<-- back to 56-Series Transmission Parts
Rubber seals for gearbox.
#Front Cover O-ring #Front Oil Seal #Transmission Rear Seal
Front Cover O-ring
32112-18000ᴳ RING-O, front cover ($7 Nissan USA 2025)
Front Oil Seal
8 32113-13200 SEAL-OIL FRONT COVER 8 32113-H3100 SEAL-OIL FRONT COVER 0971- 2 32113-13200
C2113-H3100ᴳ SEAL-OIL FRONT COVER 0971- * Replaces: 32113-H3100ᴳ and 32113-13200ᴳ
Rockauto * SCHAEFFLER SS2200ᴳ Bore Diameter (IN) 1.575 Bore Diameter (MM) 40.01 Maximum Seal Inside Diameter (IN) 0.984 Maximum Seal Inside Diameter (MM) 24.99 Seal Outside Diameter (IN) 1.583 Seal Outside Diameter (MM) 40.21 Seal Type Metal; Spring; Auxiliary lip Seal Width (IN) 0.276 Seal Width (MM) 7.01 Sealing Material Nitrile Fits: * Datsun B110/B210/B310 * GM/Isuzu truck steering Gear Worm Shaft seal * Honda Accord/Prelude 1979-1983
Rockauto * Timken 222540ᴳ F4W56L, F4W56A $2.84 * National 710316ᴳ F4W56L * Oil Seal: Nitrile * Shaft Size=0.984" * Housing Bore=1.575" * Outer Diameter=1.583" * Width=0.315" * Timken 710417ᴳ F4W63, F4W63A, F4W63L * Timken 1981ᴳ R4W71A
REPAIR SLEEVES* SKF 99098ᴳ Speed-Sleeve * Timken KWK99098ᴳ Kwik Sleeve repair F4W56L, F4W56A * National/BCA 99098ᴳ Redi-Sleeve $27.79 * .982" x .986" x .313"
TRANSMISSION EXTENSION REAR OIL SEAL (tailshaft seal/yoke seal/gearbox output seal)
Which seal you need depends on which type of Driveshaft yoke is being used.
Shrouded OR unshrouded OR lipped
If you buy the wrong seal, you may be able to use it by cutting it down
56-series Transmission
3-speed, 4-speed, 5-speed 56-Series Transmission 16 #32136-18001 SEAL-OIL REAR EXTENSION 16 #32136-H3100 SEAL-OIL REAR EXTENSION 1071-0972 22 32136-18001 16 #32136-G1001 SEAL-OIL REAR EXTENSION 1072- 0 32136-H3100
60-series Transmission
60-series is used behind A14 and A15 engine in the Datsun B310
32150-H7300 4-speed 8110-
4-speed & 5-speed RockAuto.com * Nissan C2136-H8900 > 32136-H8900 $10.00 USD * Nissan C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION $23.87 USD * Timken 2016 * SKF 11619 (also says it replaces #32136-G1001) FITS * 56A,60A,60L SPECS * Material Nitrile * Shaft Size 1.181" 30mm * Housing Bore 1.772" 45mm * Outer Diameter 1.78" 45.2mm * Flange Diameter 2.441" 62mm * Width 0.591" 15mm![]()
32136-H3100
B110 from October 1971 * replaced the earlier #32136-18001 * not compatible with the newer #32136-G1001
32136-H3100ᴳ SEAL-OIL REAR EXTENSION [45mm bore] RockAuto.com
* SKF 11618
32136-18000
Simple type 45mm
Replaced by #32136-H3100 * B10 Datsun 1000 * Early B110 Datsun 1200
32136-18000ᴳ 45mm diameter
32136-G1001
New style with shield enclosing the end of the transmission. Will not work with drivelines that have a shield.
56-series from October 1971 * B110 from 1971.10 * B120 from 7110 * B210
TIMKEN 2016ᴳ F4W56A, F4W56L, F4W60, F4W60L, F4WF60, F4WF60L $11.04 NATIONAL 2016ᴳ Aichi F4W56L $15.87 * Material Nitrile * Shaft Size 1.181" 30mm * Housing Bore 1.772" 45mm * Outer Diameter 1.78" 45.2mm * Flange Diameter 2.441" 62mm * Width 0.591" 15mm
32136-G1001ᴳ 60mm flange, 45 mm bore
