Nissan Factory service manual for the A14E fuel injected engine, 1978 edition.
A14E Service Manual A14E Service Manual Part 2 Engine Overhaul & Service Data
You can help us out! If you can type Japanese, please click Edit and type in the text. Also need help translating. Thanks!
A型 エンジン
A-series Engine
(1978 Standards Conforming Car)
はじめに Introduction
はじめに
この本は、53年度排出ガス規制適合のNAPSを挟用したA系EGI仕 ... | Introduction
This book, A-specifications EGI system was for conforming the NAPS of 1978 fiscal exhaust gas regulations ... |
目次 Table of Contents
Overview 4
1. 概要
| 1. 概要 | 1. Overview
排出ガス清浄化システム"NAPS"及びEGI装置は基本的に次の装置で構成され、53年度排出ガス規制に適合している。
1. エンジン改良(エンジン本体、点火系)
2. EGI装置(吸入空気量検出方式)
3. 排気ガス還流(EGR)装置(負荷比例式〔VVT方式〕)
4. 酸化触媒装置(触媒ペレットの改良)
5. 二次空気導入(EAI)装置
The A-series EGI engine, which complies with the 1978 exhaust gas regulations, is based on the conventional engine, but in addition to complying with the 1978 exhaust gas regulations, it also features an improved oxidation catalytic system with improvements to the engine body and the EGI device and various NAPS devices to improve drivability and fuel economy.
The exhaust gas purification system "NAPS" and EGI device are basically composed of the following devices, and comply with the 1978 exhaust gas regulations.
1. Engine improvements (engine body, ignition system)
2. EGI device (intake air volume detection method)
3. Exhaust gas recirculation (EGR) device (load proportional type [VVT method])
4. Oxidation catalyst device (improvement of catalyst pellets)
5. Secondary air introduction (EAI) device
Engine Main Specifications 5
1-1 エンジン主要諸元 Engine Main Specifications
NAPS Specification List 6
1-2 NAPS仕様-覧 NAPS Specification - List
Engine Appearance 7
1-3 エンジン外観
Engine Appearance
(1) Secondary air intake tube 二次空気導入チューブ (2) Throttle chamber スロットル チャンバー (3) Air regulator エア レギュレーター (4) EGR control valve EGRコントロール バルブ (5) Dashpot ダッシュ ポット
(1) Water temperature switch 水温スイッチ (2) TV valve TVバルブ (3) Water temp sensor 水温センサー (4) Blowby lower hose プローパイ ホース ロア
(1) Alternator オルタネーター (2) Distributor ディストリビューター (3) Blowby upper hose ブローバイ アッパー ホース (4) Pressure Regulator プレッシャー レギュレーター (5) VVT valve VVTバルブ (6) VC solenoid valve VCソレノイド バルブ (7) Fuel injectors フューエル インジェクター
Engine Sectional View 10
1-4 エンジン断面図
Engine Performance Curve 11
1-5 エンジン性能曲線
NAPS System View 12
1-6 NAPSシステム図
NAPS System View
NAPS Piping Diagram 13
1-7 NAPS配管図
NAPS Piping Diagram
(1) Vacuum Hose Diagram
mm
1. 170 Vacuum gallery ~ pressure regulator
2. 90 VVT tube ~ VVT valve
3. 200 VVT valve ~ TV valve 3-way connector
4. 70 Vacuum gallery ~ Dist. 3-way connector
5. 50 Vacuum gallery ~ Dist. 3-way connector
6. 190 Vacuum gallery ~ TV valve
7. 170 EGR control valve ~ TV valve
8. 110 TV valve ~ 3-way connector
9. 540 Distributor ~ 3-way connector
10. 120 Vacuum gallery ~ VC solenoid valve
11. 200 VVT valve ~ VC solenoid valve
12. 200 Throttle chamber ~ vacuum gallery
13. 90 Vacuum connector ~ vacuum gallery
14. 130 Throttle chamber ~ vacuum gallery
(for Distributor)
15. 230 Throttle chamber ~ VC solenoid valve
16. 170 Throttle chamber ~ vacuum gallery
(for EGR control)
17. Blind Cap
Engine Maintenance Notes 15
1-8 エンジン整備上の注意
Engine Start-up Notes 18
1-9 エンジン始動上の注意
Cautions for starting the engine
page 18 #English
エンジンの始動方法を問診し、正しい始動方法をユーザーに指導してください。
(1) ハンド ブレーキ レバーをいっぱいに引き、変速機のシフト レバーをニュートラル位置にする。
(2) アクセル ペダルを踏まないで、スターターを回して始動す。
注意:スターターは連続10秒以上回さない。一度回した後は、10秒以上待ってバッテリーを回復させる。
(3) 始動後、暖機運転をする。
注意:
1.始動直後など、エンジンが冷えている場合、無用の空吹しや高回転にしない。
2.暖機されているときでも、停車中に長時間(10分以上)高回転にしない。
(4) エンジン始動後、バッテリー ターミナルは絶対に外さない。
Ask the user how to start the engine and instruct them on the correct method.
(1) Pull the handbrake lever all the way in and put the transmission shift lever in neutral.
(2) Turn the starter to start the engine without depressing the accelerator pedal.
Caution: Do not turn the starter for more than 10 seconds continuously. After turning it once, wait 10 seconds or more to allow the battery to recover.
(3) After starting, warm up the engine.
CAUTION:
1. When the engine is cold, such as immediately after starting, do not rev the engine unnecessarily or run it at high speed.
2. Even if the engine has been warmed up, do not run it at high speed for long periods of time (more than 10 minutes) while the vehicle is stopped.
(4) After starting the engine, never disconnect the battery terminals.
Regular Inspection And Maintenance 19
2. 定期点検整備 Regular inspection and maintenance
キャニスター Canister * ? * ? filter 40,000 km
キャニスター本体 Canister Body
フィルター Filter
フィルターの点検 Filter Inspection
Checker 28
3. チェッカー Checker
Function Checker 28
3-1 ファンクション チェッカー Function Checker
EGI Harness Check 30
3-2 EGI ハーネス チェッカー (EG1131) EGI Harness Checker
(1) (2)page 31
page 34 - EGI Circuit
full | japanese
Page 35 - Checker: ハーネス実態図 EGI Harness Schematic View
full | Japanese
EGI Control Unit Checker 38
3-3 EGIコントロール ユニット チェッカー EGI Control Unit Checker
Fault Diagnosis 42
4. 故障診断 Fault diagnosis
On-vehicle Engine Maintenance 45
5. 車載上のエンジン整備 On-vehicle Engine maintenance
Air Door Adjustment 45
5-1 アイ ドル調整
Air Cleaner and ? 48
5-2 エア クリーナー及びニ?空気?入(EAI)装
Throttle Chamber 89
5-8 スロットル チャンバー
Manifold 90
5-9 マニホールド
Cylinder Head 92
5-10 シリダー ヘッド
Catalyst ? 95
5-11 触媒コンベーター及び排気温?報装置
103
104
105
108
Engine Removal and Installation 111
エンジン脱着
Removing and installing the engine
6. エ ン ジ ン 脱 着
Engine Overhaul 114
7 Engine Overhaul 114 7.1 Overhaul Notes 114 7.2 Disassembly 115 7.3 Inspection, Correction, Replacement 119 7.3.1 Cylinder Head and Valve 119 7.3.2 Cylinder Block 124 7.3.3 Piston, Piston Ring, Conrod 125 7.3.4 Crankshaft, Main Bearing 128 7.3.5 Camshaft 130 7.3.6 Other Components 131 7.4 Assembly 132
Service Data 141
8. サ=ビス データ Service Data
See A14E Service Manual Part 2
8.1 Standard Bolt, Nut Tightening Torque 141 8.2 Engine Torque Specs 142 8.3 Service Data 143
Special Tools And Checker 146
9. 特殊工具監及びチェッカー Special tools and checker
Special Tools 146
9-1 特殊工具
Checker and Check Sheet 151
9-2 チェッカー及びチェック シート
Inspection Circuits 155
10. 点検回路 Checking Circuits
Function Checker Check 155
10-1 ファンクション チェッカー チェック
EGI Harness Checker Check 156
10-2 EGI ハーネス チェッカー チェック
Memos 176-182
[pages 176-182 are blank "Memo" pages for taking notes]
Publisher's Page 183
page 183 #English
複製を禁ず
印 刷発行 昭和 53年 4 月
改 訂 昭和 53年 6 月
『複製品』
発行所 日産自動車株式会社 担当 サービス部技術資 料課 東 京 都 中 央 区 銀 座 6-17-1 TEL 03-543-5523
1 H-804055 2 H-806005 3 H-003010 4 H-105013
This book contains instructions for disassembly, assembly, adjustment, etc. of each device. However, since disassembly and maintenance is regulated by a notification from the Ministry of Transport that "disassembly and maintenance must be carried out by persons certified for automobile disassembly and maintenance," we ask that you always ask a maintenance shop to carry out disassembly and maintenance.
Printed April 1978
Revised June 1978
"Reproduction"
Published by Nissan Motor Co., Ltd. Contact Technical Information Section, Service Department 6-17-1 Ginza, Chuo-ku, Tokyo TEL: 03-543-5523
