Datsun 1200 has a service brake system with the handle conveniently located between the two front seats. Also known as "emergency brake" or "hand brake".
Hand brake cover.
Top: replacement part, same as B210
Bottom: original B110 design
Light Switch
Lamp switch for brake handle was fitted to USA 1200, and to newer utes.
Not used on Japan Market before 1975.
The dash lamps are always connect to 12V when IGN switch is on. They only light up when a switch grounds the bulb. A switch is fitted to the hand brake lever. When you pull the lever, it grounds the circuit.
- G: Green wire from IGN fuse to dash cluster lamps
- B: Black wire to main body earth bolt in engine compartment
- Y/G: Yellow wire w/Green stripe, from switch to bulb, grounds the bulb
- 74965-H1000 BOOT-HAND BRAKE
- 74965-H7300 BOOTS-HAND BRAKE
- 36011-89901 SWITCH-HAND BRAKE USA
- 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- USA
- Also fits B210 USA
- Also fits B210 JAPAN from '75-4
- 36011-K2200 SWITCH ASSY-PARKING BRAKE LAMP B120 7510-
- 36010-H1001 CONTROL ASS'Y-hand brake STD B110
- 1 36310-H1001 LEVER ASS'Y-hand brake STD
- 36010-H1101 CONTROL ASS'Y-hand brake DX,GL,GX B110
- 1 36310-H1101 LEVER ASS'Y-hand brake
- 1 36310-G1000 LEVER ASS'Y-hand brake (up to '73-11) B120
- 1 36310-G1001 LEVER ASS'Y-hand brake (from '73-12) B120
- 1 36310-G1600 DEVICE ASSY-PARKING BRAKE CONTROL 7510-7803 B120
- 1 36310-G1660 DEVICE ASSY-PARKING BRAKE CONTROL 7804-7907 B120
- 1 36310-G1661 DEVICE ASSY-PARKING BRAKE CONTROL 7908-8910 B120
- 1 36310-95W00 DEVICE ASSY-PARKING BRAKE CONTROL 8910- B120
- 2 36315-H1001 GRIP, lever-hand brake (up to '73-11)
- 3 36327-H1001 ROD-release, hand brake (up to '73-11)
- 4 36402-H1025 CABLE SET-hand brake, front B110
- 4 36402-G1000 CABLE ASSY-hand brake, front B120
- 5 36326-H1000 CLIP-hand brake cable, front
- 6 08310-50612 SCREW (2)
- 7 08915-13510 WASHER-lock (2)
- 8 36406-H1001 PLATE-lock, hand brake cable
- 9 08911-30610 NUT
- 10 08110-82014 BOLT (2)
- 10 08110-82062 BOLT (2)
- 01211-00261 NUT 8910-
- Not Shown, pin fastening cable to lever
- 36382-18000 PIN-clevis (up to '73-11)
- 36385-18000 FIXTURE-push spring (up to '73-11)
- 36339-H1000 PIN-COTTER
