<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Sedan Fuel Tank
Standard
1 17201-H1001 ASSY-TANK FUEL 40L SEDAN 0570- 2 17201-H1000 1 17201-H1902 ASSY-TANK FUEL 40L SEDAN 1070- 4 17201-H1001 1 17201-H2800 ASSY-TANK FUEL 40L SEDAN 0 17201-H1902 1 17201-H1000 ASSY-TANK FUEL 40L SEDAN 2 17342-18000 RING-O SEDAN 3 17343-14801 PLATE-LOCK SEDAN 2 17343-H1001 3 17343-H1001 PLATE-LOCK SEDAN 3 17343-14801 PLATE-LOCK SEDAN 2 17343-H1001 4 25060-H1000 GAUGE-FUEL TANK SEDAN 4 25060-H1900 GAUGE-FUEL TANK SEDAN 1070- 0 25060-H1000 5 17312-14800 PACKING-DRAIN SEDAN 5 17312-H1000 PACKING-DRAIN SEDAN 2 17312-14800 5 17312-P0101 PACKING-DRAIN SEDAN -370 2 17312-H1000 5 17312-P0102 PACKING-DRAIN SEDAN 2 17312-P0101 6 17310-H1000 PLUG-DRAIN SEDAN 2 08931-44210 6 17310-P0100 PLUG-DRAIN SEDAN -370 2 17310-H1000 6 08931-44210 PLUG SEDAN 7 17251-H1000 CAP-FILLER SEDAN 8 17264-18000 PACKING SEDAN 9 17220-H1000 ASSY-TUBE FILLER UPPER SEDAN 10 17222-H1000 NECK-FILLER SEDAN 11 17221-H1000 PACKING FILLER NECK SEDAN 12 08310-40812 SCREW (3) SEDAN 17229-H1900 HOSE-FILLER SEDAN 17229-H1000 13 17229-H1000 HOSE-FILLER SEDAN 14 08723-15800 CLAMP-HOSE (2) SEDAN 15 A7325-H1000 TUBE(10X14DX5M) SEDAN 16 08723-11400 CLAMP-HOSE (2) SEDAN 16 16439-22100 CLAMP-HOSE (2) SEDAN 2 08723-11400 17 17335-H1000 TUBE-VINYL SEDAN 18 08360-82014 BOLT WITH LOCK WASHER (4) SEDAN 19 08915-53810 WASHER-PLAIN (4) SEDAN 20 17314-H1000 GROMMET SEDAN
1973 LB110 USA Parts Catalog
Evapo
1 17201-H1902 ASSY-TANK FUEL 40L SEDAN EVAPO 0570- 2 17201-H1901 1 17201-H2800 ASSY-TANK FUEL 40L SEDAN EVAPO 1070- 2 17201-H1902 1 17201-H1901 ASSY-TANK FUEL 40L SEDAN EVAPO 2 17342-18000 RING-O SEDAN 3 17343-H1001 PLATE-LOCK SEDAN 3 17343-14801 PLATE-LOCK SEDAN 2 17343-H1001 4 25060-H1900 GAUGE-FUEL TANK SEDAN EVAPO 5 17312-14800 PACKING-DRAIN SEDAN 5 17312-H1000 PACKING-DRAIN SEDAN 2 17312-14800 5 17312-P0101 PACKING-DRAIN SEDAN 1070- 2 17312-H1000 5 17312-P0102 PACKING-DRAIN SEDAN 1070- 2 17312-P0101 6 08931-44210 PLUG SEDAN 6 17310-H1000 PLUG-DRAIN SEDAN 2 08931-44210 6 17310-P0100 PLUG-DRAIN SEDAN 1070- 2 17310-H1000 7 17251-H1900 CAP-FILLER SEDAN 7 17251-H1000 CAP-FILLER SEDAN EVAPO 0570- 2 17251-H1900 7 17251-H1900 CAP-FILLER SEDAN EVAPO 0672- 2 17251-H1000 7 17251-H1901 CAP-FILLER SEDAN EVAPO 0672- 2 17251-H1900 7 17251-H1902 CAP-FILLER SEDAN EVAPO 0173- 2 17251-H1901 8 17264-18000 PACKING SEDAN 9 17220-H1901 TUBE-FILLER UPPER SEDAN EVAPO 10 17222-H1000 NECK-FILLER SEDAN 11 17221-H1000 PACKING FILLER NECK SEDAN 12 08310-40812 SCREW (3) SEDAN EVAPO 13 17229-H1900 HOSE-FILLER SEDAN EVAPO 14 08723-15800 CLAMP-HOSE (2) SEDAN EVAPO 15 08360-82014 BOLT WITH LOCK WASHER (4) SEDAN 16 08915-53810 WASHER-PLAIN (4) SEDAN 17 17314-H1000 GROMMET SEDAN 18 17350-H1900 ASSY-TANK RESERVOIR SEDAN EVAPO 19 17351-H1900 CONNECTOR-3 WAY SEDAN EVAPO 19 17351-H1901 CONNECTOR-3 WAY SEDAN EVAPO 2 17351-H1900 20 17352-H1901 SEPARATOR SEDAN EVAPO 20 17352-H1902 SEPARATOR SEDAN EVAPO 0570- 2 17352-H1901 21 A8742-20040 HOSE-FUEL RUBBER (10X17X2.2M) SEDAN EVAPO 2 08742-20040 21 08742-20040 HOSE-FUEL RUBBER (10X17X2.2M) SEDAN EVAPO 2 A7515-H1900 21 A7515-H1900 HOSE-FUEL RUBBER(10X16DX5M) SEDAN EVAPO 22 A7515-H1800 HOSE-FUEL RUBBER(6X13.5X5M) SEDAN EVAPO 22 08742-20020 HOSE-FUEL RUBBER (6X13.5X2.2M SEDAN EVAPO 2 A7515-H1800 23 08723-11400 CLAMP-HOSE 1 (14) SEDAN EVAPO 23 16439-22100 CLAMP-HOSE 1 (14) SEDAN EVAPO 2 08723-11400 24 17230-H1900 HOSE-FILLER 2ND SEDAN EVAPO 24 17230-H1901 HOSE-FILLER INNER SEDAN EVAPO 2 17230-H1900 25 08723-13600 CLAMP-HOSE SEDAN EVAPO 26 08723-11400 CLAMP-HOSE (2) SEDAN EVAPO 26 16439-22100 CLAMP-HOSE (2) SEDAN EVAPO 2 08723-11400 27 17361-H1922 TUBE-EVAPO SEDAN EVAPO AUTOMATIC 27 17361-H1902 TUBE-EVAPO SEDAN EVAPO MANUAL 27 17361-H1903 TUBE-EVAPO SEDAN EVAPO MANUAL 0 17361-H1902
