USA model 1200s use a positive pressure Gas Cap. It is not vented. It seals the tank. Venting takes place with a vent line to the engine compartment, where it vents into the crankcase.
Newer models, starting with the 1973 B210, vent into a charcoal cannister. But they use the same cap.
The fuel filler cap should be sealed type. It does not let air out. But it does have a vacuum release valve to let air in. Perhaps it has the wrong cap. It should be more or less flat on the outside, with a nubbin on the inside.
Testing
You should not be able to blow air out throw the cap You should be able to suck air in through the nubbin.
- Wipe valve housing clean and place it in your mouth.
- Inhale air. A slight resistance indicates that the valve is in good mechanical condition. Note that, by further inhaling air, the resistance should disappear as the valve clicks.
- If valve is clogged, or if no resistance is felt, replace cap as an assembled unit.
The same gas cap is used for most Datsuns, from 1971 to early 1980s.
Pressure-Vacuum Type For Emission Control
- #16 / 671016 Atlas
- Stant #G-806
Fits:
- Datsun
- 720 Pickup 1980-1982
- 620 Pickup 1972-1979
- Stanza 1982
- F10 (F-10) 1982
- B110 1971-1973
- S10,S110 (200SX) 1977-1982
- B210 (B-210) 1973-1978
- B310 (210) 1979-1982
- 280Z 1977-1978
- N10 (310) 1979-1982
- A10 (510) 1978-1981
- 610 Wagon 1973-1976
- 710 Wagon 1977
- 810 (Maxima) 1977-1982
- AMC
- 1971, 1972, 1973, 1974 - Ambassador
- 1970 - Ambassador, California only
- 1978, 1979, 1980, 1981, 1982, 1983 - Concord
- 1980, 1981, 1982, 1983 - Eagle
- 1977, 1978 - Gremlin
- 1974, 1975, 1976, 1977 - Hornet
- 1978, 1979 - AMX, Javelin
- 1971, 1972, 1973, 1974 - AMX, Javelin
- 1970 - Javelin, California only
- 1971, 1972, 1973, 1974, 1975, 1976, 1977, 1978 - Matador
- 1977, 1978, 1979, 1980 - Pacer Station Wagon
- 1971 - Rebel
- 1970 - Rebel, California only
- 1979, 1980, 1981, 1982, 1983 - Spirit
- Buick
- 1970 - Station Wagons, California only
- Cadillac
- 1970 - California only
- Chevrolet
- 1970 - Full Size Station Wagons, California only
- 1970 - Camaro, California only
- 1970 - Chevelle & Malibu, California only
- 1970 - Chevy II & Nova, California only
- 1970 - El Camino, California only
- Chrysler
- 1977, 1978, 1979 - LeBaron, 2 Door
- 1976, 1977 - Full Size Station Wagons
- 1971 thru April - Imperial
- 1970 - Imperial, California only
- Dodge
- 1977, 1978 1979 - Diplomat, 2 Door
- 1976, 1977 - Royal Monaco Station Wagon
- 1971 thru April - Full Size, Coronet, Charger
- 1970 - Polara, Monaco, California only
- Ford
- 1970 - Fairlane Station Wagon, California only
- Plymouth
- 1976, 1977 - Gran Fury Station Wagon
- 1971 thru April - Fury, Belvedere,Satelite, Barracuda
- 1970 - Fury, California only
- 1970 - Belvedere, Satellite, except Station Wagon, California only
- Pontiac
- Renault
- 1982 - Fuego
- 1980, 1981, 1982 - 18I
- Subaru
- Toyota
- 1978-1982 Celica
- 1976, 1977 Celica Liftback
- 1981 Starlet
- 1980-1982 Tercel
- 1980-1982 Corolla
- 1971-1974 Corolla Sedan
- 1970 - Corolla 1200
- 1979-1981 Corona Sedan, Liftback, Station Wagon
- 1972, 1973 Corona Hardtop, Sedan
- 1970, 1971 Corona
- 1973-1976 Corona MK II Sedan, Hardtop, Station Wagon
- 1969-1972 Corona MK II
- 1980-1982 Cressida
- 1978, 1979 Cressida Sedan
- 1971, 1972 Crown
- 1971-1983 Hilux Pickup, Sport Truck
- 1979 Land Cruiser
- 1981, 1982 Land Cruiser
- 1981, 1982 Starlet
