Axle Shaft
Revision as of 03:26, 7 August 2009; view current revision
Datsun 1200 axle shafts come in two sizes: H145 for all cars and early utes, and H165 units for 1974-1997 models.
Bearing Replacement
The bearing is held on a by a collar (a plain ring). This has to cut off with a cold chisel, then a new one pressed on.
Bearing held on by shaft collar
When replacing a rear axle bearing, check the wheel bearing-to-housing end face clearance and adjust with shims.
Suppliers - USA
Axle
  • 38162-G0300 ASSY-SHAFT REAR AXLE B110, B210
  • 38162-H8500 SHAFT ASSY-REAR AXLE(L=612) B310
  • 38162-G1000 SHAFT ASSY-REAR AXLE B120 7510- with H165 diff
    • Also B210 H165B with L16 engine
Rear Axle Seal
  • Nissan 43252-H1000 SEAL-OIL REAR AXLE SHAFT
Rear Axle Bearing
  • Nissan 43255-H1000 COLLAR-REAR AXLE BEARING
    Required when replacing the bearing. The collar is cut in two to release the bearing, and the new collar pressed on.
  • Nissan 43215-18000 BEARING-REAR AXLE
    • SKF GRW115R Schuck's
    • KOYO 83294C4
    • NSK B32-3CC5
    • NTN 6206BLUX/32C4 $28 USD
Interchange:
  • 1967-1970 Datsun B10 (180 is B10 part number)
  • 1970-1973 Datsun B110
Specs:
  • O.D.: 62.000 (mm)
  • Bore: 30.000 (mm)
    •  ?? 32 mm
  • Width: 16.000 (mm)
