GL and GX trim Datsun 1200s used illuminated electrical switch knobs. For 1973 all USA 1200s adopted the illuminated knobs. B210 also used this as standard fitment in Japan and USA.
A variable knob was turned to progressively dim the lamps.
H70 Type: Green knobs with words and illumination.
* Wipe Wash knob * Heater Control knob * Cigar Lighter knob * Auto-trans shift indicator lamp
From 1976 * Clock lamp * Radio lamp
Control Switch
A resistor rheostat was used through 1976. This produced significant heat.
This switch went in-between the lamps and Earth/Ground (B wire).
Resistor Rheostat
B: Earth/Ground (notched side of connector)
RL: to lamps
For 1977 a new active semiconductor rheostat was introduced, which required a 12V IGN feed, but is otherwise wired the same. This one is not load-dependent (works even if one or more bulbs are burned out) and uses less power.
Semiconductor Rheostat - Illumination Control B: Earth/Ground GW: to lamps & Lighting Switch from Fuse Box (RG) GY: to lamps
B310 Illumination Control controlled these lamps:
* Heater Control lamp * Radio lamp * Ash tray lamp * Cigarette Lighter lamp * Clock lamp * To dash rotary connector Three lamps - Instrument Panel * Pin 5 * Pin 6 * Shifter lamp (Automatic Transmission)
Australia
Australia 1200s use a two-position bright/dim switch built into the Lighting Switch. It is not a rheostat (variable). The knob is twisted (rotated) to use either bright or dim position.
See Wiring Diagrams
See main article: Switch Part Numbers
