4 SPEED 0473-
15 00931-10810 PLUG-FILLER 4 SPEED 0473-
16 08120-85510 BOLT (8) 4 SPEED 0473-
17 08915-23810 WASHER-LOCK (8) 4 SPEED 0473-
18 08915-43810 WASHER-PLAIN 4 SPEED 0473-
19 32137-G1100 ASSY-PLATE ADAPTER 4 SPEED 0473-
20 32133-18000 PIN-DOWEL REAR EXTENSION (2) 4 SPEED 0473-
21 32141-24900 BUSH-STRIKING ROD 4 SPEED 0473-
22 32005-21101 COMP-SWITCH REVERSE LAMP 4 SPEED 0473-0673 3
22 32005-K1214 COMP-SWITCH REVERSE LAMP 4 SPEED 0473-0673 32005-21101,32005-H5000
22 32005-H5000 COMP-SWITCH REVERSE LAMP 4 SPEED 0773-
23 32006-H6000 COMP-SWITCH 4TH LAMP 4 SPEED 0473-
24 08120-85510 BOLT-FIXING TRANSMISSION (6) 4 SPEED 0473-
25 08915-23810 WASHER-LOCK FIXING TRANSMISSION (6) 4 SPEED 0473-
26 24210-89957 CLIP 4 SPEED 0473-
27 32702-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED 0473- 32702-15400
27 32703-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED 0473- 2 32702-15400
28 32707-18000 ASSY-SLEEVE SPEEDOMETER 4 SPEED 0473-
29 32709-18000 RING-'O' SPEEDOMETER PINION 4 SPEED 0473-
30 32710-18000 RING-"O" SPEEDOMETER SLEEVE 4 SPEED 0473-
31 32708-18000 WASHER-SPEEDOMETER PINION 4 SPEED 0473-
32 32712-18000 PIN-RETAINING SPEEDOMETER 4 SPEED 0473-
33 08915-13610 WASHER-LOCK (2) 4 SPEED 0473-
34 08110-61410 BOLT-FIX SPEEDOMETER (2) 4 SPEED 0473-
35 30422-H5010 COVER-DUST CLUTCH HOUSING 4 SPEED 0473-
36 08111-01614 BOLT-HEX DUST COVER (3) 4 SPEED 0473-
37 32719-18000 BUSH-SLEEVE SPEEDOMETER 4 SPEED 0473-
1973 LB110 USA Parts Catalog, page 50A-1
